Concrete Discoloration - Masonry - Contractor Talk
Old 08-23-2019, 11:47 PM   #1
Wezal15's Avatar
Trade: Low voltage
Rewards Points: 18
My concrete guy poured this back on June 13th. Most bleached out but I have dark spots that still look like this. Is there something wrong or do I need to keep waiting for the dark to bleach out? I’ve seen slight improvement week over week, but only slight. The photo was taken in the evening so the dark areas may show darker than in person.
Concrete discoloration-213d54b2-7649-4ae5-8832-a67106150537_1566621934627.jpeg
Wezal15 is offline
Old 08-24-2019, 12:02 AM   #2
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,808
Re: Concrete Discoloration
Looks like inconsistent base.
Mike.
_______________
Calidecks is online now
Wezal15 (08-25-2019)
Old 08-24-2019, 12:04 AM   #3
GC/carpenter
Calidecks's Avatar
I've also found pouring with 3000 psi helps tremendously with color consistency. More cement makes for a better finish. It's a cream thing.
Mike.
_______________
Old 08-24-2019, 12:15 AM   #4
Wezal15's Avatar
Trade: Low voltage
Rewards Points: 18
It was 3000 psi. Any suggestions to fix or will that come with time?
Wezal15 is offline
Old 08-24-2019, 09:24 AM   #5
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,760
Well, it wont stay that dark forever, but it probably won't even out the way you want. Is there plastic under it?
jhark123 is offline
The Following User Says Thank You to jhark123 For This Useful Post:
Old 08-24-2019, 10:13 AM   #6
Wezal15's Avatar
Trade: Low voltage
Rewards Points: 18
No plastic underneath
Wezal15 is offline
Old 08-24-2019, 11:23 AM   #7
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Was it troweled with a power trowel ? If you put a real hard finish on with a machine,you can actually turn the entire finish gun metal blue.
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
griz (08-24-2019), Wezal15 (08-25-2019)
Old 08-24-2019, 04:17 PM   #8
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 682
Is it a hard troweled finish? Looks like it got burned in those spots, but I've never seen one get burned so splotchy like that.
I try to get most of my floors that blued steel color, but typically it all goes at around the same time.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
Old 08-24-2019, 04:19 PM   #9
NYCB's Avatar
Rewards Points: 682
Mike.
_______________
4000 is my favorite, lots of cream to work with, but not so much that the load is unpredictable in how fast is is going to get warm on you.
NYCB is offline
Calidecks (08-24-2019)
Old 08-24-2019, 11:29 PM   #10
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,383
Really poor sealer job....
Form oil spillage from raise elevation form work??
Was higher island poured after stained portion?
Contaminated concrete?
dirty hose water, hard water stain...
Water soluble contamination under slab...
Oiled rebars/ mesh?
oily finish tools, leaky two stroke gas tank....
Vandalism. Or enemy action?
Dirty blankets? burlap?
Contaminated garden sprayer tank used for sealer with out clean out of stain or other chemical(s).
Hydraulic oil spill from "cement" truck....over oiled concrete buggies/wheelbarrows. Spill at concrete plant/ quarry. Rock truck...
Buy the foremen a case of Beer and ask WTF happened to my concrete?????
Fouthgeneration is offline
The Following 3 Users Say Thank You to Fouthgeneration For This Useful Post:
griz (08-25-2019), SmallTownGuy (08-25-2019), Wezal15 (08-25-2019)
Old 08-25-2019, 02:46 AM   #11
Wezal15's Avatar
Trade: Low voltage
Rewards Points: 18
It’s broom finish
Wezal15 is offline
Old 08-25-2019, 02:52 AM   #12
Wezal15's Avatar
Trade: Low voltage
Rewards Points: 18
Oiled rebars/ mesh?
Contaminated garden sprayer tank used for sealer with out clean out of stain or other chemical(s).<img src="http://img.contractortalk.com/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" />
Buy the foremen a case of Beer and ask WTF happened to my concrete?????<img src="http://img.contractortalk.com/smilies/icon_wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Sounds like there are many variables to consider.
It was all poured the same time, the raised pad is fine. It had some minor blotching but pretty much has faded completely away. The larger areas are what scare me. In those, there has been some fading away/bleach out, but slowly. My guy says it happens sometimes and I just have to give it time but 60+ days? I’m not sure if I just be patient and what happens or what to do next?
Wezal15 is offline
Old 08-25-2019, 09:04 AM   #13
NYCB's Avatar
Rewards Points: 682
Originally Posted by Wezal15 View Post
Itís broom finish
Like was said above, did form oil get spilled all over it?
I've never seen discoloration like that on concrete that hasn't been burned, except when contaminated with something.
NYCB is offline
The Following 3 Users Say Thank You to NYCB For This Useful Post:
Fouthgeneration (08-25-2019), jomama (08-26-2019), Wezal15 (08-25-2019)
Old 08-25-2019, 09:09 AM   #14
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
....My guy says it happens sometimes and I just have to give it time but 60+ days? Iím not sure if I just be patient and what happens or what to do next?
Why? WTF do you think is going to happen?
Are you expecting giant lizard creatures to jump out of it?
SmallTownGuy is offline
Old 08-25-2019, 09:32 AM   #15
Wezal15's Avatar
Trade: Low voltage
Rewards Points: 18
It’s broom finish
Not that I’m aware of.
Wezal15 is offline
Old 08-25-2019, 09:35 AM   #16
Wezal15's Avatar
Trade: Low voltage
Rewards Points: 18
....My guy says it happens sometimes and I just have to give it time but 60+ days? I’m not sure if I just be patient and what happens or what to do next?
I’m hoping it bleaches out and doesn’t look like crap. Posted seeking help for a root cause and a solution to have this fixed and look normal if it won’t just heal with time. If giant lizards pooped out of it that would be interesting &#x1f602;
Wezal15 is offline
Old 08-25-2019, 09:43 AM   #17
John the Builder
Iím hoping it bleaches out and doesnít look like crap. Posted seeking help for a root cause and a solution to have this fixed and look normal if it wonít just heal with time. If giant lizards pooped out of it that would be interesting &#x1f602;
It's **** ing concrete. There's nothing to "heal".
You talk like a DIY homeowner. I will treat you as one.
Old 08-25-2019, 10:06 AM   #18
Wezal15's Avatar
Trade: Low voltage
Rewards Points: 18
It’s ****ing concrete with dark spots that I’m looking for root causes and solutions to address. Not that you contributed to that but no need to be a jerk.
Wezal15 is offline
Old 08-25-2019, 03:02 PM   #19
Caleb1989's Avatar
Rewards Points: 368
Howís the slope on that slab? If it was wetted down right after pour and the water puddled for awhile, thatís a common reason for discoloration.
Caleb1989 is offline
The Following 2 Users Say Thank You to Caleb1989 For This Useful Post:
Fouthgeneration (08-25-2019), Wezal15 (08-26-2019)
Old 08-26-2019, 05:24 AM   #20
builditguy's Avatar
Rewards Points: 1,958
I was called to look at one, similar to this. It was poured about a year ago. There is a little white, but mostly still dark blue. It has a burned finish.
It's a garage floor.
In that case, I suspect a hot load of concrete. They got the concrete from a plant, at least an hour away, by car. I'll bet that concrete was in the truck for 1 1/2 hours, before pouring.
The floor also has stress cracks around the perimeter. A crack runs toward the center, only about 8", but the cracks are less than 12" apart. That's alot of cracks.
It should have been white, by now.
So, having said all of that, is there a chance the load was hot.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
