Brick Removal For New Window Thread - Masonry - Contractor Talk
Old 10-16-2014, 08:32 PM   #1
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
I didnt get a chance to comment on that thread before it got closed, but I was wondering about the angle iron over arched windows.
I've never seen anyone in this area use angle irons over arched windows before. Isnt the arch itself enough to hold the weight of the brick? Obviously one would flash it properly and make a form to lay your brick, but the angle iron use has me confused.
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 10-16-2014, 08:46 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 5,816
Re: Brick Removal For New Window Thread
There no steel in there - it's a self supporting segmental arch. There are occasions and applications where custom form lintels are used in, but I'd highly doubt that's the case here.
A good arch will outlast a steel lintel any day of the week.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
dom-mas (10-19-2014)
Old 10-16-2014, 08:49 PM   #3
Renaissance Man
superseal's Avatar
Or do you mean flat angles above the arch - that's more likely if there's some super imposed load perhaps.
Old 10-16-2014, 08:50 PM   #4
Renaissance Man
superseal's Avatar
This just looks like veneer work to me...
Old 10-17-2014, 05:38 AM   #5
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,172
There are lintels designed for arches with brick/cavity/block walls that also solve the flashing problem.
http://www.catnic.com/semi_circular_arch.aspx
stuart45 is online now
Old 10-17-2014, 06:27 AM   #6
Smarter than the brick...
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
Form? Don't need no stinking form... we just put a 2x4 across the gap and stack up brick on it and use the window for the form.
Edit: And no, we would never put an angle iron in something like that.
Kniggit is offline
The Following User Says Thank You to Kniggit For This Useful Post:
Bigbricklayer (10-20-2014)
Old 10-17-2014, 07:30 AM   #7
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 166
We don't use steel here either, just a temporary plywood form.
The only steel I've seen used for arches is something like this:
http://www.speedarch.com/home.html
jomama is offline
Old 10-17-2014, 08:31 AM   #8
Tscarborough's Avatar
Rewards Points: 1,456
I mis-understood what he was doing, I thought he was removing the top window and replacing it with an arched one, that is why I mentioned the angle iron.
That said, there are applications for arched angle irons, and they are pretty common around here.
Tscarborough is offline
Old 10-17-2014, 08:42 AM   #9
Trade: masonry
Originally Posted by Tscarborough
I mis-understood what he was doing, I thought he was removing the top window and replacing it with an arched one, that is why I mentioned the angle iron. That said, there are applications for arched angle irons, and they are pretty common around here.
Ahh that clears it up.
Visit our website @
Old 10-17-2014, 06:49 PM   #10
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
missed that one i guess
www.dominionmasonry.ca
dom-mas is offline
Old 10-18-2014, 09:46 PM   #11
fjn's Avatar
Trade: mason
Rewards Points: 10,678
A method used in the days of mass wall masonry to deal with super imposed loads was often to use a relieving arch above the arched opening.
https://www.google.com/search?q=reli...w=1366&bih=600
fjn is offline
Pref fab brick panel questions charlie lazor General Discussion 8 04-23-2015 09:22 AM
Leaking window MEL Masonry 33 02-03-2013 09:12 AM
First RRP window job today, full units ApgarNJ Lead RRP Discussion 59 01-24-2011 09:09 PM
something for the masonry department dakzaag Masonry 2 05-08-2009 09:23 PM
