Bay Window Leaks (they're All Supposed To Right?) - Masonry - Contractor Talk
Old 02-21-2014, 02:01 PM   #1
lilbuzzy's Avatar
Trade: blasting
I am seeking information. I have a bay window with brick and copper. It is leaking. I was not around to see what type of flashing and or method was used when the house was built. My question to the masons: Can one retro flash a bay window without starting from scratch? And how and where would you begin this process? It looks fancy and professional but it leaks like 70's Harley. From my internet research I have seen how it needs to be done, but my problem lies in that its a done house. So what and how do you do the reflash? I know you guys want pics right now, but I don't have access at the moment. It is a curved copper top (at the hip). Does that make it more difficult to fix.
Thanks in advance
Richie
lilbuzzy is offline
Old 02-21-2014, 03:42 PM   #2
General Contractor
greg24k's Avatar
Rewards Points: 8,814
Re: Bay Window Leaks (they're All Supposed To Right?)
Thanks in advance
Richie
Cut the brick joint about 2-3 courses up from the roof line and along the sides, bend and install flashing and seal it along the joint.
Something like this
greg24k is offline
Old 02-21-2014, 04:58 PM   #3
lilbuzzy's Avatar
Trade: blasting
Thanks for the advice but I think that's the way it's flashed. I feel it needs more from the structure to the outside of the veneer. attached are some pics. The curve is why I think all the contractors I've talked with want to calk and seal the brick and it ride. I'm tired of riding! I just want it fixed.
lilbuzzy is offline
Old 02-21-2014, 06:07 PM   #4
Roofcheck's Avatar
Trade: Know it all
Rewards Points: 2,054
I think it's obvious to where your leak is. At least one lock should have been flattened and covered by the next seam- and soldered.
Step 1 pull that silicone out and see what's under it.
Roofcheck is offline
The Following User Says Thank You to Roofcheck For This Useful Post:
dom-mas (02-22-2014)
Old 02-21-2014, 06:09 PM   #5
Roofcheck's Avatar
Trade: Know it all
A new "to wall" flashing tucked under that wall flashing- not on the rake wall just across the top, using copper it will age nicely.
Old 02-21-2014, 06:36 PM   #6
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Take all of that off and re do it. Its a roofing problem not a masonry problem
JBM is offline
The Following 2 Users Say Thank You to JBM For This Useful Post:
dom-mas (02-22-2014), slowsol (02-22-2014)
Old 02-21-2014, 06:42 PM   #7
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Nice house for a blaster!
jlsconstruction is offline
Old 02-21-2014, 07:10 PM   #8
Roofcheck's Avatar
Trade: Know it all
I think it's only missing one piece the rest isn't bad.
JBM (02-21-2014)
Old 02-21-2014, 08:45 PM   #9
lilbuzzy's Avatar
Trade: blasting
so it needs to be cut in the brick and lap from under the decorative piece?
lilbuzzy is offline
Old 02-21-2014, 08:46 PM   #10
lilbuzzy's Avatar
Trade: blasting
thanks. try jack of many master of none. two incomes no kids has advantages. i guess i do a bit of everything.
lilbuzzy is offline
The Following 2 Users Say Thank You to lilbuzzy For This Useful Post:
jlsconstruction (02-21-2014), Rockmonster (02-24-2014)
Old 02-21-2014, 10:22 PM   #11
pro
Builder Butch's Avatar
Trade: builder/remodeler
Rewards Points: 87
Its hard to be sure from pics but we build a lot of copper hoods like yours here also. They all leak and here are 2 solutions that seems to fix most. And trust me I've stopped hundreds from leaking.
1. The window above might need a flashing pan install. Wood windows are difficult to keep water out. The water usually runs down the back side of the brick down to the ground. The bay has interrupted the weep system and is hitting your ceiling most likely. A window pan between the sill and the rough opening will catch the weep water and direct it outside the wall.
2. Seal the brick with Soloxane PD. Brick is like a sponge and will absorb the water and weep down the backside of the brick again interrupted by the bay and likely ending up on your ceiling.
Anytime brick does not terminate to the ground it is almost always the brick. Since the flashing is on the face of the brick the water soaks through the brick and infiltrate the wall assembly.i
Builder Butch is offline
The Following User Says Thank You to Builder Butch For This Useful Post:
lilbuzzy (02-21-2014)
Old 02-21-2014, 11:11 PM   #12
lilbuzzy's Avatar
Trade: blasting
2. Seal the brick with Soloxane PD. Brick is like a sponge and will absorb the water and weep down the backside of the brick again interrupted by the bay and likely ending up on your ceiling.\
I've been told the same thing. I think it needs something like you described. Do you have to unbrick it to install that pan from the structure to the outside or can you slide it under?
lilbuzzy is offline
Old 02-22-2014, 11:07 AM   #13
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,292
I would say that Builder Butch is correct. We call them cavity trays.
http://www.manthorpe.co.uk/Building/...ity-Trays.html
Without them wind driven rain pours inside.
