Wobbeling Front Wheel? - Page 2 - Vehicles - Contractor Talk
Old 07-30-2019, 07:13 AM   #21
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 792
Re: Wobbeling Front Wheel?
When I consider should I fix something or hire a professional to fix it. I have to ask myself. How long will this take me? What's my time worth? How much is it going to cost me to hire a professional? Then do the math off the answers. If it turns out to be a push, or slightly higher than a push, I hire the professional.
Taking that exact advice myself this morning. I've got a truck that needs to go to the repair shop. It's 50 miles to the repair shop. I've got a trailer big enough to load the truck on & a tractor that I could tow it onto the trailer with & another truck that I could use to pull it to the shop.
Drive time is 2 1/2 hours round trip, plus fuel, plus the time to get the truck loaded. I called the local tow company & was quoted $200. I'm going to work instead & will easily make more than the $200 tow bill.
BTW, I don't change my oil anymore either, just not cost effective to work on my own vehicles as a rule.
pinwheel is online now
The Following 4 Users Say Thank You to pinwheel For This Useful Post:
hdavis (07-30-2019), TheConstruct (07-30-2019), Tinstaafl (07-30-2019), Tom M (07-31-2019)
Old 07-30-2019, 08:25 AM   #22
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 14,528
Monetarily that's definitely true and something that's hard to remember.
There is a couple variables for some people though. For me, I like to learn how things work and a lot of times the only way to understand them completely is to disassemble and reassemble them. When I had the DT466E I spent an entire week tearing the entire motor apart messing with the fuel delivery system. Ohming out injectors, changing seals, installing a new pigtail and testing the HPOP. What a pain but I knew that engine pretty well when done. Turned out to be a fuse cool system though.
I also change my oil on occasions because it's something easy that wont frustrate me and my little girl loves helping on the truck.
Dont make fun of the people who post from their moms basement... they're a little unstable.
Deckhead is offline
The Following User Says Thank You to Deckhead For This Useful Post:
Tom M (07-31-2019)
Old 07-30-2019, 08:56 AM   #23
rrk's Avatar
Rewards Points: 1,782
Originally Posted by Inner10 View Post
Wheel weight fell off.
Mine was the balancing beads they put in the tire separated from the tire
rrk is offline
Old 07-30-2019, 10:42 AM   #24
Texas Wax's Avatar
Rewards Points: 1,746
Don't take but 30 minutes to rotate tires and rule out tire balance or a fed ten dollar bills to have it done at a tire shop. Good practice to rotate anyway.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following 2 Users Say Thank You to Texas Wax For This Useful Post:
hdavis (07-30-2019), MarkJames (07-30-2019)
Old 07-30-2019, 07:39 PM   #25
TimNJ's Avatar
Rewards Points: 4,634
Originally Posted by rrk View Post
That is called a "death Wobble"
I have had that a few times, 50 mph and hit a bump or a pothole. In my case the problem was worn out of balance tire. Get a steering stabilizer while you are at it.
https://www.youtube.com/watch?v=JrNY3TE-9a8
If my truck was doing that, there is no way I'd be driving 70mph.
TimNJ is offline
The Following 2 Users Say Thank You to TimNJ For This Useful Post:
J.C. (07-30-2019), rrk (07-30-2019)
Old 07-30-2019, 08:29 PM   #26
rrk's Avatar
Did not happen at 70, it happened to me at 50 or so. The only way to stop it is to go down to 30 and it stops. Must say the cheeks did get a bit tight when it happened.
A pot hole or expansion gap on a bridge will do it
rrk is offline
Old 07-30-2019, 08:58 PM   #27
TimNJ's Avatar
I meant the driver in the video.
Look at his speedo. It kicks in when he is around 67-71mph.
TimNJ is offline
hdavis (07-30-2019), rrk (07-31-2019)
Old 07-30-2019, 11:37 PM   #28
rustyjames's Avatar
Rewards Points: 1,696
Yup, that's an easy way to rule out a bad tire, which I suspect is the problem.
rustyjames is offline
Old 07-31-2019, 12:41 AM   #29
Texas Wax's Avatar
Know what causes that exact thing on Ford Vans.
Old 08-01-2019, 07:12 AM   #30
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,572
A little levity...
When the debate is lost, slander becomes the tool of the losers.
Robie is offline
tgeb (08-01-2019)
Old 08-12-2019, 07:05 PM   #31
rrk's Avatar
They say Jeep has found what is causing it in their vehicles
https://www.foxnews.com/auto/jeep-wr...ath-wobble-fix
I had a 1976 Chevy pickup that also had it, I installed a steering stabilizer on that and it fixed it for a while but it came back. I doubt it is just a stabilizer because my Isuzu NPR never had one to start with.
rrk is offline
