Caulking Removal - Masonry - Contractor Talk
Caulking Removal
Old 12-07-2016, 05:01 PM   #1
windowsonwashington.net
WindowsonWash's Avatar
Trade: Exterior Construction
Rewards Points: 1,178
Caulking Removal
Best combo of tool and chemical to get some old arse caulking (i.e. brittle and stuck on good) off of some otherwise good condition brick.
Need to put on a new pediment and the customer's old one doesn't quite line up with the newbie.
Thanks.
Windows on Washington
WindowsonWash is offline
Old 12-07-2016, 05:09 PM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 156
Re: Caulking Removal
Sorry I only know the manual way - I pull what I can with pliers & painters tool, follow that up with a steel brush or brush mounted on a drill
You may try an acid wash or caulk removal liquid but I would test on a brick that is inconspicuous area first
SLSTech is online now
Old 12-07-2016, 05:16 PM   #3
Thanks.
Recommendations on wire brush? Just a cup style?
Old 12-07-2016, 05:21 PM   #4
Renaissance Man
superseal's Avatar
Rewards Points: 5,840
Sand mold? glazed? Bartex?...etc...what kind of brick and what kind of caulk?
Line pin chisels can be your friend for removing most of the bulk without injuring most brick. Toluene, MEK and and original Goof off will usually take care of the rest.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Metro M & L (12-08-2016)
Old 12-07-2016, 05:31 PM   #5
Renaissance Man
superseal's Avatar
If you're wondering what a line pin is...W.Rose makes the best. You can get them at Krafttool.com.
Old 12-07-2016, 06:23 PM   #6
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Just did a bunch of removal two weeks ago. Was not on face of brick but at expansion joints. Used a Fein multi tool. Danced through the caulk like hot butter on a holiday.
fjn is offline
Old 12-08-2016, 10:51 AM   #7
Thanks guys. I will take a look at those items.
One installer mentioned something that he soaked the brick with and then power washed off to help with the paint and sealant.
Old 12-08-2016, 11:22 AM   #8
fjn's Avatar
Trade: mason
Originally Posted by WindowsonWash View Post
Thanks.
Just a word of caution with wire brush usage; make sure it is stainless or brass,steel will deposit carbon on brick,turning them black. Those deposits are usually harder to remove than the stuff you are trying to remove.
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
SLSTech (12-08-2016), WindowsonWash (12-13-2016)
Old 12-08-2016, 03:50 PM   #9
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,446
Yes I agree! Made that mistake before. I tried using a drill with a wire wheel to make it "easy"
Windycity is online now
Old 12-08-2016, 10:11 PM   #10
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
sometimes freezing with dry ice or liquid nitrogen works wonders, with the correct PPL of course....
Some times new units are cheaper and less different appearing then "cleaned" original units f.u.B.a.r.ed.
Tell the owner the stains are like old tattoos, it shows the building is not as dumb as it used to be......(Patina) for our architectural friends, only if the owner doesn't have some nasty old Tatts drooling over their own skin.
Fouthgeneration is offline
battery powered caulking gun...should I? Philament Tools & Equipment 35 11-30-2015 11:55 AM
Thinset after asbestos removal platinumLLC Tiling 46 04-05-2015 08:04 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
coating removal bassinhunter Pool Construction & Enclosures 0 03-10-2012 12:28 PM