You have to remove some brickwork to retro fit them.
stuart45 is online now
Old 02-22-2014, 01:21 PM   #14
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
My question is how is the opening spanned? I'm guessing with an angle iron...yet I see no evidence of weepers above the roof flashing. There needs to be wall flashing that goes onto the angle along with weeps so that water can drain onto the roof (or at least so fresh air can get in and dry things out). If the lintel is within a roof line, the flashing should stick out the masonry above where the roof flashing is anticipated and the roof flashing tuck in under it
Don't seal the brick. Masonry needs to breathe. Water will win, it gets in through very tiny cracks, the masonry needs to be able to let this water out as vapour
www.dominionmasonry.ca
dom-mas is offline
Old 02-22-2014, 07:22 PM   #15
pro
Rewards Points: 87
You cant really slide the pan in. You will need to remove the window to install it or sometimes I just take the sill out. The pans I use are built out of simple flashing metal and i bend the ends up 1/2" or so and the rear at least 3/8" or as much as I can. Then we fold the corners and use Geocell 2300 to seal the corners. make sure you put a shim under the pan just to give it a little outfall. The upbends create a damn when it fills up. You dont need to remove any brick and the pan depth needs to be from the inside of the sheetrock to a 1/2" onto the brick sill. You could go ahead and cover your Brick sill and use copper. The window is not difficult to remove just remove the brickmould and casing then set the window aside while you install your pan. Takes about a 1/2 day to do it all.
If you want to test my theroy to see if this is your problem. Take the interior stool and apron off. This should allow you to see underneath the sill. Wait till it rains or have someone spray it with a water hose and see if the water is getting in or you will probably see black mold. Start water testing low on the window and spray for at least 3 minutes isolating the one area. it takes a minute for the water to saturate the brick. If no leak
then move upward a few inches at a time until you see it coming in.
I learned this the hard way. Before the crash I built 40 to 50 good size homes a year starting in 1987. I had a few of these leaks especially the copper hoods and tried everything in the world to stop them. I spent thousands of dollars. I'm a Mechanical Engineer by degree and Builder by choice. So I was determined to figure this out. I started reading about water infiltrate management and the correct way to build a wall assembly when a light bulb went off. It was so simple it was just stupid. I had about 12 leaks that were unsolved and one lawsuit on me. I fixed them all. Now everyone calls me to fix the hard leaks. Funny thing is I try to school them on how to build them correctly but the rarely listen. Why I don't know.
Good Luck! If you PM me your email I will try to find some pic of the pan and wall assemby. Im sure I will do another one sometime soon.
Old 02-22-2014, 07:35 PM   #16
pro
Rewards Points: 87
Dom-mas you are right about the brick breathing. You need to google Solaxane PD. This stuff is great. It fills the pores of the brick but somehow leaves small voids large enough for air to pass but small enough so water cant get through. Kinda the same concept as Gortex or house wrap. Air molecules are smaller than water molecules. Stuff is expensive but last 15 to 20 years. It will not fill large cracks but will take care of the superficial cracks.
dom-mas (02-23-2014)
Old 02-23-2014, 05:09 PM   #17
fjn's Avatar
Trade: mason
Rewards Points: 11,202
https://www.youtube.com/watch?v=FbHlx4i7XIg
fjn is offline
Old 02-23-2014, 05:29 PM   #18
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Thanks FJN. That was what I was trying to explain, however code here says that masonry can only be supported by steel or other masonry, so what we do is install the angle as it was in the first part of the video, no weepers, build up with block to 4" or so above the bay, including all the angled area, then install the flashing. The roof/wall flashing covers all the block so you never see it. Weepers go in the brick
dom-mas is offline
Old 02-23-2014, 08:12 PM   #19
pro
Rewards Points: 87
Originally Posted by fjn View Post
That is exactly how I do them now. Never had a problem, however it is a difficult mess and expensive to retro that on an existing house and was the reason I reccommend my method. Thanks fjn that video makes it easy to understand.
Old 02-24-2014, 11:11 AM   #20
stuart45's Avatar
Trade: Brickwork
Here's one about the stepped cavity tray.
http://www.youtube.com/watch?v=bYwhGKxAweI
The Following User Says Thank You to stuart45 For This Useful Post:
Rockmonster (02-25-2014)
90 yr old window replacement? coworx Windows, Siding and Doors 3 04-26-2013 09:36 PM
Pressure Washing & Window Cleaning Tips Jas2012 New Member Introductions 13 08-14-2012 05:22 PM
Pressure washing and window seals. SuperiorHIP General Discussion 9 08-05-2012 07:19 PM
Nailing Utility Trim Under Window for Vinyl Nick R Windows, Siding and Doors 3 07-16-2012 05:25 PM
