Trailer Weight And Hot Asphalt - Vehicles - Contractor Talk
Old 06-20-2012, 11:27 PM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,472
I'm going to be hauling 9 tons of gravel over the next few days, using a friends dump trailer. The temps here in Delaware are expected to hit
100*. The dump trailer is rated at 7000 lbs and I've been hauling 6000 per load with no problem. Tires are in good shape.
Any problem with the heat/weight combination? It will be highway driving...50 miles or so.
Thanks.
When the debate is lost, slander becomes the tool of the losers.
Robie is offline
Old 06-20-2012, 11:35 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,350
Re: Trailer Weight And Hot Asphalt
Sounds like you'll be ok...
keep the air pressure up & the speed down...
griz is offline
Robie (06-20-2012)
Old 06-21-2012, 12:44 AM   #3
Kgmz's Avatar
Make sure that the 7,000 lb rating is capacity and not GVWR.
Most trailers are labeled with their GVWR not the actual carrying capacity.
A typical dump trailer that is rated at 7,000 GVWR actually has a capacity of 4,800 since the trailer weighs about 2,200 lbs. A trailer rated at 10,000 GVWR will weigh about 2,800 to 3,000 giving you a capacity of 7,000 or so.
Kgmz is offline
The Following User Says Thank You to Kgmz For This Useful Post:
Robie (06-21-2012)
Old 06-21-2012, 02:58 AM   #4
General Contractor
greg24k's Avatar
Rewards Points: 8,110
You can't find something closer were you can get gravel and pick it up or get delivered, instead of hauling for 50 miles?
greg24k is offline
Old 06-21-2012, 08:36 AM   #5
Robie's Avatar
No...I'me using both gray stone and red in a bunch of different locations around the house. Getting all I need dumped at one time would be easier but there is nowhere to put it.
I'm going to the gravel pit for the stone. Anyplace closer, especially for the red is double the price.
Robie is offline
Old 06-21-2012, 01:57 PM   #6
Robie's Avatar
This is a Bri Mar. The label with all the info is too faded to read. I got the registration from my friend and called the company. Sure 'nuf...only rated to carry 5000 lbs.
He said it was designed to carry more and lots do, but in the heat with the distance I'm travelling, better to be safe than sorry.
He also said that if I was involved in an accident and it was determined I was carrying more than allowed, big trouble...apparently more than an accident with allowable weight.
Thanks for all the imput!!
Rob
Robie is offline
Old 06-21-2012, 10:53 PM   #7
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
You should be fine, just check the tires before and after each trip. Best time to check is with the bed up so you can see the inside of the tire. Check for cracks, blisters, bulges or broken belts.
woodchuck2 is offline
The Following User Says Thank You to woodchuck2 For This Useful Post:
Robie (06-21-2012)
Old 06-22-2012, 06:24 PM   #8
ESSaustin's Avatar
Trade: Hauling/trucking
Rewards Points: 384
We're running trailers loaded with 5T of debris all summer long in +100*, here in Texas. I echo what WoodChuck said: check the tire pressure daily on the tow rig and trailers.
ESSaustin is offline
The Following User Says Thank You to ESSaustin For This Useful Post:
Robie (06-22-2012)
