Anyone Ever Add Ice To The Concrete Truck? - Masonry - Contractor Talk
Old 07-01-2018, 11:16 AM   #1
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,512
It's gonna be hot this week, and I have to pour two days of it. Nothing huge, 9 yards and 14 yards. I can't get a first thing in the morning load either day though, and even being in full shade, I still get nervous about the trucks heating up when it's super warm out.
Anyone ever toss ice in the truck on site before mixing, it wouldn't take very long at all to get about 60 lbs in the top of the drum to get the temperature down a bit.
I'm just kind of brainstorming here since I like to avoid retarder whenever possible.
It might be a stupid idea.
NYCB is offline
Old 07-01-2018, 11:31 AM   #2
J.C.'s Avatar
Rewards Points: 242
Re: Anyone Ever Add Ice To The Concrete Truck?
How many yds does a truck hold, 9? 9 X 4000lbs=36,000 lbs
I would imagine you'll need quite a bit more than 60lbs to do anything at all.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
Old 07-01-2018, 11:33 AM   #3
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Adding ice is the same as adding water,will dilute the mix and change the water to cement ratio,hence weakening the concrete. You'd be better off using a retarder.
fjn is offline
The Following 3 Users Say Thank You to fjn For This Useful Post:
cedarboarder (07-01-2018), griz (07-01-2018), Jaws (07-01-2018)
Old 07-01-2018, 11:39 AM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 2,714
double your crew size and don't dick around with it.
order it in two loads.
griz is online now
The Following 3 Users Say Thank You to griz For This Useful Post:
AustinDB (07-05-2018), Fouthgeneration (07-01-2018), hdavis (07-01-2018)
Old 07-01-2018, 12:42 PM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Use a mobile mix company.
Inner10 is offline
Old 07-01-2018, 12:47 PM   #6
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,725
Ya move faster!!!! I did a walkway a couple weeks ago in the heat....if it would have been one foot longer it would have gotten away from me!!!!!!
Jay hole is offline
Old 07-01-2018, 12:50 PM   #7
NYCB's Avatar
Right, so roughly 8 lbs per yard for a gallon a yard should add an inch to the slump, I guess that would be over 70 lbs for a 9 yard load.
Shouldn't weaken it anymore than dumping in 10 gallons before pouring.
Edit: reading an article about it, seems that in order to get the batched temperature down about 20 degrees you need to use nearly half the mix design water as ice, that's a lot.
NYCB is offline
Old 07-01-2018, 12:54 PM   #8
NYCB's Avatar
None of them nearby unfortunately. I have used them on a few sidewalks in the past, and the amount of time we had with it was crazy. It comes out of the auger cool to the touch and lets you wait forever before you need to hustle.
NYCB is offline
Old 07-01-2018, 12:58 PM   #9
NYCB's Avatar
It's not the placing part that worries me, we can have that done without much hassle quickly.
I'm the one that has to stick around and power trowel though and I don't want a runaway floor in the afternoon.
It's kind of annoying, I usually try to do them at 7am, but the local companies are slammed and I can't get a morning pour for two weeks. I can't wait that long on either of them.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
Fouthgeneration (07-03-2018)
Old 07-01-2018, 01:04 PM   #10
Inner10's Avatar
Really popular here, never get a hot load, no waste.
Inner10 is offline
Old 07-01-2018, 01:42 PM   #11
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Soak the subgrade, tent or sun shade the area, 2% retarder, 6 slump and sweat your azz off cause it's gonna go quick anyway.
supersealconstruction.com
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
Caleb1989 (07-02-2018), Fouthgeneration (07-01-2018)
Old 07-01-2018, 02:27 PM   #12
fjn's Avatar
Trade: mason
P.S. Don't forget your cure and seal !
fjn is offline
Old 07-01-2018, 08:45 PM   #13
tgeb's Avatar
Rewards Points: 1,170
I can request ice in the mix all Summer long, it is added at the plant for an additional charge, same as hot water in the Winter.
Adding retarder helps a lot and gives you some extra time. In the heat I'd rather wait on the concrete than have it get away.
www.gebcon.com
tgeb is online now
Old 07-01-2018, 09:18 PM   #14
test
cedarboarder's Avatar
Trade: General
Rewards Points: 817
I find this offensive, the name of this product should be changed to delayer
cedarboarder is offline
The Following User Says Thank You to cedarboarder For This Useful Post:
fjn (07-02-2018)
Old 07-02-2018, 12:18 AM   #15
Caleb1989's Avatar
Rewards Points: 394
I 2nd wet the subgrade advice, that makes all the difference in the world. And there is no shame in adding “delayer”!
Just keep a guy to work the edges while you are on the whirly bird. Also I like to hang a 2 gal bucket of water with a fatty paint brush. On your final pass, use it to toss a little water on the pock marks to smooth them out quick.
Anyone here used super plasticizer? I hear it’s good for pouring walls in the summer, but I’ve never used it.
Caleb1989 is offline
Old 07-02-2018, 03:37 PM   #16
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
pour at 3:00 pm so that you dont have the sun pounding it all day
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 07-02-2018, 03:52 PM   #17
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,866
Haven’t used it in concrete but I have used it in mortar and can say that it is amazing how it makes it flow easily
Windycity is online now
Old 07-03-2018, 10:00 PM   #18
Tscarborough's Avatar
Rewards Points: 1,460
Generally added at the plant and replaces mix water. Do other things.
Tscarborough is offline
Old 07-03-2018, 10:21 PM   #19
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,877
Take temp readings at start and finish of each unload...
Have trucker engage the drum rotation counter, at the plant, every 'extra' turn just adds heat through the tumble action once the mixing is complete.
reject any loads over mixed, like > 300 revolutions.
Avoid rush hour traffic that might delay the redi-mix trucks, use the plant closest, even if it is 50-100 $ more.....
If the slab is not need to be loaded ASAP, use more fly ash, less Portland cement, The larger the large aggregate, the less internal heat per yard at the the same final strength...
If its indoors, install a radiant heat piping, and fill and chill.....even a total loss tap water would slow the set...
A tarp awning is most likely the most practical solution, and will improve the total concrete quality, and a smaller crew...
If the work is near flat, you could flood the pour after it is finished with a sand and plastic sheeting dyke or a slightly riskier method of using yard sprinklers to keep the crete WET for hours-days?
Fouthgeneration is offline
Old 07-03-2018, 11:04 PM   #20
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,972
Eh...9 yards ain't that big of a pour, especially with a power trowel.
I'd be more worried about getting a hot load, with an afternoon delivery from a company that's busier than s#!^.
brhokel606 (07-04-2018)
Concrete Science - I'm a bit of a science nerd. AmeliaP Masonry 19 02-23-2014 02:50 PM
17-ton concrete slab overhang fell from a bank building in Stroud Township AmeliaP Masonry 27 09-05-2013 07:16 PM
Sealing Stamped Concrete Bill Butler Masonry 1 06-02-2013 04:51 PM
Concrete Slab breaking up in Barn Dustincoc General Discussion 7 02-14-2013 07:44 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
