Driveway Edge Trim - Masonry - Contractor Talk
Driveway Edge Trim
Old 05-01-2020, 09:08 AM   #1
AndrewF's Avatar
Trade: Design
Driveway Edge Trim
We’ve got pavers for trim on a clients driveway. Problem is the pavers (24”x12”) have to go around a pretty gnarly radius. The owner is going to want to keep the length (24) of the pavers intact. Will this work? Is it going to require 4 cuts per paver?
AndrewF is offline
Old 05-01-2020, 09:15 AM   #2
MarkJames's Avatar
Rewards Points: 19,505
Re: Driveway Edge Trim
Lay normal. Cut the radius. Add a border with smaller blocks.
MarkJames is offline
tgeb (05-01-2020)
Old 05-01-2020, 01:36 PM   #3
tgeb's Avatar
Rewards Points: 1,060
Adding a border course makes it a lot easier and a cleaner install.
www.gebcon.com
tgeb is offline
Old 05-02-2020, 10:44 PM   #4
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
Use the "waste" pieces with the cut to halve the angle and depth of cut needed, still cutting both longside. Saw the driveway to fit the un cut 12" end i....
out of Box answer: just lay all pieces in running bond and cut the curve in the edge(s)? Easy peasy
variation: as above with basket weave....this would be my preference.
switch running bond at center of curve to other axis, I.e. turn it 90 degrees.
Next time edge , then driveway, Much cheaper.
what is the tightest radius in feet?
Fouthgeneration is offline
