Brick Chimney To Wooden Chase Questions - Masonry - Contractor Talk
Old 04-23-2019, 08:20 AM   #1
burch's Avatar
Trade: Roofing
Rewards Points: 14
The top 3rd of my chimney (mostly above roof line) has bad spalling and needs repaired. I can do about any type of work but have never done masonry work. I am considering transitioning to a wood frame chase at the roof line. Here are some of my concerns as I plan the job.
1- The top two clay flue liners will be replaced. Is there an adhesive product I can use between the old existing liner and the new one, or must I use a refractory mix?
2- Can the new flue liners rise up through the wood chimney chase with no horizontal support, as opposed to having rubble-fill like in a brick chase? The top crown will be much lighter than concrete.
3- How much clearance should there be between the flue liner and the chase walls?
Thanks in advance for comments and any suggestions.
burch is offline
Old 04-23-2019, 09:43 AM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Brick Chimney To Wooden Chase Questions
Never saw what your proposing done before. I think you are in uncharted waters. Get a mason out there to fix it and swap roofing with him.
fjn is offline
Bull Trout (04-23-2019)
Old 04-23-2019, 09:52 AM   #3
burch's Avatar
Trade: Roofing
Rewards Points: 14
Nothing like the Hoover Dam had ever been built either but they figured it out as the project unfolded. True story, just recently watched the video on this.
Once I can get answers to my questions I can make a decision on what is the best course to follow.
burch is offline
Old 04-23-2019, 01:00 PM   #4
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,446
I would not have an unprotected flue liner through a wood chimney
They fail all the time
Youíre supposed to use refractory cement however a lot of people donít use it
Windycity is online now
Old 04-23-2019, 02:39 PM   #5
burch's Avatar
Trade: Roofing
Rewards Points: 14
What makes a flue liner protected? Would it be the rubble that is piled in between the liners and brick on a conventional brick chimney?
burch is offline
The Following User Says Thank You to burch For This Useful Post:
Windycity (04-23-2019)
Old 04-23-2019, 03:33 PM   #6
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Could nail strapping to it and side it. Make a metal pan for the top.
JBM is offline
Old 04-23-2019, 04:34 PM   #7
burch's Avatar
Trade: Roofing
Rewards Points: 14
Yes, definitely plan to make a metal top/crown. Could you expand on what you mean with nail strapping to it? Is this to give horizontal support to the flue liners?
burch is offline
Old 04-23-2019, 06:22 PM   #8
JBM's Avatar
Trade: Masonry
No you'll leave the brick chimney in place.
JBM is offline
Old 04-23-2019, 06:54 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 454
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Tinstaafl is online now
Attaching tile to brick chimney. TaylorMadeAB Remodeling 9 01-24-2015 01:06 AM
Chimney chase B.D.R. General Discussion 5 08-28-2014 10:04 PM
Brick sidewalk edge restraints red_cedar Masonry 16 07-18-2012 06:28 PM
Flue cap GettingBy HVAC 11 02-14-2011 04:46 PM
brick chimney sealant David U Masonry 3 10-28-2009 07:30 AM
