Crawlspace Low Point Drain Details Pacific NW - Masonry - Contractor Talk
Old 05-16-2019, 06:53 PM   #1
diplomat
Golden view's Avatar
Rewards Points: 1,516
Here they put a piece of 3" abs with a backwater valve through the footing, but this is new to me since I learned foundations on another region. Does it go at the bottom, under, or middle? Dumb question I know but I'm new to the practice.
Golden view is online now
Old 05-16-2019, 07:02 PM   #2
General Contractor
greg24k's Avatar
Rewards Points: 8,646
Re: Crawlspace Low Point Drain Details Pacific NW
It usually under it with a sleeve. If you going through the footing you have to make the footing is thick enough to have a min 6" of concrete above the sleeve.
greg24k is online now
The Following 2 Users Say Thank You to greg24k For This Useful Post:
Bull Trout (05-16-2019), Fouthgeneration (05-18-2019)
Old 05-16-2019, 07:58 PM   #3
diplomat
I'm 80% sure they don't do it your way, even though your way makes sense.
Old 05-16-2019, 09:00 PM   #4
General Contractor
greg24k's Avatar
I don't know how they do it, stop by and see what they say. This was always a typical way of doing it, the sleeve would be wedged between the form, you would dig a bit deeper under it to make sure entire sleeve is embedded in concrete and after the forms off, you slip perforated pipe and tie into the pit something like this. There is also a code section about that.
Old 05-16-2019, 09:16 PM   #5
diplomat
Typical crawlspace here has footing bottom at the same elevation as crawl floor. No gravel or drain tile inside or out. I'm pretty sure most of them have this low point drain just sticking through and shoved into the dirt. If nothing else it gives you an easy connection point down the road to add a drywell.
Old 05-16-2019, 11:33 PM   #6
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,526
Why do they have the interior crawlspace at the same level as the footing?
Why would someone intentionally bring water into the crawlspace, and then pump it out?
And I've always thought that sleeves had to be in the stemwall, or below the footing? I'll have to look it up sometime, but I'm pretty sure there is a code prohibition about penetrations through a footing.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
fjn (05-17-2019), Golden view (05-17-2019)
Old 05-17-2019, 02:09 AM   #7
Bull Trout's Avatar
Rewards Points: 132
One way valve to allow water out without having to be pumped, as the water table rises the pit will fill higher triggering the pump
Bull Trout is offline
The Following User Says Thank You to Bull Trout For This Useful Post:
Old 05-17-2019, 06:04 AM   #8
General Contractor
greg24k's Avatar
Plumbing pipes for a sewer connection or water lines cannot go through footing it must be under or through a stem wall.
Like the house I was building in the picture 1you can see sleeve is going through the stem wall, after the backfill, when they bring water and sewer, all they have to do is slip the sewer and water lines through the sleeves.
The second picture is incorrect, they have a perforated pipe running right through the footer, there should be a sleeve installed.
The 3d picture is how it's done, you put a sleeve and when doing the drain pipe you slip right through.
Crawlspace low point drain details Pacific NW-p_00024.jpg   Crawlspace low point drain details Pacific NW-cap-1.jpg   Crawlspace low point drain details Pacific NW-cap2.jpg
Old 05-17-2019, 09:54 AM   #9
Mordekyle's Avatar
Rewards Points: 5,964
That is how it seems almost all of them are here in Salem.
Not always at the low point. Generally at the dirt or an inch low or high.
They donít always have the check valve.
They generally run to the curb. Sometimes to a greenway if there is one at the back of the house.
Just about always through the footing.
It does make for a handy place to add discharge for a sump pump.
Mordekyle is online now
Old 05-17-2019, 10:35 AM   #10
fjn's Avatar
Trade: mason
Rewards Points: 11,202
It has NEVER made sense to me to "invite" exterior ground water into the structure only to then have to figure out a way to get it back out ! Having an exterior and interior footing drain system tied together also makes no sense. If one wants to have two systems,great,let the interior on be thought of as the back up system.
The answer to all this is an exterior sump basin. JLC ran an article on that a few months back. FHB showcased it in their book called best practices. I will see if I can pull one up.
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
Fouthgeneration (05-18-2019), SmallTownGuy (05-17-2019)
Old 05-17-2019, 10:39 AM   #11
fjn's Avatar
Trade: mason
https://www.jlconline.com/how-to/fou...dation-drain_o
fjn is offline
Old 05-17-2019, 04:57 PM   #12
Mordekyle's Avatar
The check valve stops water from backing in as well as rodents from getting in.
They seem to work fairly well. They are not tied to rain drains, but separate
A lot of the soil around here has a lot of clay in it. It would take a long time for it to migrate to an exterior sump pump.
Old 05-17-2019, 06:05 PM   #13
fjn's Avatar
Trade: mason
That is totally besides the point. Why invite it in only to pump it back out ? A pump malfunction,power outage and wham O water filling up inside. Makes absolutely no sense. Keep it outside at all times ....where it belongs !
fjn is offline
Old 05-17-2019, 06:45 PM   #14
General Contractor
greg24k's Avatar
What you basically doing is releasing hydrostatic pressure from the foundation or having the water build up alongside of the wall, this is a system which allows the water enters the sump pump and it pumps the water out to the daylight.
It was designed that way and it works.
Old 05-17-2019, 06:54 PM   #15
fjn's Avatar
Trade: mason
Yeah,it works alright...........until it doesn't as in failed pump,power outage.
An exterior sump pump or better yet,pipes run to daylight (gravity never fails us ) will do all your system will do with none of the risk.
fjn is offline
Old 05-17-2019, 08:19 PM   #16
General Contractor
greg24k's Avatar
Today most people I know have battery back-up pumps, after Sandy and Katrina, people been hooking up generators. battery pumps, etc.
This is a pretty common practice in Jersey for every new built... if you have or believe in a better system or you have a different requirement in your area, you can put exterior pumps, etc whatever works my friend.
Old 05-17-2019, 08:23 PM   #17
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Sump pumps are a necessary evil. I don't know what folks with basements did before sump pumps came along. Bailed after every rain storm I guess.
SmallTownGuy is offline
Old 05-17-2019, 10:10 PM   #18
Trade: Highwayman
Depends on the area.
Here our water table is deep, and terrain in mostly hilly. 2 wells at the ranch are both 125'.
Lots of walkouts. Easy to keep dry with proper damp-proofing, and backfill with good quality drain rock, and filter fabric.
I don't envy you guys building where the water table is a couple feet.
greg24k (05-18-2019), SmallTownGuy (05-18-2019)
Old 05-18-2019, 03:35 AM   #19
General Contractor
greg24k's Avatar
Have to keep the basement floor above the water table min 1'. As you can see in the first picture I posted, I could only go 40" +10" footing because of the high water table.
Seven-Delta-FortyOne (05-18-2019)
Old 05-18-2019, 05:48 AM   #20
John the Builder
yup
If sump pumps were disallowed in the Detroit metro area - well, there would be no basements.
Drain Hell darr1 General Discussion 13 07-25-2012 09:40 AM
French drain Bill General Discussion 12 09-09-2008 12:01 PM
Looted New Orleans Architectural Details Cole General Discussion 2 06-05-2006 04:25 PM
