Another Vault. - Masonry - Contractor Talk
Another Vault.
Old 06-02-2015, 08:09 AM   #1
Knows less all the time
Fundi's Avatar
Trade: Brick Contractor, Manufacturer
Rewards Points: 580
Another Vault.
We had been talking to an architectural firm in Dar es Salaam for awhile. This year they got a job for primary school and designed with vaults and arches (thinking of us). They can't get clay bricks in Dar and build permits needed so they went with cement paving stones and building the arches on formwork. Much more engineering and design and stamps than we have done. arches are two in middle of room of 6 meters and then 3 vaults on them and the walls.
Not what we like to see but it is a job. We havent had a vault job since early in the year Now they want to do one classroom with clay bricks vault. So Dickson has gone 200 km away looking for bricks.
Dar is 700km away and just sent Dickson and a helper. So i rely upon phone and pictures.
We only do the vaults and arches the foundation and walls are someone else.
Fundi is offline
The Following 4 Users Say Thank You to Fundi For This Useful Post:
festerized (06-02-2015), fjn (06-05-2015), stonecutter (06-04-2015), superseal (06-02-2015)
Old 06-02-2015, 08:17 AM   #2
Fundi's Avatar
Rewards Points: 580
Re: Another Vault.
Fundi is offline
The Following 9 Users Say Thank You to Fundi For This Useful Post:
blacktop (06-06-2015), CO762 (06-03-2015), dom-mas (06-02-2015), Eaglei (06-02-2015), festerized (06-02-2015), fjn (06-05-2015), SmallTownGuy (06-02-2015), stonecutter (06-02-2015), superseal (06-02-2015)
Old 06-02-2015, 08:21 AM   #3
Fundi's Avatar
Rewards Points: 580
Re: Another Vault.
oops meant this for the picture section.
Fundi is offline
Old 06-02-2015, 10:09 AM   #4
JBM's Avatar
Trade: Masonry
Rewards Points: 9,472
Re: Another Vault.
Always impressed with your anti gravity masonry skills!
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
Fundi (06-02-2015)
Old 06-02-2015, 10:40 AM   #5
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 662
Re: Another Vault.
Fundi, can I come work for you? How's the pay?
artisanstone is offline
The Following 2 Users Say Thank You to artisanstone For This Useful Post:
Fundi (06-02-2015), superseal (06-02-2015)
Old 06-02-2015, 02:05 PM   #6
Fundi's Avatar
Rewards Points: 580
Re: Another Vault.
I wish you would / could.
Fundi is offline
Old 06-02-2015, 02:32 PM   #7
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Re: Another Vault.
How long does something like this take? Looks kinda warm there. What is the mortar type used?
Great work.
heavyc is offline
Old 06-02-2015, 04:33 PM   #8
John the Builder
SmallTownGuy's Avatar
Rewards Points: 8,234
Re: Another Vault.
No, no, this is way cool being here!(Serendipity)
I was just thinking about you today. I've been researching clay and brick dwellings, and stumbled on this guy at a TED talk: Diébédo Francis Kéré
https://www.google.com/search?q=Di%C..._AUoAQ#imgrc=_
Every time I look at one of your posts here, it gets me motivated.
Thank you!
SmallTownGuy is online now
Old 06-02-2015, 06:55 PM   #9
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Another Vault.
So glad you're posting again. I liked the exterior architecture at my highschool, the interior was blah...that school on the other hand is just inspiring...as it should be
www.dominionmasonry.ca
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
Fundi (06-02-2015)
Old 06-03-2015, 01:42 AM   #10
Fundi's Avatar
Rewards Points: 580
Re: Another Vault.
Wow! Thanks for that. I can't believe I have never come accross Diébédo before. I have to check him out more.
Fundi is offline
The Following User Says Thank You to Fundi For This Useful Post:
SmallTownGuy (06-05-2015)
Old 06-05-2015, 01:23 PM   #11
Fundi's Avatar
Rewards Points: 580
Re: Another Vault.
Great work.
time: varies but about 3m(2) per day. Dar is hot. mortar in this case is homemade but type S.
