Sound Proofing , Single Family Home - New Member Introductions - Contractor Talk
Old 04-03-2019, 07:46 PM   #1
lep's Avatar
Trade: Insulators
Rewards Points: 2
Hi there,
I am new here so please bear with me.
I have a sound proofing project in an old construction with no insulation: a single family house 2 stories in LA, each level approximately 1100 sqft.
They want to sound proof the second floor/first ceiling so that they don't hear each other in the 2 different stories.
2nd floor is engineered hard wood flooring.
House is wood frame on slab built in 1954 remodeled several times. Last remodel is 2 years old. Wood floor in the 2nd floor is like new.
I had the chance, due to a gas leak, to see the space between the 2 levels, after removing the drywall ceiling downstairs and noticed there is absolutely NO insulation between the 2 floors. Just joists under the wood floor and the drywall ceiling below. So they need to, somehow, insert strong sound insulation in between, at a low cost with high efficiency.
Do we have to remove the floor above, sound proof and re-install the hardwood floor? gonna cost a lot.
Or make holes in the ceiling from below? then inject insulation like in an attic? Is that efficient?
What materials is the most efficient?
Any advice is welcome.
Thanks
lep is offline
Old 04-03-2019, 09:05 PM   #2
Bull Trout's Avatar
Rewards Points: 132
Re: Sound Proofing , Single Family Home
This is a sight for contractors and building pro's. Please direct your questions to the DIY Chatroom.
Bull Trout is offline
Old 04-03-2019, 10:05 PM   #3
Mordekyle's Avatar
Rewards Points: 6,012
Holes from the exterior into each floor joist bay. Hose/blow in insulation?
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
lep (04-03-2019)
Old 04-04-2019, 09:54 AM   #4
Stunt Carpenter's Avatar
Rewards Points: 2,768
Just add a second layer of drywall to the ceiling. Will do more than some insulation
https://builddaley.com/
Stunt Carpenter is online now
Old 04-04-2019, 03:42 PM   #5
test
cedarboarder's Avatar
Trade: General
Rewards Points: 815
resilient bar it's cheap-and it works.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Demographics For Direct Mail MEL Marketing & Sales 26 01-30-2013 10:48 AM
Searching for partition system without hollow sound HassaanAbdeen Drywall 10 08-08-2012 04:27 AM
Taking Your Work Home With You hiteams Lead RRP Discussion 0 06-05-2012 07:38 AM
should my family help build my home in Hawai'i...? woorki General Discussion 4 01-09-2012 07:01 AM
Custom Home Builder vs. Spec and Tract Builder renet General Discussion 4 11-16-2008 01:51 AM
