8" Block Firewall - Masonry - Contractor Talk
8" Block Firewall
Old 05-13-2013, 06:03 PM   #1
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
8" Block Firewall
I did a search on 'firewall' but didnt find much.
Anyone have any info on 8" block firewalls? I'd like to know is an 8" block wall by its self fire rated for 3 hours, or does it need zonolite or something similar put in?
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 05-13-2013, 06:26 PM   #2
slowsol's Avatar
Rewards Points: 2,248
Re: 8" Block Firewall
http://www.orco.com/tech_fire_rat.htm
-John
slowsol is offline
Old 05-13-2013, 06:28 PM   #3
fjn's Avatar
Trade: mason
Rewards Points: 11,202
or http://www.nwcma.org/TekNotes/CMFireRes0205.pdf
fjn is offline
Old 05-13-2013, 07:01 PM   #4
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
As FJNs link says, it depends on the block, which differs by region. I'd ask the manufacturer, or the supplier, they should have all the info
www.dominionmasonry.ca
dom-mas is offline
Old 05-13-2013, 07:09 PM   #5
Tscarborough's Avatar
Rewards Points: 1,460
Normally a true lightweight 8" is 2 hour unfilled, 4+ hour filled. Make sure they do not want a UL certified fire rating as that has to be done for the specific batch of block used, and, as stated, check with your manufacturer for the relevant test results.
Tscarborough is offline
Old 05-13-2013, 08:30 PM   #6
Trade: masonry
Thanks for the info guys. It will be standard block, not the light weights.
I have some 12" and 8", and it doesnt call if zonolite is used, but says add an hour if it is. I'll call the local yard tomorrow.
Visit our website @
Old 05-14-2013, 10:50 AM   #7
fjn's Avatar
Trade: mason
As previously mentioned, be careful around that darn zonolite.
fjn is offline
Old 05-14-2013, 04:16 PM   #8
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
6string -
Check with County Materials (if there is anyone else left after buy-outs) and see if they have 8" block with a very thick face shell. They are pretty weak on anything technical but they may know.
For many years, many producers made an 8" block with a 2 1/8" face shell for UL certification, but sold the same unit without certification at a lower price because of the red tape for UL. In heavyweight/normal weight, it had a 3 hour rating and the lightweight was 4 hours with no core filling labor necessary for either weights.
Oldcastle may also have the same units since they have access to many more molds than County, but they may not be in stock. I know the boys in GB made the UL block at one time, but probably rented the molds from someone else. Bend/Oldcastle also made them years ago in West Bend, but who knows what is in stock in WI now.
Dick
concretemasonry is offline
The Following User Says Thank You to concretemasonry For This Useful Post:
6stringmason (05-14-2013)
Old 05-14-2013, 10:58 PM   #9
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,090
I can't (won't) say one way or another, but back in the day we used 8" concrete block for all party walls, filled with vermiculite.
That's what was on the plan.
Today,??? Probably doesn't matter what you use, someone is bound to sue you.
02,
D
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 05-20-2013, 01:30 PM   #10
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 170
Originally Posted by concretemasonry View Post
6string -
I'm starting to think that you're a closet "Cheesehead" ............
Bend/Oldcastle/Northfield/whoeverbuysthem next doesn't make them here anymore I don't believe, but they're made at one of the Northfield plants in Northern Ill., in both 3 & 4 hour HW as I recall. I run into this issue once in a while with 8", and have found that we can usually just fill the cavity with sand to get to 3 hour. Pretty sure all you need is 5.02" total or something like that, and the State will sign-off on it.
I did look for pretty extensively for Zonolite this past fall (even in your area 6string) and could find anything. Closest was Perlite, but I didn't want to pour it outside in this higher-end area, and we had to tooth-in a few door openings later in the same wall......
jomama is offline
Old 05-20-2013, 01:49 PM   #11
I am not a closet "cheese head". My wedge is purple with white horns when I wear it.
There are many ways to raise/increase the fire rating depending on the openness of the authorities. Since concrete does not burn it is just a matter of the amount of mass (equivalent thickness for block) what is put into the cores. Anything (grout, sand, vermiculite, perlite (the best and priciest) increases the fire resistance as long as the local authority approves the background tests. Even a good lightweight aggregate (expanded shale or pumice is great) if available.
In the Republic of WI, the left-overs of the old DLIHR still remain in some areas. When we supplied block for WI certifications, the owner of the testing lab was puzzled why the required such a low standard for LWT block (115 max pcf in WI when the rest of the world had a higher standard of 105 pcf max.), but he followed the standards since they had labs in WI - Codes and standards are always slow to change.
Dick
Old 05-24-2013, 10:15 PM   #12
Trade: masonry
I got a price on some 8" lightweights with a 3 hour fire rating right from the plant. Pulaski concrete.
No one around here sells vermiculite or perilite anymore. All the yards got it from County, and County quit carrying it.
Visit our website @
Compressed Earth Block Construction Jaws Construction 12 02-07-2013 03:33 PM
#5 rebar with 33" lap splice in 8" block wazez Masonry 14 07-11-2011 04:54 PM
Block building leaking inside? GSS Masonry 9 05-24-2010 09:20 AM
Vapor Barrier with concrete block walls? pzeiler Insulation 0 04-21-2010 11:40 PM
How to cap off 8" concrete block wall Michaeljp86 General Discussion 18 09-20-2008 07:18 AM
