20 Ton Tree Landed On A Customer's House - Masonry - Contractor Talk
Old 07-03-2019, 08:41 PM   #1
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,280
I'm not a Mason nor do I know anything about masonry but I think I know enough to say that repointing the bricks on a house that got crushed by a tree probably isn't the correct fix. We had to get a crane to get the tree off of the house and when we were doing that, the brick wall on the first floor was moving around quite a bit. Before the crane, after the tree collapsed, I was inspecting the property and noticed that the brick wall had brakes all over the place in the mortar lines. While I was standing out front talking to the customer we kept hearing loud pops, like 2x4s were breaking from the all the weight on the house. The 2nd floor is siding but the first is brick. The tree smashed all thru the 2nd floor and laid across the roof covering probably 40 squares of shingles. Is it possible that some of the framing behind the brick wall is broken as well?
https://www.dropbox.com/sh/rsjgav92b...NSaaNiLia?dl=0
It was hard to encompass the whole thing in pictures. It was way worse than it looks in photos
madrina is offline
The Following 2 Users Say Thank You to madrina For This Useful Post:
A&E Exteriors (07-05-2019), Fouthgeneration (07-05-2019)
Old 07-03-2019, 09:15 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: 20 Ton Tree Landed On A Customer's House
Probably the least intrusive way to investigate the areas of concern would be to pop the drywall off in those areas. With the glass still intact,I would say the framing may have fared pretty good. But that is conjecture on my part. You will just have to have a looks see.
fjn is offline
Old 07-03-2019, 10:29 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 1,992
there is proper procedure for this type of job just like a fire job.
get the tree out of the way, clean up the debris & do exploratory surgery.
some will be obvious & others hidden pretty well.
just because doors open/close properly & window glass isn't broken just means that there is not likely damage in that immediate area.
foundation & slab must be checked closely.
griz is offline
overanalyze (07-05-2019)
Old 07-03-2019, 11:28 PM   #4
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
I just need pics...
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
B.Johnson (07-05-2019)
Old 07-04-2019, 12:30 AM   #5
hdavis's Avatar
Rewards Points: 1,262
Frame stress should show up in the drywall. Pops, ripples, etc. Pull those areas out and see what is going on.
Brick doesn't move much before it cracks, so it isn't an indicator of other damage if it' didn't open up much. If it opened up, slab would be the first thing to check.
It isn't just stud cracks you're looking for, problems with connections are likely.
That tree could pull the surrounding framing out if square and level, so that all needs to be checked as well.
A simple check of corners for plumb is pretty fast, and exterior visual check to see if a wall has twist is fast as well.
hdavis is offline
Old 07-04-2019, 07:45 AM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 354
Generally, the insurance company will hire an engineer to check on all this. A few years ago, we were involved in an insurance job where a tree fell on a house and did significant damage. After the engineer inspection, the homeowner disputed the findings and wanted more money. They sent pictures of other cracks in the house that were not being covered. The engineer had notes regarding every crack that he found, including those the homeowner wanted repaired. The other cracks weer found to be old because upon magnification, dust and dirt was found in the cracks, indicating an older crack.
Easy Gibson
Warren is online now
The Following 2 Users Say Thank You to Warren For This Useful Post:
hdavis (07-04-2019), overanalyze (07-05-2019)
Old 07-04-2019, 11:50 PM   #7
Not a people person
Chris Doom's Avatar
Trade: Remodel/landscaping/irrigation
Rewards Points: 295
I second what he said and maybe add a couple things. If you're going to be the guy fixing all this or you're helping this HO out. I was thinking you could probably help the engineer out when he comes by stripping some sheetrock from the lower walls to see what damage that tree did to the framing. Judging from the brick facade, at least some forces pounded the framing down low. Suppose it wouldn't hurt to rip out the rock below it before the adjuster gets there and that way he can see exactly what's going on.
Having grown up around insurance underwriting and my GF is an agent, I wouldn't want to see this claim turn into a lawsuit that drags you into it so CYA.
Chris Doom is offline
The Following User Says Thank You to Chris Doom For This Useful Post:
Old 07-05-2019, 08:41 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,797
20 tons of Hardwood = Semi load of firewood..... over ten cords of Maple.....
Max firewood that branch that hit the would yeild, < 2 cords, 180 cubic feet of solid wood at 45 lbs = 8100 pounds plus or minus 2500 IMHO...
8100 pounds x 12-16 feet a second( speed created by branch falling to roof line at plus 12-16 feet above ground) = 113,400 foot pounds of energy give or take 50%....
Does it matter what the tree weighed?
Some cracks do appear to be pre tree fall in my opinion around crawl space vent...
I'd use it as a reason to install 1.5 to 2" of added on sheathing foam insulation, relay everything, and cover that God awful phony barn-board and battens with matching brick or stone.
Fouthgeneration is offline
Old 08-03-2019, 12:56 AM   #9
madrina's Avatar
Thank everyone for their reply... 4th gen...wow
You lost me at tree. But put it into perspective... 20 ton is what was on the bill from the tree removal guys. I talked to the tree guy, he was an older guy, seemed to be one of the few that was around when handshakes meant something if you know what I mean.
I thought I posted pics.. if I didn't I'll do it now..
madrina is offline
Old 08-03-2019, 02:09 AM   #10
Trade: Masonry
This is how a big rain and Flood end up as, " It rained 40 days and 40 Nights...".....
Imagine a 20 Ton concrete truck dropped on the same roof from a 10 foot elevation......
The damage is bad enough, NO need to exaggerate.....
20 tons in my world is about 36,000 to 44,000 lbs...about 840 5 gallon buckets of paint.....
About 20 Tons, is 10-30 Tons....
WAG 20 Tons is 2 to 200 Tons.....
