Contractor Poured Air Entrained For Pole Barn Slab - Masonry - Contractor Talk
Old 07-27-2020, 07:47 PM   #1
Cmed250f's Avatar
Trade: Electrican
Hello everyone and thanks for the ad!....I came to this forum to get your opinions and thoughts on my situation...I recently had a slab poured In my pole building 30x40x6" deep 4000psi....during the pour at after 20 yards were In already my mason realized they sent air entrained when he specified NO AIR because he wanted to do a power trowl finish...instead he bull float and hand trowled it...about two weeks after pour I notice all these spider lines in the floor is this the start of it blistering and going to pop...what should I do any thought opinions are greatly appreciated
Thanks
Cmed250f is offline
Old 07-27-2020, 10:11 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,906
Re: Contractor Poured Air Entrained For Pole Barn Slab
Ask your concrete guy what he intends to about it.
He accepted the load...
There are three things one can guarantee about comcrete:
Its wet coming off the truck...
Its heavy...
Its going to crack...
You may have some leverage since it is not what was ordered...
But why didn't your guy check the ticket...
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (07-27-2020), greg24k (07-29-2020)
Old 07-27-2020, 10:19 PM   #3
Fire up the BBQ
griz's Avatar
Wouldn't be the first time i've concrete jackhammered out because it was the wrong mix design...
griz is online now
Calidecks (07-27-2020), hdavis (07-27-2020)
Old 07-27-2020, 11:20 PM   #4
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,590
Thanks
Lines or cracks?
Big Johnson is online now
Old 07-27-2020, 11:21 PM   #5
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 656
Apply curing compound ASAP.
cdkyle is offline
The Following User Says Thank You to cdkyle For This Useful Post:
hdavis (07-27-2020)
Old 07-27-2020, 11:30 PM   #6
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 618
It will not delaminate unless you hard troweled it and pushed the little air pockets into the slab, just under the surface.
Air-entrained helps with the freeze-thaw cycles.
Andy.
ScipioAfricanus is online now
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
hdavis (07-27-2020)
Old 07-27-2020, 11:41 PM   #7
hdavis's Avatar
Rewards Points: 3,784
Air engrained or not, they can both be finished and cured.
Fine lines all over are most likely with a steel troweled smooth finish, but you get similar lines if it starts drying out before curing. Check with your mason.
hdavis is online now
Old 07-28-2020, 05:55 AM   #8
Cmed250f's Avatar
Trade: Electrican
Thanks for all the feedback guys currently trying to upload pictures but not working any tips for this
Cmed250f is offline
Old 07-28-2020, 05:57 AM   #9
Cmed250f's Avatar
Trade: Electrican
https://linksharing.samsungcloud.com/k3Ni62Tq0rcZ
They arent cracks its lines cannot feel them and looking at saw cut from sides they dont seem to go down
Cmed250f is offline
Old 07-28-2020, 09:34 AM   #10
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,370
I don't think air entrained is the end of the world. I would have gone ahead and smooth trowel finished it.
If the slab is bad, he needs to take it out and replace it to your satisfaction. I suspect something else is going on causing the slab to spider crack and deteriorate, but regardless it needs to be replaced. Hope you haven't paid him.
Fishindude is offline
Old 07-28-2020, 10:32 AM   #11
Cmed250f's Avatar
Trade: Electrican
Finishindude were you able to see the photos I posted here are links to then they sent like physical cracks through the pad just seem like a design on top you cant feel anything when you run your fingernail across it
https://linksharing.samsungcloud.com/6pdymqzQ4S8B
https://linksharing.samsungcloud.com/yWbMGGdMiQUh
Cmed250f is offline
Old 07-28-2020, 10:49 AM   #12
tgeb's Avatar
Rewards Points: 1,258
Looks like shrinkage cracks to me, how wet was the pour?
I hard trowel air entrained concrete all the time.
www.gebcon.com
tgeb is offline
Old 07-28-2020, 12:53 PM   #13
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 536
^^^ x2
How much air was in it?
I order low air (around 2.5%) for my garage floors and they get power troweled without issue.
mrcat is online now
Old 07-28-2020, 01:00 PM   #14
Cmed250f's Avatar
Trade: Electrican
Unfortunately I believe the concrete company said anywhere between 5-7%
Cmed250f is offline
Old 07-28-2020, 01:01 PM   #15
Cmed250f's Avatar
Trade: Electrican
The pour didnt seem to be that wet but it was extreamly hot the day of and days after 90+*
Cmed250f is offline
Old 07-28-2020, 04:09 PM   #16
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,536
You can power trowel air entrained, it's a bitch, but we've done it plenty of times.
You have to wait longer, then get a splashy with the water bucket to prevent peeling.
NYCB is offline
Old 07-28-2020, 04:10 PM   #17
NYCB's Avatar
Originally Posted by mrcat View Post
^^^ x2
I usually specify "no air" for my floors, and of course they still ad air to it, but at a much lower amount. One supplier I use has special mix designs based on application, so they always ask what you are pouring when you order.
I don't pay much attention to the percentages.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
mrcat (07-28-2020)
Old 07-28-2020, 04:12 PM   #18
NYCB's Avatar
If the slab is flat and in otherwise good condition, I would ask him to polish it or find someone that can. Still work, but not as much work as jackhammering and doing it again.
NYCB is offline
Old 07-28-2020, 04:18 PM   #19
Cmed250f's Avatar
Trade: Electrican
Honestly it doesn't matter to me not being being power trowled polished I its sealed and has an abrasive for traction I just wanted to make sure all those small lines arent going to pop and blister at some point
contractor poured air entrained for pole barn slab-20200728_171455_1595970910586.jpg   contractor poured air entrained for pole barn slab-20200728_171257_1595970990166.jpg   contractor poured air entrained for pole barn slab-20200728_171306_1595971025312.jpg
Cmed250f is offline
Old 07-28-2020, 04:40 PM   #20
Cmed250f's Avatar
Trade: Electrican
My dog slopped some water on it and now I noticed how it takes to the " lines" could this just be the sealer surface I used gem cure 1315
contractor poured air entrained for pole barn slab-20200728_173917_1595972373432.jpg
Cmed250f is offline
