Block Wall Fence Leaning - Masonry - Contractor Talk
Old 05-24-2020, 10:15 PM   #1
Homeshopper's Avatar
Trade: HVAC
Rewards Points: 4
Hello, we are looking at a home to purchase that we really like. The problem is that it has a block wall fence around the perimeter of the back yard, approx 300 LF, thats leaning slightly. I was wondering if thats something that can be repaired fairly easily and relatively inexpensive.
If there is any additional information that you may need for an accurate response, please let me know.
Thank you for your time.
Jerry
Homeshopper is offline
Old 05-24-2020, 10:20 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,462
Re: Block Wall Fence Leaning
sounds like it is not properly built, including the required footings.
will not be a quick, easy or cheap fix.
griz is online now
The Following 3 Users Say Thank You to griz For This Useful Post:
Fouthgeneration (06-02-2020), KAP (05-25-2020), Seven-Delta-FortyOne (05-25-2020)
Old 06-02-2020, 08:53 PM   #3
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
Get a Bid from a real Mason that HAS repaired similar fence successfully, use the cost to lower your offer for the home.
get a to bid to demo the nuisance fence and replace to code....Again use the info to negotiate a fair offer.
if the fence almost had frost footings, maybe mini-pipe piles?
Fouthgeneration is offline
Old 06-02-2020, 09:05 PM   #4
tgeb's Avatar
Rewards Points: 1,056
I provided a quote to remove a leaning brick fence a couple years ago. I don't recall if it included a new proper footing for a new wall or not.
But I did not get a call back.
Sent from my SM-G970U using Tapatalk
www.gebcon.com
tgeb is offline
Old 06-03-2020, 07:39 AM   #5
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,310
Have an outfit such as AccuLevel take a look at it. Might be able to mud jack under the footings to straighten it up?
Fishindude is offline
