Drywall Guy With A Masonry Question... - Masonry - Contractor Talk
Old 09-14-2013, 07:29 PM   #1
Construction Estimator
DaveH's Avatar
Trade: Estimator
Rewards Points: 250
Masons of the world!!!
I am doing a wainscot project using manufactured thin stone on the front of my house. I have installed a vapor/water barrier and then applied Durock cement board over it. I know I do not need to use lath (Oh the horror of it all!) I just need to know is a scratch coat needed for proper bonding. I have seen some use no scratch and simply butter and stick. I just don't know if this is good enough. I plan on using Type S morter, and the "stone" is actually made up of "tiles" so-to-speak that are to have a dry stack appearance. Anybody????
A buck a foot is not an estimate! It's a crap shoot!
DaveH is offline
Old 09-14-2013, 08:33 PM   #2
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Re: Drywall Guy With A Masonry Question...
You should use a alkaline resistant tape and tape the seams. I would use a thin stone mortar, ask your local brick yard if they have some, follow the instructions on mixing it. Parge the wall and butter the back and stick it on. Point however you fancy but dont make a mess or it will be tough to get off. Sponge the stones if needed. Keep the water bucket clean. Cut a thinner stone then the one next to it to hide the cut.
Post pics when your done
JBM is offline
Old 09-14-2013, 08:33 PM   #3
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
just ask yourself this question... what is it that's going to make your "scratch" coat bond better than just applying the stone??? a failure is a failure... one just costs more than the other
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 09-14-2013, 08:35 PM   #4
always building
out of curiosity JBM,... what is a thin stone mortar and how does it differ???
www.RDPontheWeb.com
Old 09-14-2013, 08:49 PM   #5
DaveH's Avatar
Trade: Estimator
Rewards Points: 250
JBM,
Taping of the seams. Check. Do I do that with the parge coat? Should the parge cure prior to application, or should I apply while wet.
Also you said sponge the stone. To clean it? Or to wet it? Since this product has a dry stack look, there's no tucking. Sorry for the silly questions but masonry is usually done by the time my trade shows up on the job!
DaveH is offline
Old 09-14-2013, 09:40 PM   #6
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Follow manufacture specs and you can't go wrong. I find that novices benefit from the better grip a scratch coat provides.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 09-14-2013, 10:03 PM   #7
dbrons's Avatar
Trade: Masonry
Rewards Points: 608
Hi Parker ,
Stone veneer mortar is what they call it in our neck of the woods and it's really like mortar and thin-set mixed. It's stickier than type s, but also kinda runny. And I would agree with JBM and would use it for this sort of job.
Also agree a scratch coat not needed as long as the finished wall is strong enough to not flex when bumped with a lawnmower or rake.
What I do sometimes with a stack stone, is to add color to my mortar to match the stone, and do a quick parge coat as I go. This is just so no gray cement, or durock would be visible through any small gaps there might be. If you're dealing with those Chinese panels a little adjustment with the grinder here and there and you can lay them tight so there shouldn't be any gaps.
dbrons is offline
The Following 2 Users Say Thank You to dbrons For This Useful Post:
dom-mas (09-16-2013), parkers5150 (09-15-2013)
Old 09-15-2013, 06:00 AM   #8
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
I always wash my thin brick or stone first thing. Get all the dust and slurryoff from the quarry. And some cement board needs to be dampened slightly for a better bond.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 09-15-2013, 06:52 AM   #9
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
We use Stone-Hold. It works good and only cost a little more than 'S' type
brickhook is offline
The Following 2 Users Say Thank You to brickhook For This Useful Post:
fjn (09-15-2013), parkers5150 (09-15-2013)
Old 09-16-2013, 05:36 PM   #10
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I agree with JBM, dbrons and CJkarl. Use a thin veneer mortar and add some colour, black is good too so that it look like shadow rather than mortar. If you can't find thin veneer mortar, add a pile of acrylic additive to a regular mix, that helps with the sticking. And if you wet the back of the stone you make sure there is no dust effecting the bond, and if you dampen the cement board, you ensure that the board doesn't suck too much moisture out of the mortar. Personally I don't think a parge coat is needed, but it won't hurt...unless you put it on too thick
www.dominionmasonry.ca
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
S.U.M (09-16-2013)
Old 09-16-2013, 06:51 PM   #11
JBM's Avatar
Trade: Masonry
I was referring to applying mud to the board and then to the back of the stone, not necessarily parging the whole board, more parge as you go to get it to stick/bond properly. You know, like tile lol.
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
drywall finish question Dustyrose General Discussion 6 08-07-2009 03:27 AM
Switching Gears: masonry for the full house? bnentrup Masonry 1 06-06-2009 03:33 PM
Question about small drywall job we're doing.. Dorman Painting Painting & Finish Work 4 10-30-2008 05:40 PM
