Wobbeling Front Wheel? - Vehicles - Contractor Talk
Old 07-29-2019, 05:42 PM   #1
Joe Wood's Avatar
Rewards Points: 834
The front left tire on my Dodge pickmup is occasionally wobbling around 50 MPH. Not always but when it happens I slow down and all's well. It's only happened twice in the last two months.
what is causing that, worn tie rods, ball joint??
I'm hoping to fix it myself but I'm not what you'd call a mechanic!
Joe Wood is offline
Old 07-29-2019, 06:00 PM   #2
hdavis's Avatar
Rewards Points: 2,286
Re: Wobbeling Front Wheel?
Could be a few different things.
Catch a YouTube video on how to check the bearings, tie rod ends, and ball joints. Inspect all the bushings for cracking / degradation.
It could also be an alignment issue or a wheel/ tire issue.
hdavis is offline
Old 07-29-2019, 06:05 PM   #3
Joe Wood's Avatar
Rewards Points: 834
Darn I was hoping for something simple .. I've never worked on any of those things ..
Joe Wood is offline
Old 07-29-2019, 06:23 PM   #4
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
Rewards Points: 748
maybe a busted belt?
"Your problem does not constitute an emergency on my part"
CScalf is offline
Old 07-29-2019, 06:29 PM   #5
Joe Wood's Avatar
Rewards Points: 834
Belt in the tire you mean? This had only happened twice like I said?
Joe Wood is offline
Old 07-29-2019, 06:38 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 446
Dumb question maybe, but how do you know it's the left-hand wheel?
Tinstaafl is offline
DaemarConst (07-29-2019)
Old 07-29-2019, 06:40 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 446
I had a similar symptom once that turned out to be a stone lodged in the rim, throwing it off balance.
hdavis (07-29-2019)
Old 07-29-2019, 06:41 PM   #8
tjbnwi's Avatar
Rewards Points: 1,818
I’d check the ball joints, steering linkage on the drivers side and the wheel bearings for play/looseness.
2 or 4 wheel drive.
If you’ve never attempted a steering repair before, I highly recommend finding someone to guide you or have the repairs done. There is no redundant system for steering, when it goes while in motion you’re at the mercy of dumb luck.
tjbnwi is offline
Old 07-29-2019, 06:44 PM   #9
Joe Wood's Avatar
Rewards Points: 834
Yeah I think I'll have a pro look at it, way past my knowledge,
thanks for the good advice guys!
Joe Wood is offline
Old 07-29-2019, 06:56 PM   #10
CScalf's Avatar
Rewards Points: 748
I was just throwing out ideas...im not a wrench turner...hence me being on CT
CScalf is offline
Old 07-29-2019, 07:10 PM   #11
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,025
Did you even drive by a disabled vehicle where the front tire is turned a full 100 degrees and folded out? This sounds like that is about to happen any moment, (whatever that is).
MarkJames is online now
Dirtywhiteboy (07-29-2019)
Old 07-29-2019, 07:19 PM   #12
Fire up the BBQ
griz's Avatar
Rewards Points: 680
did you check the lug nuts????
griz is online now
Old 07-29-2019, 09:44 PM   #13
avenge's Avatar
Rewards Points: 130
If it's a wobble tie rod ends, idler arm, etc. Bounce or vibration balljoint, wheel balance. That's assuming lug nuts are tight and tire is fine.
avenge is offline
Old 07-29-2019, 10:53 PM   #14
Dirtywhiteboy's Avatar
Rewards Points: 13,096
I'd go out there and jack it up and put a big demo bar under it and see if it moves up&down when you lift up on it. That would be the wheel bearings. They are not hard to replace.
Dirtywhiteboy is online now
Old 07-29-2019, 11:21 PM   #15
A1 Auto has a lot of good you tube videos on front ends. They also sell parts. Front ends aren't that complex.
Old 07-30-2019, 12:34 AM   #16
hdavis's Avatar
Up here, you just need a few tools, impact wrench (1500ftlbs isn't too much), and oxy acetylene torch to heat things up.
Jack, stands, chocks....
hdavis is offline
Old 07-30-2019, 12:46 AM   #17
Yup,, same here. I'd like to get a air hammer next.
My ball joints are ready and that other bummer thing.
hdavis (07-30-2019)
Old 07-30-2019, 05:47 AM   #18
rrk's Avatar
Rewards Points: 3,470
That is called a "death Wobble"
I have had that a few times, 50 mph and hit a bump or a pothole. In my case the problem was worn out of balance tire. Get a steering stabilizer while you are at it.
rrk is offline
Old 07-30-2019, 07:04 AM   #19
Tom M's Avatar
Rewards Points: 8,126
Well if you jack it up and grab the wheel and you can rock it I would say it's the ball joint.
Maybe you have a bent rim
Tom M is offline
Old 07-30-2019, 07:08 AM   #20
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
Wheel weight fell off.
Inner10 is offline
Deckhead (07-30-2019)
