Adding To Concrete Around Post - Page 2 - Masonry - Contractor Talk
Old 05-20-2019, 09:36 PM   #21
Stunt Carpenter's Avatar
Rewards Points: 2,768
Re: Adding To Concrete Around Post
Originally Posted by Joe Wood View Post
jeeze Stunt the posts are sitting in a low spot surrounded by dirt and grass
that's asking for it!
Maybe itís the clay that we have that makes it work. Iíve pulled a ton of posts like that that have no rot at grade.
Gravel here doesnít work with frost and wind. Replaced a fence last year that was two years old with graveled posts. Posts where so loose you could pull them by hand.
https://builddaley.com/
Stunt Carpenter is offline
The Following 3 Users Say Thank You to Stunt Carpenter For This Useful Post:
hdavis (05-21-2019), SmallTownGuy (05-21-2019), XJCraver (05-21-2019)
Old 05-21-2019, 10:19 AM   #22
XJCraver's Avatar
Trade: Building Official
Gravel doesn't work here either, the clay "eats" the rock and then you have loose posts / leaning gates. Fences around here, we pound the posts into the ground without digging or use concrete.
XJCraver is offline
The Following User Says Thank You to XJCraver For This Useful Post:
hdavis (05-21-2019)
Old 05-21-2019, 11:19 AM   #23
hdavis's Avatar
Rewards Points: 1,280
Part of it can be the wind loads coupled with soft ground. 4X4 loads the soil more than a 6X6 or 6" cedar post. If a 6X6 still gives too much loading, cement is pretty usual to get it spread out over a larger area.
At the start of last winter I saw some 4X4 posts in deep loan get hit with a lot of rain, followed by strong winds and a freeze. Posts moved a ton, and panel fasteners snapped off.
Some are still waiting to be repaired.
hdavis is online now
Concrete Slab vs Block vs Pier / Post Foundations carpenj4 Construction 4 09-23-2013 04:41 AM
I need a fence post mounted on a concrete pad. JT Wood Decks & Fencing 23 10-06-2011 11:42 PM
