Adding To Concrete Around Post - Masonry - Contractor Talk
Old 05-20-2019, 09:28 AM   #1
Joe Wood's Avatar
Rewards Points: 904
When I set posts in the ground I bring the concrete up to grade with a slight slope away from the post, then wrap the post bottom with copper.
I sent a fence kit out to Cape Cod and when my customer sent me pics I noticed the post bottoms were all a little below grade with dirt around the post bottoms.
what is a good product to put on top of the concrete to bring it just to grade with a slight slope as it should be? Redi mix won't work because of the aggregate / little rocks.
Some kind of mortar?
Adding to concrete around post-post-bottom.jpg   Adding to concrete around post-copper-posts.jpg
Joe Wood is offline
Old 05-20-2019, 09:39 AM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Adding To Concrete Around Post
Not to drastically sidestep the question,however,I never set posts in concrete. This exchange may change your tack.
https://www.finehomebuilding.com/for...ng-fence-posts
fjn is offline
SmallTownGuy (05-20-2019)
Old 05-20-2019, 11:01 AM   #3
Joe Wood's Avatar
Rewards Points: 904
This looks promising?
https://www.sakrete.com/products/top...ncrete-patcher
Joe Wood is offline
Old 05-20-2019, 11:07 AM   #4
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Concrete is in fact, disallowed in our local arrea. When you apply for a deck or a fence permit, "Construction Code Authority" will give you a print out showing how to set the pad in the bottom, then backfill with pea gravel/crushed stone.
And, they prefer crushed stone.
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
fjn (05-20-2019), rrk (05-20-2019)
Old 05-20-2019, 11:41 AM   #5
hdavis's Avatar
Rewards Points: 1,280
Mortar. If the post wiggles, it will crack if it isn't bonded to the concrete.
hdavis is online now
Old 05-20-2019, 11:49 AM   #6
hdavis's Avatar
No way will I use crushed stone. If I have to pull a post, digging that stuff out to set a new one would be a pain.
Old 05-20-2019, 12:04 PM   #7
Joe Wood's Avatar
Rewards Points: 904
if they use
should they also use a bonder / concrete glue on the top of the concrete??
EDIT
yikes the owner just said-
Each post is sitting in three feet of concrete. Concrete stops a little before the surface – that is going to be filled with crushed stone.
I replied-Yeah the stone will do nothing to get the water away from the post, it’ll actually trap the water there because the post bottom is in a little sump / low spot now with dirt around it. You need to bring the concrete up just above grade, just above where the grass roots are, with a slight slope away from the post and this looks like a good product to use now
https://www.homedepot.com/p/SAKRETE-...5001/100275522 Make sure the exposed concrete is clean, maybe use a wire brush.
Joe Wood is offline
Old 05-20-2019, 12:15 PM   #8
Stunt Carpenter's Avatar
Rewards Points: 2,768
Iíve always had a different approach. I intentionally leave the concrete low and fill to top 6Ē with dirt from the whole. Making sure the dirt is slipping away from the post.
I find this lets the grass grow back to the post and the grass helps absorb the moisture that would normally rot the post.
My fence was done this way 5 years ago and isnít showing any rot
https://builddaley.com/
Stunt Carpenter is offline
Old 05-20-2019, 12:29 PM   #9
John the Builder
Backwards thinking.
Why on earth would you ever even consider pulling a post?
Defies all logic right there.
There is no good use for concrete - or mortar.
Dark Ages are long behind me. I wish you well.
Old 05-20-2019, 12:32 PM   #10
Joe Wood's Avatar
Rewards Points: 904
jeeze Stunt the posts are sitting in a low spot surrounded by dirt and grass
that's asking for it!
Joe Wood is offline
Old 05-20-2019, 12:40 PM   #11
John the Builder
I agree.
Old 05-20-2019, 01:36 PM   #12
Joe Wood's Avatar
Rewards Points: 904
Should they use a concrete glue on top of the new poured concrete before doing the concrete patcher? These footings are only a few days old now.
Joe Wood is offline
Old 05-20-2019, 02:10 PM   #13
hdavis's Avatar
Backwards thinking.
IMO, what works best depends on the situation.
Put fencing where you hit what amounts to rock 2 ft down, and concrete is going to happen.
I get 30 years or so out of PT 4x4 set in sand up here in a well draining area. If you have to take down a couple panels and pull a post for access or tree removal, you can do it. Wet the sand, then wiggle the post and pull it straight out. You can replace a broken post the same way, you just have to be careful pulling it out and sliding the new one in. No digging unless you mess up.
Personally, I wouldn't put a cement or mortar collar where the ground freezes much due to frost heaves, etc. What can work depends a lot on site specifics.
The OP is using redwood posts. They'll be fine no matter what is done. I have some in a swampy area that, even though redwood is considered a 50 year wood for posts, made it to 40 before rot. They're ready to be replaced now just shy of 50 years, but this time around it will be black locust because I can source it locally.
Old 05-20-2019, 02:14 PM   #14
hdavis's Avatar
It's safest to use a concrete bonding agent, but I wouldn't recommend putting a collar on top of the cement simply due to the freeze thaw cycles there.
Old 05-20-2019, 02:19 PM   #15
Joe Wood's Avatar
Rewards Points: 904
better then having them sit in a low wet spot HDavis? It won't be a collar, just a slight slope up to the post to shed the water away?
Joe Wood is offline
Old 05-20-2019, 02:24 PM   #16
hdavis's Avatar
If you want to go the concrete patch route, use this:
https://www.homedepot.com/p/Quikrete...3340/100318461
All the patchers seem to set fast, so you have to work fast.
Old 05-20-2019, 02:36 PM   #17
hdavis's Avatar
Here is where site specifics come in. I'm guessing most of MV is well draining sand under the top soil. It's has decent rainfall. You just want to keep the moisture content of the wood more consistent through the year, so the vinyl patcher may help. With redwood, it's more of a checking/cracking issue due to moisture swings.
One of the best arguments I ever heard was it keeps string trimmers from having to get too close and accidentally tearing up the post. If you put in redwood posts, it makes sense to preserve the cosmetics.
JMO.
Old 05-20-2019, 02:55 PM   #18
John the Builder
Dear Joe Woods - good luck my friend.
smh, smh, smh...
Edit: "Joe Wood" - my bad.
Old 05-20-2019, 02:56 PM   #19
Joe Wood's Avatar
Rewards Points: 904
No S, just Wood! :-)
what's smh??
Joe Wood is offline
Old 05-20-2019, 03:47 PM   #20
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,592
Crushed rock will set the post every bit as solid as concrete and still provide a way for water to drain away.
Randy Bush is offline
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
fjn (05-20-2019), SmallTownGuy (05-20-2019)
Concrete Slab vs Block vs Pier / Post Foundations carpenj4 Construction 4 09-23-2013 04:41 AM
I need a fence post mounted on a concrete pad. JT Wood Decks & Fencing 23 10-06-2011 11:42 PM
