Cracked Chimney - Masonry - Contractor Talk
Cracked Chimney
Old 01-11-2019, 01:34 PM   #1
Scuba diver's Avatar
Trade: Mason
Cracked Chimney
Hi all
I have recently finished an outdoor fireplace, gas fired. Not sure if the owner is lighting on low or straight to high. This burner is 180000 btu's chimney is red brick with a two coat stucco system. It has precast concrete face(haddonstone product).from top of firebox chimney is 6'tall, cap stones are about 6" above flue liner. Problem occurred shortly after the owner stsrted using it. It cracked from tge face stones to the top. Any ideas on why?
Scuba diver is offline
Old 01-11-2019, 01:45 PM   #2
Trade: Mason
Re: Cracked Chimney
Trying to figure out if ignited on high would crack it, by not allowing the unit to warm up slowly
Old 01-11-2019, 07:22 PM   #3
fjn's Avatar
Trade: mason
Rewards Points: 9,820
Re: Cracked Chimney
Was a 1" air space maintained between flue liner and surrounding masonry ? Flue liners when heated, expand both in width and height. That expansion can exert stresses and crack both the liner and masonry.
fjn is offline
Fouthgeneration (01-12-2019)
Old 01-11-2019, 08:51 PM   #4
Trade: Mason
Re: Cracked Chimney
There was a gap maintained until the last few crs. of brick, i also had not noticed a crack in the liner but will take a closer look
Old 01-12-2019, 05:19 AM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,445
Re: Cracked Chimney
The good news this isn't inside a 500,000.00$ home waiting to cause a fire....
No scaffold needed to tear it apart....
I suggest you find a competent fire place builder to teach you how, for either direct payments or some sort of labor exchange for schooling in safe to use fireplace construction techniques.
Some studying on line and at a library might help some.
Pretty Fire place, Where is the roof to keep it BONE dry?
In Argentina, in the Pampas? ranch land, the out of doors cow cookers/summer time kitchens have ROOFS, but the walls are rolled up tarps, thus allowing the fire places to survive several winters.....
Even a properly built fire place will explode/suffer damage if it is hot fired when wet or damp.
Fouthgeneration is offline
Old 01-18-2019, 05:11 PM   #6
JBM's Avatar
Trade: Masonry
Rewards Points: 6,954
Re: Cracked Chimney
How did you build the smoke chamber, did it have it's own walls behind the outside masonry?
There isn't a damper right?
JBM is offline
Old 01-18-2019, 05:14 PM   #7
JBM's Avatar
Trade: Masonry
Re: Cracked Chimney
I had a small bit of puddling at the joint where the bluestone met the fire brick. A chunk of the bluestone exploded!
JBM is offline
Old Yesterday, 08:58 AM   #8
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
Re: Cracked Chimney
Any angle irons in there which lack room for expansion? It's amazing how much lateral pressure expanding metal can exert... Dampers included.
bytor is offline
Old Yesterday, 07:35 PM   #9
Trade: Masonry
Re: Cracked Chimney
bytor, I'll use some rolled up fiberglass to form a cavity for the steel and iron embeds to grow into , instead of 'jacking' the masonry apart.
the flues need to able to move up to 2" vertically on a 2 story home during a chimney fire.
I like using stainless steel positioners cut out of 18-20 gauge stock that allow the flue to move up and down and grow some what around during fireplace/furnace use.
The flue needs a soft sliding joint around the cap, especially with poured caps, I have repaired several that had the cap elevated by thermal expansion of the flues.
Old Yesterday, 09:22 PM   #10
JBM's Avatar
Trade: Masonry
Re: Cracked Chimney
Another non returning poster, building something wrong...
JBM is offline
Flashing a stone veneer chimney. PatChap Roofing 7 04-02-2013 12:19 PM
joint cracked twice in a week r4r&r Drywall 9 06-29-2012 09:08 PM
Adding a new chimney on an existing house Desdevinc Masonry 7 03-20-2011 11:14 AM
Flue cap GettingBy HVAC 11 02-14-2011 04:46 PM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 08:35 PM
