Can This Shoddy Mortar Job Be Fixed? - Masonry - Contractor Talk
Thread Tools
Old 07-12-2019, 11:02 AM
bhamlegend's Avatar
Trade: GC & Carpenter (Rough/Finish/Millwork)
Rewards Points: 4
I'm responsible for facilities improvements and exterior maintenance at my general contracting firm. Our facility is 100,000 square feet. The office part of it is about to be remodeled in full and expanded, but there's a section of the property that is remaining untouched because it's mostly used for equipment and materials warehousing. However, the exterior of it has some unsightly blemishes that will only look worse when the rest of the facility is updated. The building is 100+ years old, and like the other historic buildings in our area, is red brick. Some years ago (before my time...I'm told it was maybe 10 years ago), a masonry contractor was hired to repair some crumbling mortar and brick on one of the exterior walls. They didn't exactly do a bang up job in my opinion and the opinion of others here. They used pure white mortar not only for the joints but also to fill damaged spots in the actual brick. I'm actually surprised that after 10 years, weather and biological growth haven't reduced the whiteness significantly. Anyway, we have two options:
  1. Paint over the brick, which we don't really want to do because the rest of the businesses in the area have kept the bare red brick look for historical reasons.
  2. Somehow fix the shoddy patch job so that it looks more uniform (like the wall to its right...see picture)
I'd really like to pursue the second option, but if it's something that's going to be super labor intensive with a cost that is an order of magnitude higher than painting, we may have to just paint it. Wanting to know if anyone has had success with any relatively cost-effective methods to achieve this?
Picture here: https://imgur.com/a/jNWgUxT
bhamlegend is offline
Old 07-12-2019, 03:00 PM
Renaissance Man
superseal's Avatar
Rewards Points: 5,840
Re: Can This Shoddy Mortar Job Be Fixed?
Saw-cut and re-point the entire facade...certainly more than a paint job, but would you rather have it done right as opposed to marrying into a lifelong struggle of maintaining a coating which will only harbor more moisture upon failure, (which it eventually will) and promote further decay and potential moisture intrusion?
From my seat here, I'd estimate the work to be in the 25/30K range which would include power washing, dustless saw-cutting and re-point and appropriate breathable penetrating sealer upon cure.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
bhamlegend (07-12-2019)
Old 07-13-2019, 02:52 PM
Tscarborough's Avatar
Rewards Points: 1,460
It looks large enough, and in good enough shape, that you need to get the existing mortar analyzed to find out what it is. Then you can develop a plan to ensure the structural integrity of the building. Painting should be the last option, if considered at all.
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
Fouthgeneration (07-13-2019)
Old 07-13-2019, 07:35 PM
fjn's Avatar
Trade: mason
Rewards Points: 11,202
http://www.oldlouisville.com/circa19...structures.htm
fjn is offline
Old 07-13-2019, 07:41 PM
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,391
A very long life stain? the idea is just to stain mortar mostly....
Might not be any cheaper then repointing...
Since the end of pollution in the USA, in particular the emission of Sulfur being reduce to a tiny fraction of its peak. Masonry walls will Never again be as deeply stained as those from the Pre EPA era ever again.
The smear fest and bright white are very near the bottom of workmanship IMO.
Bight the bullet and hire a full time tuck pointer with a proven history of nearly matching mortar shades and correct strengths, I'd question the judgement of any GC that had such poor work on their Home Plant.
Even a laid off mason next winter with a lift could make quick work of this eyesore
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
bhamlegend (07-15-2019)
Old 07-15-2019, 08:53 AM
bhamlegend's Avatar
Rewards Points: 4
Thanks everyone for the feedback, kind of validates my opinion that this should never be painted. Fourthgeneration, you are right to be weary of a GC that has that kind of workmanship done on their own shop, which is another big reason why I want to correct it. This is as much a branding/perception decision as it is a maintenance decision. I don't know who did the work (I can probably find the invoice if I dig hard enough), but we definitely haven't used them on any of the jobs I've been involved with. We are mostly an interior GC shop specializing in very specific commercial spaces, so we don't run into many projects that require brickmasons, but when we have had to use them I've seen nothing but very high quality workmanship.
Old 07-20-2019, 08:32 PM
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Isn't mortar from the 60 and 70 have the potential of asbestos in it?
I only could see one pic so I don't know what I'm looking at.
JBM is offline
Old 07-20-2019, 08:41 PM
JBM's Avatar
Trade: Masonry
I actually read the post instead of skimming.
The building has lime mortar, large areas should be redone in lime mortar.
Do not paint that EVER. it will trap moisture and rot the mortar.
JBM is offline
Old 08-14-2019, 08:24 PM
Mason52's Avatar
Trade: Masonry
Rewards Points: 84
Agree with the lime rich mortar but, never heard of asbestos in mortar. Back then they used to make their mortar on site and actually slack the lime before mixing it into the cement and sand. Not nearly as much cement in the mix. There are places you can get mortar that matches your mortar much better than the white mortar that was used.
Found this online
First thing you need to do is find a suitable mortar. You can make your own mortar with slaked lime putty and sand by mixing in a 1:3 proportion of lime to sand if you want to be super old school. You donít need any water in the mix, other a slight amount to ďbulkĒ the sand initially.
Usually, itís most efficient to buy a pre-package mortar like Ecologic Mortar from Limeworks.us. They make several different colors and textures to help you find a match for your project, since color matching is so important. You can even send them a sample and have them make you a custom blended mortar that matches yours exactly.
Hope this helps
Good luck
Mason52 is offline
Old 08-15-2019, 04:05 AM
Trade: Masonry
IF the space is heated, it might pay to add a wythe over 2-3" of a foil faced insulation board, air cavity/ rainscreen and the new brick/stone/ veneer, or stucco/dirvit....
Thread Tools
Rate This Thread
