Column Design - Masonry - Contractor Talk
Column Design
Old 07-04-2015, 06:00 AM   #1
Stone's Avatar
Trade: Stone Mason and Sculptor
Rewards Points: 93
Column Design
I have been asked to build something similar to what is in this picture at a private residence. I have some ideas on how to build the columns but I would appreciate some input from some of the knowledgeable people on this forum and I may in the end hire an engineer anyway. Obviously a lot could go wrong if not done right. By the way, the piece in the picture was built in 1991 and still looks fine. Thanks.
Stone is offline
Old 07-04-2015, 06:08 AM   #2
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Re: Column Design
Let engineer design and put his stamp on that! Don't know who or why but to each is own. That hurts my eyes.
heavyc is offline
Old 07-04-2015, 06:21 AM   #3
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Re: Column Design
Looks like whomever wanted it really didn't in the end. The side walk/entry way is almost covered by the greenery. I know I wouldn't ever open that gate myself?
heavyc is offline
The Following User Says Thank You to heavyc For This Useful Post:
fjn (07-04-2015)
Old 07-04-2015, 06:31 AM   #4
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
Re: Column Design
I would think those columns are poured reinforced concrete with a veneer shelf and those "cap" stones are set with anchors. Personally, I agree with heavy...they are nasty looking things.
www.thewoodfiredenthusiast.com
stonecutter is offline
The Following 2 Users Say Thank You to stonecutter For This Useful Post:
brickhook (07-05-2015), dom-mas (07-04-2015)
Old 07-04-2015, 06:52 AM   #5
Stone's Avatar
Rewards Points: 93
Re: Column Design
This is an old public art project and I am not a fan myself, but the client is. I hope to make something more aesthetically pleasing. I am trying to talk the client into something like in this picture but he really likes the original design but with more refined stonework.
Stone is offline
Old 07-04-2015, 07:00 AM   #6
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Re: Column Design
I'd tell your client to stand under that right column behind that gate might as well be a fence. Then open and shut the gate as he looks straight up at that accident waiting to happen over his/her head. I don't know how much longer prayers are gonna hold that knife shaped large stone up. Can't even see mortar in there? That would be the right side as facing the picture in the thread start.
heavyc is offline
Old 07-04-2015, 07:41 AM   #7
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Re: Column Design
I would walk if they really wanted sh!t that could fall and kill someone. Its just moronic.
JBM is offline
The Following 2 Users Say Thank You to JBM For This Useful Post:
brickhook (07-05-2015), fjn (07-04-2015)
Old 07-04-2015, 08:06 AM   #8
Stone's Avatar
Rewards Points: 93
Re: Column Design
I can build anything if it engineered right and I wouldn't do it if safety was an issue. Oh, one last thing before I leave for the day: To add to the logistical difficulties of this project, it is on an island, and everything would have to be ferried over.
Stone is offline
Old 07-04-2015, 08:23 AM   #9
Trade: Stonemasonry
Re: Column Design
Originally Posted by Stone View Post
.....it is on an island, and everything would have to be ferried over.
Old 07-04-2015, 09:38 AM   #10
S.U.M's Avatar
Trade: Brick/Stone Mason
Rewards Points: 1,286
Re: Column Design
Horrible looking thing. You will get more people avoiding it than admiring it.
S.U.M is offline
The Following User Says Thank You to S.U.M For This Useful Post:
fjn (07-04-2015)
Old 07-04-2015, 10:37 AM   #11
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Re: Column Design
Sounds like Michigan maybe Lake Huron?
heavyc is offline
SmallTownGuy (07-05-2015)
Old 07-04-2015, 10:51 AM   #12
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Column Design
Like Bob Dylan said in one of his songs "it looks like a mattress balanced on a bottle of wine".
