Eldorado Stone Veneer - Masonry - Contractor Talk
Old 06-25-2009, 03:09 PM   #1
Imagineer09's Avatar
Trade: Masonry Contractor
Hey Guys, new to the forum.
I have a project in the pipeline and trying to gather information prior to starting.
Eldorado brick (vintage used) thin veneer. Typical installation is fine.
I have a dome arch to install in the above brick. It's the main dining room on a new restaurant. diameter is 15ft, 40ft in length.
My question is, has anyone placed this veneer in this ceiling situation.
I am concerned about losing adhesion at anytime. Eldorado's cant provide any tech support as to this situation.
Tech support say a tile thin set adhesive dry's out too quickly and must be made mixed with sand/cement mixture, though I cant help but wanna pure thin set the little sod's into place.
Any advice would be appreciated. I'm a structural masonry guy adapting to this thin veneer revolution, forcibly I might add.
Thanks in advance!
Imagineer09 is offline
Old 06-25-2009, 04:09 PM   #2
DJ9222's Avatar
Trade: Mason Contractor
Rewards Points: 150
Re: Eldorado Stone Veneer
Hi
We did a ceiling in a room about half the size of your project with used brick that we cut down to about 3/8" thick, we used the pre mixed modified thin set and had no problem with them sticking. We pointed them up using a squeeze bag(reg.type N mortar) and hit the joints with a jointer.
The GC and owner luved it...... Good luck...
DJ9222 is offline
The Following User Says Thank You to DJ9222 For This Useful Post:
Imagineer09 (06-25-2009)
Old 06-25-2009, 06:30 PM   #3
Thanks for the reply!
Curious to know what thin set mortar you used?
Eldorao's technical support guy just emailed me stating that they dont guarantee installations in this position since the testing for code does'nt require them to.
Getting mixed feedback from Eldorado also, Female Eldorado tech support said to use thinset mortar mixed with 3 parts cement, 7 parts sand. Soon as she said that the alarm bells began to ring an I tried to get around her, hence email from tech support director above.
He pointed me onto a product called LATICRETE 211 mixed with 4237 latex additive. Seems a trip to the tile forum might be needed to verify this product. I Contacted a few more people regarding this and they suggested LATICRETE 254 Platinum to achieve same results.
So any feed back on thin set mortars in this situation would be appreciated.
Nightmare images of fighting to get the veneer to stay up octopus style & an even worse image of customers dining on steak, fries and a slice of eldorado! Not good! Gotta get it right the first time!
Thanks for the replies!
Old 06-25-2009, 08:16 PM   #4
DJ9222's Avatar
Rewards Points: 150
Hi
The thin set we used was a premixed modified thin set I will have to get the brand name for you but i am pretty sure it was an exterior thin set... i will get back to you
DJ9222 is offline
What is the lightest stone veneer? bob_cntrctr Masonry 11 06-17-2009 04:42 PM
Inside corner (lap siding to stone veneer) HandyHails Windows, Siding and Doors 16 05-09-2009 07:08 PM
Stone Veneer applied to round pillars louiscd Masonry 1 04-27-2009 03:06 PM
Natural Stone Veneer over Painted CINDER Block Tommy C Masonry 14 04-22-2009 11:46 AM
Stone veneer -Wilf- Masonry 5 09-01-2008 09:07 PM
