Broken Concrete Lip Freshly Placed - Masonry - Contractor Talk
Old 09-24-2020, 09:59 PM   #1
Astone's Avatar
Rewards Points: 40
Hey hope to get some guidance here. Formed a concrete patio and added a lip detail that stone veneer will tuck up under and I will duplicate the detail on a stair set.
My mistake was stripping too early. I cracked a bit of the lip off.
I plan to epoxy the pieces back on. They broke off in 2 big chunks. My question is do I do this now (green concrete) or wait till it’s set up a bit.
Or does anybody else have any ideas?
Broken concrete lip freshly placed-679bb895-17de-4fe4-94c4-d0688bdef7df_1601002742286.jpeg
Astone is offline
Old 09-25-2020, 09:28 AM   #2
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,410
Re: Broken Concrete Lip Freshly Placed
I think getting that piece to hold in place long term would be a real long shot, no matter how you do it.
Fishindude is offline
The Following 2 Users Say Thank You to Fishindude For This Useful Post:
greg24k (09-29-2020), griz (09-25-2020)
Old 09-25-2020, 01:31 PM   #3
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,600
I would probably grind out with nice straight lines that bottom piece and pour a patch right in place with some #3 bar drilled in.
You probably should have had a piece of bar in there originally.
NYCB is offline
Old 09-25-2020, 10:05 PM   #4
Astone's Avatar
Rewards Points: 40
Would have but the lower lip is only 2” thick. Bar is in the upper part of it, but not enough room in lower....
Next time I’ll use rigid foam I can just jack out for the embedded part of form
Astone is offline
Old 09-25-2020, 11:11 PM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,941
Is that a trapped sheet of plywood under the slab......
Eliminate the "pocket" , use a formed drip or install a stainless steel hemmed drip edge instead......
lay the faux stone..... then pour over last inch or so
Fouthgeneration is online now
Old 09-25-2020, 11:45 PM   #6
Astone's Avatar
Rewards Points: 40
Originally Posted by Fouthgeneration View Post
Is that a trapped sheet of plywood under the slab......<img src="http://img.contractortalk.com/smilies/sad.gif" border="0" alt="" title="Sad" class="inlineimg" />
It’s a deck framed with a slope. 2 ply torch on roofing applied over that. 4” slab poured on top of torch on.
The point of the pocket was to allow the torch on to freely drain, even though the bulk water will flow off the concrete. There is a drip edge at the face of the torch on, there will be a counter flashing under the drip edge that will cover the top of the stone. Stone will tuck up into the pocket.
Sort of confused what you mean by forming a drip? You mean in the bottom edge of the slab itself? The detail in the slab is designed to be the same as the risers/treads in the future formed stairs leading to this patio
Astone is offline
Old 09-27-2020, 07:53 PM   #7
tgeb's Avatar
Rewards Points: 22
I think that if you epoxy and pin it somehow it will stand up for quite sometime.
I have never seen a texture like that.
How do you do that and make it so uniform?
It looks like a pea gravel mix plus dye, there must be more that you do to get that look.
To your original post, I would wait a bit before attempting the repair, a couple weeks to get the concrete up to strength.
www.gebcon.com
tgeb is online now
The Following 3 Users Say Thank You to tgeb For This Useful Post:
Calidecks (09-28-2020), Fouthgeneration (09-30-2020), TheConstruct (09-27-2020)
Old 09-28-2020, 02:04 PM   #8
Half-fast Eddie's Avatar
Trade: Commercial project management
Rewards Points: 226
I would wait as long as possibly, up to about 30 days. Two reasons: concrete strength and moisture bleed-off. Then i would epoxy, possibly with some 1/4” brass dowels. Might try to drill the dowel holes now while the strength is lower.
Half-fast Eddie is online now
Old 09-28-2020, 06:09 PM   #9
rustyjames's Avatar
Rewards Points: 26
I "glued" a concrete birdbath that was split in half with PL Premium. Figured there was nothing to loose. That was about 4 years ago and it still holds water. No fancy prep work, dowels, etc. Just gave both pieces a heavy dose, clamped it for a few days and trimmed what oozed out after it hardened.
rustyjames is online now
The Following 3 Users Say Thank You to rustyjames For This Useful Post:
Fouthgeneration (09-30-2020), greg24k (09-29-2020), TheConstruct (09-28-2020)
Old 09-28-2020, 06:17 PM   #10
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 666
Looks like.....Trying to do too much with too little.
Looks like.....That rubber man made synthetic expansion joint material.
Waiting for....."Tear it out and re-do it."
cdkyle is online now
Old 09-28-2020, 07:13 PM   #11
NYCB's Avatar
I once had the rear view mirror fall off our car windshield. I went and bought the kit from the auto parts place to fix it, fell off again.
The next time I use PL and just held it on with duct tape until it cured. It stayed on for 3 years and was still going strong when we sold the car.
That stuff is great.
NYCB is offline
Old 09-28-2020, 08:15 PM   #12
rustyjames's Avatar
Rewards Points: 26
It's impressed me more than once. And it's cheap.
Old 09-28-2020, 08:39 PM   #13
Fire up the BBQ
griz's Avatar
Rewards Points: 18
The wild card here is if the owner will accept the patch job.
griz is online now
The Following 5 Users Say Thank You to griz For This Useful Post:
greg24k (09-29-2020), KAP (09-29-2020), rustyjames (09-29-2020), tgeb (09-29-2020), TheConstruct (09-28-2020)
Old 09-29-2020, 09:05 AM   #14
rustyjames's Avatar
Rewards Points: 26
Another product that I would be confident as a permant repair is PC7 epoxy. And it would be a closer match. I've used this stuff for many years and it has never failed.
