Approximate Thickness Of Metal Lathe + Scratch Coat? - Masonry - Contractor Talk
Old 06-30-2019, 09:59 PM   #1
JRremodelers's Avatar
Rewards Points: 72
Im working on my exterior wall detail. Looking to do a brick veneer over 2 foam insulation w/ integrated studs. this will be 10 above grade to top of block
Just asking you experienced masons. What is your typical thickness of metal lathe plus scratch coat. My idea is to not have my brick veneer protrude past the siding. Rather have it recessed. I plan to use just a 1/2 brick veneer
JRremodelers is offline
Old 06-30-2019, 11:44 PM   #2
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,740
Re: Approximate Thickness Of Metal Lathe + Scratch Coat?
The lath is pretty thin, like an 1/8th...But the problem is when the lath overlaps another piece or two it starts to build up
I would say no more than 3/8in thick
Windycity is offline
Old 07-01-2019, 09:28 AM   #3
fjn's Avatar
Trade: mason
Rewards Points: 11,202
And a tad thicker if you use self furring lath,which I prefer. Ideally,three coat stucco should finish out between 3 / 4 " -- 1".
fjn is offline
Old 07-01-2019, 09:42 AM   #4
fjn's Avatar
Trade: mason
Actually,the ASTM standard requires self furring lath over a solid surface.
Sometimes flat or non-self-furred lath,
or flat rib lath, is used over solid surfaces. ASTM states that self-furred lath
shall provide approximately 1/4-inch
furring away from the solid surface in
order to provide proper keying of the
stucco, and that self-furred lath must be
used on all solid surfaces. Self-furred
lath is furred with dimples or embossed
ribs in the mesh that provide for the
required 1/4 inch of furring. Flat rib
lath should not be considered selffurred because it does not offer an adequate amount of furring
fjn is offline
Fouthgeneration (07-03-2019)
Old 07-02-2019, 06:42 PM   #5
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
3/8" to 1/2"
supersealconstruction.com
superseal is offline
Old 07-03-2019, 12:41 AM   #6
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,797
As You go to the "thin" side of any materials normal thickness, any previous errors will telegraph to the surface.
The crappier the underlying workmanship, the greater the need for an ever thicker scratch coat... Tom Jefferson's Monticello has rooms with 6-7 inches of plaster to square up the slave Mason built walls......
Remember at corners, if you don't stagger every other course there are FOUR layers of mesh, and any exposed steel mesh/fasteners will eventually rust.
Fouthgeneration is offline
Old 07-13-2019, 02:57 PM   #7
Tscarborough's Avatar
Rewards Points: 1,460
1/2" to 3/4" Using faces cut to half thickness is not the standard. Cut the faces to 1" or so. You need 7 of them (modular size) to weigh less than 14 pounds.
Tscarborough is offline
