Changing Out Existing Garage Door Lintel In Natural Stone Wall - Masonry - Contractor Talk
Thread Tools
Old 06-24-2017, 02:00 PM
feliped's Avatar
Trade: Masonry
Rewards Points: 4
Got a lintel that is around 17 foot long on a natural flagstone wall that we need to switch out because it is undersized. The issue we have is that the new flashing detail requires us to go up 18" above the lintel. Being irregular shaped stone does anyone have a suggestion of how to temporary support the wall while removing the lintel/stone above?
Here is a picture http://imgur.com/a/r2LVc
Thanks for the help/suggestions.
feliped is offline
Old 06-24-2017, 02:32 PM
Tscarborough's Avatar
Rewards Points: 1,460
Re: Changing Out Existing Garage Door Lintel In Natural Stone Wall
Remove it.
Tscarborough is offline
Old 06-24-2017, 02:42 PM
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,436
What a pain!
Usually i punch a hole all the way through and shove a beam through but that probably won't work there due to not having enough height inside the garage.
I wouldn't trust taking the steel out without supporting the irregular stone in some way
Maybe some one else has a better idea but maybe punch a hole and find the wood header and resting shoring on there?
Here is a job i did a while back adding an opening to a solid masonry wall but there was plenty of head room for shoring
Windycity is online now
The Following 6 Users Say Thank You to Windycity For This Useful Post:
fjn (06-24-2017), Philament (06-24-2017), Rio (06-24-2017), SmallTownGuy (06-24-2017), stuart45 (06-24-2017), superseal (06-24-2017)
Old 06-24-2017, 03:39 PM
Windycity's Avatar
Trade: Masonry
Originally Posted by Tscarborough View Post
Remove it.
Unfortunately it looks like from the pictures you would have to remove it all the way up!
Old 06-24-2017, 04:16 PM
Sorry for the short reply, I was framing a window earlier. This picture shows the amount of stone that needs to be removed (if it was a solid faced wall, no windows), under the circumstances, you may as well take off the whole face as I assume someone has responsibility for the undersize lintel and will be paying for it.
It looks like new or nearly new construction, but I do not see any sag. What is driving the the refit?
Changing Out Existing Garage Door Lintel in Natural Stone Wall-ziiekkbrev1.jpg
The Following 3 Users Say Thank You to Tscarborough For This Useful Post:
feliped (06-24-2017), fjn (06-24-2017), Kniggit (06-24-2017)
Old 06-24-2017, 04:26 PM
Windycity's Avatar
Trade: Masonry
Yea i dont see any sagging or cracks either. Looks pretty good in the pictures
Old 06-24-2017, 04:34 PM
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,248
These have become more popular in the last few years for propping brickwork, although they are not so good on stonework.
stuart45 is offline
The Following User Says Thank You to stuart45 For This Useful Post:
Old 06-24-2017, 04:53 PM
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Unfortunately,this will not help you with flagstone walls.I 'm pretty handy fabing steel,thought about making some up for myself,especially since there is no distributor in the States. Maybe Stuart knows about this since they come from his country.
fjn is offline
Old 06-24-2017, 05:13 PM
stuart45's Avatar
Trade: Brickwork
With a stone face you can sometimes get some of these strongboys in the beds joints in different places.
https://www.google.co.uk/search?q=st...LivGEDHKMXioM:
The method in your link Fred is possibly not as popular here as the newer one above using a scaffold pole.
As with any job involving propping a large span it's not easy to give really accurate advice when not on site.
stuart45 is offline
Old 06-24-2017, 07:24 PM
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
If it were me I would take a stone out every 2' and bolt the beam into the header like it was supposed to be done.
JBM is offline
Old 06-24-2017, 07:26 PM
JBM's Avatar
Trade: Masonry
Or you could cut an arch above it, lay a header course there like above the opening, let it sit up for a couple weeks, pull out the beam and re do it.
JBM is offline
Old 06-24-2017, 07:28 PM
JBM's Avatar
Trade: Masonry
I zoomed in A LOT and there are no visible cracks, pull a stone and bolt it in imo.
JBM is offline
Old 06-25-2017, 09:04 AM
feliped's Avatar
Trade: Masonry
Rewards Points: 4
They used a piece of flat stock that is way too thin. There is multiple units with this situation. This happened to be one that hasn't cracked - yet.
feliped is offline
Old 06-25-2017, 09:48 AM
stuart45's Avatar
Trade: Brickwork
Have you decided how you are going to prop it yet?
stuart45 is offline
Old 06-25-2017, 03:10 PM
17' calls for at least a 6x4x5/16 with six inch laps.
Old 06-25-2017, 03:54 PM
Windycity's Avatar
Trade: Masonry
Flat stock? Im assuming a 3.5 x3.5 steel lintel as opposed to a 3.5 x 6 lintel? That's usually where they cheat round here. They get away with it as long as they prop it up in the middle with a 2x4 until it dries
Thread Tools
Rate This Thread
Penetrating sealer for natural stone EC Craftsman Masonry 10 05-21-2013 05:54 PM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Garage walls with no ext. sheathing, bedford stone veneer MarktheCarp Insulation 0 08-13-2010 08:19 PM
Drystack stone wall denver 2 Masonry Picture Post 14 12-09-2009 08:47 PM
Bleeding Stone Wall sxdirt Masonry 9 08-11-2008 07:31 PM