fjn is offline
Old 07-04-2015, 04:03 PM   #13
Accent Masonry LLC
Gordon Forsyth's Avatar
Trade: Masonry
Rewards Points: 330
Re: Column Design
Everything has a fulcrum point, which is the point at which weight is equally balanced on both ends. I would suggest setting up something approximately the size that the top of the columns will be on the ground, possibly out of wood or brick, and marking out the point at which it is balanced. Definitely drill in and epoxy steel rods and set stone in a thin set mortar mixture. As for the columns 24"x24" reinforced with steel footers (minimum size varies by state and architectural design but should be at least as wide as the stone your trying to balance) with either steel reinforced formed concrete or 8"x8" concrete block with a stone veneer. However I would never attempt something like this in any area prone to earthquakes or extreme climate changes, and would have something written up clearing me of any liability. Hope this helps
Southwest Florida Masonry Contractor
Glass Block, Brick & Stone
http://www.accentmasonryllc.co
Gordon Forsyth is offline
Old 07-04-2015, 04:16 PM   #14
CarpenterSFO's Avatar
Rewards Points: 2,044
Re: Column Design
The columns are especially bad.
- Bob
CarpenterSFO is offline
Old 07-04-2015, 06:29 PM   #15
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Column Design
Agreed 100% with stonecutter and Gordon. The stone on those columns is adhered to what is most likely poured concrete. there is then most likely a good deal of heavy threaded rod epoxied into those stones on top. 3 pieces of 1" threaded rod (stainless) minimum per cap I'd say
I think they are among the ugliest things I've seen and the masonry is of the poorest quality but I'm not the end user. I build what the customer wants, not what I want.
Hire an engineer, none of us are going to stamp anything
www.dominionmasonry.ca
dom-mas is offline
Old 07-05-2015, 06:32 AM   #16
Stone's Avatar
Rewards Points: 93
Re: Column Design
Good guess but actually one of the Lake Erie islands. If I do it the columns will be reinforced concrete as you guys described and everything pinned and epoxied, and I have decided to insist on an engineer signing off on it based on the responses.
The finished project will look similar but I hope a whole lot different with my spin on it. I am a stone sculptor besides being a mason and I get to do some weird fun stuff occasionally that may not be to everyone's taste. It is interesting how much some of you dislike the original project. I will post a picture of my version if it comes to fruition.
Stone is offline
Old 07-05-2015, 06:43 AM   #17
S.U.M's Avatar
Re: Column Design
Good luck with this, keep us posted.
S.U.M is offline
Old 07-05-2015, 07:56 AM   #18
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Re: Column Design
I grew up on Lake Erie. And fish it regularly when I return to visit. That opens a debacle of obstacles. Lake-effect winds, bitter cold temps, snow and the list goes on. The footing hurdle I would guess will be tough? Maybe the freeze zone isn't as deep with the island factor?
heavyc is offline
Old 07-05-2015, 07:59 AM   #19
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
Re: Column Design
Even if it was engineered, and could be built safely, I wouldn't want my name on something so dang ugly
brickhook is offline
The Following User Says Thank You to brickhook For This Useful Post:
Kniggit (07-05-2015)
Old 07-05-2015, 08:06 AM   #20
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Re: Column Design
Horrendous, hideous and horrifying!
Why couldn't you just propose a nice graceful arch and call it a day...
Sometimes simple is better!
supersealconstruction.com
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
Fundi (07-08-2015), slowsol (07-05-2015)
Design programs Kent Whitten Drafting & CAD Forum 72 04-24-2016 02:38 PM
New deck design, ideas, suggestions to look at... WS6Fury Decks & Fencing 3 08-20-2011 01:21 PM
Tile and Stone Technical Design manuals opiethetileman Tiling 4 05-03-2011 07:59 PM
Design Presentation - Going to Virtual fakie99 Marketing & Sales 6 01-22-2009 08:21 AM
Free Download: Advanced Energy Design Guide Ed the Roofer Roofing 0 02-09-2008 09:01 PM
