Concrete Counter Tops - Page 2 - Masonry - Contractor Talk
Old 02-23-2014, 05:11 PM   #21
CarpenterSFO's Avatar
Rewards Points: 2,044
Re: Concrete Counter Tops
Originally Posted by Texas Wax View Post
Play with a couple of small mock ups. You'll get a good feel fast for how and what's going on.
Very good advice.
- Bob
CarpenterSFO is offline
Old 02-23-2014, 06:52 PM   #22
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Originally Posted by CENTERLINE MV
I was looking at some from a different company, but thanks
jlsconstruction is offline
Old 02-23-2014, 07:06 PM   #23
Originally Posted by jlsconstruction View Post
I'm going to be remodeling 2 kitchens in a duplex I own. I've never done concrete tops, but would like to try it on one of my own houses first. Is there anything I should know before starting? What is involved in upkeep with them? Good idea or bad?
When you're done you'll realize why a good concrete top should cost as much as any other top.
- Bob
The Following User Says Thank You to CarpenterSFO For This Useful Post:
overanalyze (02-23-2014)
Old 02-23-2014, 07:19 PM   #24
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 704
If not more depending on how detailed and unique they want the pour.
overanalyze is online now
CarpenterSFO (02-23-2014)
Old 02-24-2014, 04:53 AM   #25
Knows less all the time
Fundi's Avatar
Trade: Brick Contractor, Manufacturer
Rewards Points: 580
And post how it went, even if it didnt go so well. About /----/ that close to trying myself.
Fundi is offline
Old 02-24-2014, 09:50 PM   #26
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Need at leadt 5000 psi. For water resistance. I did an out door table with 5000 psi kwikcrete and a super plasticiser /water reducer. It came out very hard.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
The Following User Says Thank You to CJKarl For This Useful Post:
Tom Struble (04-15-2014)
Old 02-24-2014, 09:57 PM   #27
CJKarl's Avatar
Trade: Masonry
If you search back I may have stated what sealer I used. Food grade supposed to fill the microscopic pores of the crete. I then put on a layer of Carnuba wax.
CJKarl is offline
Old 02-24-2014, 10:11 PM   #28
VinylHanger's Avatar
Rewards Points: 10,306
Yep. Please post pics if you go for it. I'm thinking this will be what we will do as well.
VinylHanger is offline
Old 02-24-2014, 10:14 PM   #29
stacker of sticks
Rewards Points: 590
I will, plumbers and sparkys will be here wednesday and Thursday. So hopefully I'll have some time to mess around with it then
The Following User Says Thank You to jlsconstruction For This Useful Post:
VinylHanger (02-28-2014)
Old 02-27-2014, 04:16 PM   #30
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
One thing I notice a lot of people do when starting out with concrete is they dont let it mix long enough. It needs time to hydrate while in the mixer.
I will mix mine for a minimum of 5 minutes after the last bag is in, usually around 7, let it sit for another 5-7, then spit it slowly for another few minutes. If you mix fast and dump right away you will get a lot of bleed water and be there all day troweling, or if you pour pre cast tops, you will have water all along the top, and you could get water staining once you flip them.
Remember to vibrate them well. I usually would put my forms up on blcoks of 2" foam so I could get my vibrator under the form and hit them good. It really cuts down on the bug holes.
You will have to slurry the top once for sure I would think. I mix my cement with acrylic. It hardens faster, sticks better, and doesnt shrink as much.
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
The Following User Says Thank You to 6stringmason For This Useful Post:
overanalyze (02-27-2014)
Old 02-27-2014, 08:00 PM   #31
Kent Whitten's Avatar
Rewards Points: 2,040
Is the acrylic the binder? I'm not fully sure of the terminology. I have a local guy I know who does some really nice tops. He said there was a binder(?) for sticking the cement to the crushed glass (in his case) or sticking everything together. I'm trying to recall the percentages he stated. Along the line of 85% recycled material? Does that sound right? Is it a recipe of cement, aggregate, water and binder? I'm interested as well. It's certainly interesting. Where do you get the coloring for it? Is it organic dyes?
SalmonFallsCabinetry.com
Kent Whitten is offline
The Following User Says Thank You to Kent Whitten For This Useful Post:
Old 04-14-2014, 12:03 PM   #32
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,278
Did some body ring? Is this post still in the works or is it over and done with?
madrina is offline
Old 04-14-2014, 03:56 PM   #33
stacker of sticks
Rewards Points: 590
I haven't had time yet. Every time I think I'll have a few days to play with it something comes up
Old 04-15-2014, 06:29 PM   #34
madrina's Avatar
What are the counters now? Laminate?
madrina is offline
Old 04-15-2014, 07:30 PM   #35
stacker of sticks
Rewards Points: 590
Nothing, cabs aren't installed yet
Old 04-15-2014, 08:44 PM   #36
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
that was a work of art..had those glow stones right?
Tom Struble is offline
Old 04-22-2014, 05:41 PM   #37
madrina's Avatar
Is the food grade acrylic sealer that fills microscopic holes the same thing as a densifier?
madrina is offline
Old 04-23-2014, 03:10 AM   #38
CJKarl's Avatar
Trade: Masonry
I bought all my chemicals from these guys. Good prices and VERY helpful over the phone.
http://www.concretecountertopsupply....ef=MixProducts
CJKarl is offline
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 12:25 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
TYPARŪ Flashing BA - under a concrete floor?? AmeliaP Masonry 5 07-27-2012 04:08 AM
