Concrete Counter Tops - Masonry - Contractor Talk
Old 02-22-2014, 08:19 PM   #1
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I'm going to be remodeling 2 kitchens in a duplex I own. I've never done concrete tops, but would like to try it on one of my own houses first. Is there anything I should know before starting? What is involved in upkeep with them? Good idea or bad?
jlsconstruction is offline
Old 02-22-2014, 09:19 PM   #2
Valley Springs,ca
bmartin's Avatar
Trade: General and Landscape contractor
Rewards Points: 121
Re: Concrete Counter Tops
I've had them for about 7 years in my house. I like them and they have been pretty durable. Mine are acid stained and I seal them with a tile and granite sealer and they still look pretty good. I have to be careful of citrus juice on the counters because it cuts thru the sealer.
bmartin is offline
The Following User Says Thank You to bmartin For This Useful Post:
jlsconstruction (02-22-2014)
Old 02-22-2014, 09:58 PM   #3
hdavis's Avatar
Rewards Points: 1,556
Ask Madrina.
hdavis is offline
Old 02-22-2014, 11:17 PM   #4
duburban's Avatar
Trade: building
Rewards Points: 1,764
it all depends on what your expectations are. they will stain, no question about it. if you slop on some sort of high tech urethane they won't stain for a while… but then when that fails you'll be refinishing a car in your kitchen. the alternative, a sealer as mentioned above or any option won't give you great protection. learn to live with the stains and accept the patina, just like copper. its totally possible to set down a glass and have a water ring stay for a short time or long time.
duburban is offline
The Following 2 Users Say Thank You to duburban For This Useful Post:
jlsconstruction (02-22-2014), overanalyze (02-23-2014)
Old 02-22-2014, 11:41 PM   #5
Texas Wax's Avatar
Rewards Points: 1,946
Originally Posted by hdavis View Post
Ask Madrina.
Gel Coat kind of defeats the purpose and look of concrete
Texas Wax is online now
The Following User Says Thank You to Texas Wax For This Useful Post:
CarpenterSFO (02-23-2014)
Old 02-22-2014, 11:47 PM   #6
Dan_Watson's Avatar
Rewards Points: 2,748
Ive done a few...sealer every other year and your good. same as granite with the right product.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
Old 02-22-2014, 11:50 PM   #7
stacker of sticks
Rewards Points: 590
I think I'm going to make a few for the bathrooms and see how it goes.
The Following User Says Thank You to jlsconstruction For This Useful Post:
Old 02-23-2014, 12:01 AM   #8
duburban's Avatar
Trade: building
good call. the world of boutique concrete mixes is crazy. if your going to go some sort of bag mix run quikrete 5000 with extra cement. makes a decent mix, really straight forward.
duburban is offline
The Following User Says Thank You to duburban For This Useful Post:
jlsconstruction (02-23-2014)
Old 02-23-2014, 10:18 AM   #9
Dan_Watson's Avatar
I mixed my own, played with GFRC for the last one. It was WAY cheaper to make my own mix than by a prebagged.
Old 02-23-2014, 10:59 AM   #10
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,134
You have to decide if you are going to pre-cast or pour in place. I prefer pre-cast. Your form work needs to be precise. If its in the form, it will be in your top. For your first couple pours, try the Cheng admix. It's fairly inexpensive and uses stock bag mix. It will get you started. if you like it, start experimenting with your own recipe. There is a lot of info out there on good mixes with high psi and flexural strength. Don't go thinner than 1-1/2".
overanalyze is online now
Old 02-23-2014, 11:01 AM   #11
Dan_Watson's Avatar
Depends on the mix and if fiber is added. I have a table top thats only about 3/8" thick with no issues.
I made a table for a competition that was also no more than 3/8". Left outside for years, it was good until a tree fell on it....
Old 02-23-2014, 11:09 AM   #12
Dan_Watson's Avatar
Old 02-23-2014, 11:15 AM   #13
Always Learning
I totally agree you can do thinner, but for a first top, I wouldn't recommend it. I love that fire top Dan! Very cool!
Old 02-23-2014, 11:19 AM   #14
Dan_Watson's Avatar
Gotchya.
It was awesome. I wish I had a place to use it. I lost that one, so when it comes time to have my own outdoor space I will make another. I want to come up with a way of doing some BBQ or cooking right there. Maybe a rack or even a small spit. Sit around the table, drink and cook up some kabobs.
Old 02-23-2014, 11:25 AM   #15
stacker of sticks
Rewards Points: 590
It will be pre cast, I don't trust myself enough to do it on top of new cabinets
Old 02-23-2014, 11:30 AM   #16
Always Learning
For the ultimate easy vanity top, plan on a vessel sink. The only two things you will need to form in place will be the faucet hole and the vessel drain hole.
Old 02-23-2014, 12:19 PM   #17
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 610
For some inspiration, my counter guy:
https://www.facebook.com/pages/The-M...t/206596160294
Golden view is online now
The Following 6 Users Say Thank You to Golden view For This Useful Post:
CENTERLINE MV (02-23-2014), Dan_Watson (02-23-2014), jlsconstruction (02-23-2014), overanalyze (02-23-2014), Texas Wax (02-23-2014), VinylHanger (02-24-2014)
Old 02-23-2014, 01:12 PM   #18
Texas Wax's Avatar
I agree.
Faucet hole, home despot has diamond hole saws, goes right through concrete with out aggregate... Like hit the staples Easy button, easy. Almost harder to form the hole in place
Play with a couple of small mock ups. You'll get a good feel fast for how and what's going on.
Old 02-23-2014, 03:27 PM   #19
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
These might interest you JLS:
http://concretecountertopsolutions.c...edge-profiles/
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 02-23-2014, 05:11 PM   #20
CarpenterSFO's Avatar
Rewards Points: 2,044
For admix, try the Sika "Ultimate Fortifier" (not the acrylic stuff). It's available at Home Depot; it's the same animal as the Cheng super-plasticizer/water reducer, at about 1/10th the unit price, and available right away. It will turn a stiff mix into a flowable one, or an impossibly stiff mix into an easily workable one, and make a very strong and hard top. The drawback is that if you mess up, breaking up that 400-lb behemoth will require a saw, because a sledge will just bounce off.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 12:25 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
TYPARŪ Flashing BA - under a concrete floor?? AmeliaP Masonry 5 07-27-2012 04:08 AM