Mortar in next pictures is clay sand.
Fundi is offline
heavyc (06-05-2015)
Old 06-05-2015, 01:48 PM   #12
Fundi's Avatar
Rewards Points: 580
Re: Another Vault.
Architect wanted to try some vaults in clay bricks. So now formwork is only used to mark the shape on end walls.
Mortar is clay sand.
Bricks dont look as good as mine but better than the first one in last picture.
Fundi is offline
The Following 2 Users Say Thank You to Fundi For This Useful Post:
blacktop (06-06-2015), SmallTownGuy (06-05-2015)
Old 06-05-2015, 03:19 PM   #13
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Another Vault.
Never having worked with a clay/sand mortar I'm guessing it only works with a clay product? Is that becaase of the absorptive properties of the clay unit or something else?
dom-mas is offline
Old 06-05-2015, 04:21 PM   #14
Tscarborough's Avatar
Rewards Points: 1,456
Re: Another Vault.
I think it only works because the structure is in compression, the mortar is holding the brick apart, not together. There may be a very slight hydraulic set, but not much.
Tscarborough is offline
Old 06-05-2015, 04:29 PM   #15
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Another Vault.
In most modern masonry i would say the same, that the mortar is holding the units apart...it;s acting a sa gasket between the units, but here he doesn't use a centre for the vault when he's using clay mortar so the mortar has to be holding the units together, same as fireclay and firebrick
dom-mas is offline
Old 06-05-2015, 10:36 PM   #16
JBM's Avatar
Trade: Masonry
Re: Another Vault.
How many 2x4 legs would be have trying that!
JBM is offline
Old 06-05-2015, 11:43 PM   #17
Fundi's Avatar
Rewards Points: 580
Re: Another Vault.
Exactly dom, it is the absorptive properties that allow capilliary action on the bricks to keep a brick in place while building one arch in the vault , until the adhesive properties of clay take over. so it doesnt work with a clinker brick. After the arch is finished the dynamics change.
After the arch is finished it is keeping the courses apart like Tsar mentioned and dealing with irregularities of the bricks. Compression comes in AFTER the one course is finished.
I could work on a cement product that is somewhat porous and thinner. Just as if the clay brick were thicker compared to length it would be harder. So you need a good sized face and not too thick.
Did i ever post pics the the timbrel / catalan vault ceilings? I cant find on CT. There the first layer of clay tiles are put up with gypsum as the adhesive.
It is also interesting that we put nothing on the ends of the brick while building an arch. After the arch is done the extrados are "open" and where the radius is sharp it could be even 2cm (3/4"). there is a possibility with loading on one side it could move so we lightly tap stone chippings into the extrados. Mortar could work but only after it is dry.
Fundi is offline
dom-mas (06-06-2015)
Old 06-06-2015, 10:02 AM   #18
fjn's Avatar
Trade: mason
Rewards Points: 10,718
Re: Another Vault.
Thank you for sharing,besides the beautiful projects,you take some great photos !
fjn is offline
Fundi (06-06-2015)
Old 06-06-2015, 10:29 AM   #19
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 214
Re: Another Vault.
Very Impressive Work !
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 06-06-2015, 11:52 AM   #20
patrick grey's Avatar
Trade: mason
Rewards Points: 100
Re: Another Vault.
Excellent work .the Spanish and the Mexican,s have some really good videos on YouTube doing the boveda Catalan (Catalan vaults)and the escalera catalan.they use a soupy kind of mix with lime in it ,very tacky stuff .the mix they use is posted in the comments section on one of the videos.
patrick grey is offline
GROINED VAULT III- FAILURE? HUMBLE PIE? or GREAT EXPERIENCE? Fundi Masonry 17 02-06-2014 05:49 AM
Even another Masonry Vault Fundi Masonry Picture Post 45 03-01-2013 10:07 PM
Masonry Groined Vault II Fundi Masonry Picture Post 30 09-16-2011 08:10 PM
Insulating the Vault monticellohomes Insulation 5 12-18-2008 05:09 PM
