Bond Beam Blocks - Masonry - Contractor Talk
Bond Beam Blocks
Old 05-01-2019, 09:16 PM   #1
CMU85's Avatar
Trade: Builder
Bond Beam Blocks
Has anyone ever constructed a cmu foundation with bond beam blocks for every course? Are there any potential pitfalls to this method, besides being costly.
CMU85 is offline
Old 05-01-2019, 09:49 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,028
Re: Bond Beam Blocks
Yes, I have.
Nothing wrong with it.
Last one I built has bond beams every other course, because there is rebar in every other course horizontally, and every other cell got a stick.
And then some extra in a few places.
And then fully grouted.
fjn (05-02-2019)
Old 05-02-2019, 03:23 PM   #3
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,446
Why?
Windycity is online now
Old 05-03-2019, 11:58 AM   #4
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 682
At that point you might as well just do a poured wall or ICF and get a better end product.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
rustyjames (05-03-2019)
Old 05-03-2019, 04:18 PM   #5
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,118
Why wouldn't you just use line blocks made for this application?
You won't be able to do any vertical rebar in grouted cores using bond beams.
Fishindude is offline
Old 05-03-2019, 05:42 PM   #6
fjn's Avatar
Trade: mason
Rewards Points: 11,202
???? and why not ? I think you are confusing bond beam block with lintel block.
fjn is offline
Seven-Delta-FortyOne (05-03-2019)
Old 05-04-2019, 10:13 PM   #7
Tscarborough's Avatar
Rewards Points: 1,460
RSBB AKA Knockout Bond Beams.
https://elstonmaterials.com/product/...low-through-2/
They cost a little more, but for a solid grouted wall, the way to go.
Tscarborough is offline
Old 05-04-2019, 11:07 PM   #8
Windycity's Avatar
Trade: Masonry
I only made it to the part that said 12 inch on your block link before i promptly closed that page and started running away and promising myself to never ever look at that page again
The Following User Says Thank You to Windycity For This Useful Post:
bytor (05-05-2019)
Old 05-05-2019, 06:00 PM   #9
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Nothing wrong with it perse aside from a waste of money.
JBM is offline
Old 05-05-2019, 09:33 PM   #10
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
Your design team is silly: far better than solid walls are the same amount of concrete and grout and rebar USING A WIDER CMUS... Price the 12" or even 14" Units, grouted every 16 or 24" with TWO smaller bars adjacent to the faces....each 12" cell takes 200% the grout a 8" cell takes, more or less...
if you need to get the steel to concrete % higher for Uber wall loads, use 3/16" ths dura-wall Ladder wire(grouts far easier) every course, INCLUDING BOND BEAMS.
Pilasters would be another technique to cheapen the wall up and still meet strength demands.
What ever you do, make sure the footings are equal to the loads the wall imposes on them.
If you must grout solid, just cut your own "Calfornia" bond beams with the demo saw, cut a layer of a cube at time during handling.
All block basements I've done recently have 2 Bond beams top or second from top in an underpin, and a continuous bond beam below the egress window.
I wouldn't use any plastic insulation inside my house, ever...
Double up on the outside, use the weight of masonry/concrete for "thermal Mass",
Fouthgeneration is offline
Old 05-10-2019, 06:34 AM   #11
NYCB's Avatar
Rewards Points: 682
Aren't block footers usually the same spec as poured wall footers?
At least as deep as wall thickness and at least 3x as wide?
NYCB is offline
Old 05-10-2019, 10:13 AM   #12
fjn's Avatar
Trade: mason
This raises an interesting question. From what I read,the proposed building loads along with the soil bearing capacity dictates the footing thickness and width in relation to wall width. A common rule in N.W. Indiana is footings should be as thick as wall is wide and twice the wall width. Can't remember where I read it,however,in some cases,footings can actually be too wide if the ratio is ignored. Kinda like loading the center of a 2 "x 4" one 4' long and the other 16' long with the same weight. The 16' will crack sooner.
fjn is offline
Old 05-10-2019, 10:19 AM   #13
fjn's Avatar
Trade: mason
This article speaks to the possibility of a footing being too wide if the ratio is not followed.
http://www.home-building-answers.com/footing.html
fjn is offline
Old 05-12-2019, 07:52 AM   #14
Trade: Masonry
Any footing I design/poor that has a veneer masonry starts at 20" wide by 10 "...
Around here, with out a soil test, your are looking at only 1.5KIPS a square foot of bearing, where 30 years ago it was "assumed" at least 2.5KIPS a square foot.
There is no sense in using a super duty load bearing element then resting it on doubled up Osb stapled together.
In a more perfect world the width and depth of the footings would vary to match the dead and live loads imposed directly above to reduce differential settlement
Post to Beam to Cover Vinson Decks & Fencing 12 05-18-2016 10:00 AM
Typical beam span [email protected] General Discussion 24 07-30-2014 08:07 PM
Advice on Removing Large Beam? (Residential) markavelli Construction 26 05-26-2013 12:04 AM
Updating main beam in century-home: end. bob_cntrctr Framing 8 02-07-2008 04:04 PM
form bond beam bobbrown Masonry 8 09-11-2006 06:54 AM
