Trailer Size & Truck Size(towing Capacity) - Vehicles - Contractor Talk
Old 01-22-2013, 10:44 PM   #1
Dmitry's Avatar
Trade: Framing,Siding.
Rewards Points: 536
Hi, guys. I'll get straight to the point, I've never owned a trailer and trying to switch from working van to towing a trailer to jobs.
I am looking at a trailer at about 6,7 wide by 10,12 long. The main reason is to have a vehicle for personal use after I leave the trailer on site.
I was looking at Tacomas but think the might be a little underpowered and also considered an F150.
What size truck woul you recommend to tow the trailer that has the average amount of tools that you would fit in a van?
Dmitry is offline
Old 01-22-2013, 10:47 PM   #2
Dmitry's Avatar
Rewards Points: 536
Re: Trailer Size & Truck Size(towing Capacity)
Sorry for the terrible spelling, typing long texts sucks on the phone screen.
Dmitry is offline
Old 01-22-2013, 10:51 PM   #3
skillman's Avatar
Rewards Points: 1,968
What weight class you looking for . Do you want gas or diesel truck .
skillman is offline
Old 01-22-2013, 10:56 PM   #4
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
How much weight you going to pull. How far and over what terrain.
Nathaniel Huckins (huck)
Facebook
country_huck is offline
Old 01-22-2013, 10:58 PM   #5
Dmitry's Avatar
Rewards Points: 536
Gas. Trying get something with as close to decent mpg as possible. That's why still trying to figure out if Tacoma won't work for me.
Ford F150 or Tacoma v6( max 6500 towing)
Dmitry is offline
Old 01-22-2013, 11:02 PM   #6
Dmitry's Avatar
Rewards Points: 536
Well, we don't have to many hills over here.
As to the weight, I am not sure. I have a van packed with tools but I need to have a little extra room for play so I don't run out of my range to quick.
What do you guys use?
Dmitry is offline
Old 01-22-2013, 11:13 PM   #7
pro
Rewards Points: 768
If all you are carrying is tools and f150, Toyota tundra or a chevy 1500 would all be more than capable. They all have close to a 10k towing rating.
I you carry a lot in your bed like pallets if tile or shingles you may want a 3/4 ton.
I'm using a chevy 2500 with the 6.0 and it does all i need.
Facebook
Old 01-23-2013, 06:21 PM   #8
Dmitry's Avatar
Rewards Points: 536
Thanks a lot guys, I know my question was rather vague, just needed your outlook.
Dmitry is offline
Old 01-23-2013, 06:48 PM   #9
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Most trailers that size will be 3k lb on a single axle or 7k lb on a dual axle payload capacity. Most f150's can tow about 11,300lbs last time I checked depending on how you spec it out. Mine has a 7800lb towing payload if remember correctly and I tow my 7x14 dual axle day in day out all around the mountains with the 5.4 gas motor.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Dmitry (01-24-2013)
Old 01-23-2013, 07:32 PM   #10
Box Builder
Morning Wood's Avatar
Rewards Points: 10,242
I think towing 6500 lbs with a Tacoma wouldn't be much fun. Seeing as you have never towed a trailer before I think I would opt for 1/2 ton truck. It will be more stable than a tacoma. If you get a single axle trailer get at least a 5k axle on it, and make sure it has electric brakes. Single axle trailer with a 3-3.5k axle will get overloaded quickly. A general rule of thumb I have read is- your trailer shouldn't weigh more than the tow vehicle. Now, I don't live by that saying at all, but as soon as you start to pull more than your tow vehicle weighs, you better be paying real close attention.
Morning Wood is online now
The Following User Says Thank You to Morning Wood For This Useful Post:
Dmitry (01-24-2013)
Old 01-23-2013, 08:20 PM   #11
pro
Builder Butch's Avatar
Trade: builder/remodeler
Rewards Points: 87
I pull a 6x12 loaded heavy with my 07 f150 without a problem, stops good too. However I get right at 10 mpg and the rear springs are upgraded to keep the rear level. I got 105K all city driving without a problem. Well, I do eat front brakes every 30K but that pretty cheap repair. I miss my diesel but not the repair bills.
Builder Butch is offline
Old 01-23-2013, 08:29 PM   #12
Crete's Avatar
Trade: EIFS
Rewards Points: 25
Add another vote for the F-150
Crete is offline
The Following User Says Thank You to Crete For This Useful Post:
Dmitry (01-24-2013)
Old 01-23-2013, 11:49 PM   #13
ram360's Avatar
Trade: General
any 1/2 ton will tow that trailer w/o a problem. I'd stay away from the smaller stuff like the taco, rangers, s10s.
ram360 is offline
Old 01-24-2013, 05:14 PM   #14
Tall Moose
Nepean GC's Avatar
Rewards Points: 179
Being the owner of a compact truck, I personally would dissuade anyone who wants to tow from purchasing one.
Don't get me wrong, I love my ranger...but I have lots of time on Taco's as well...and with anything more than 3k behind them, they are not fun.
an F150 with an ecoboost or 5.0 will get the same fuel economy as a compact, and tow mountains these days (8-11k lbs). Keep in mind, whatever you are towing...you also have to stop. That is the biggest advantage to larger trucks. They can generally stop their loads better.
With a trailer though, don't forget brakes. I spec'd all my trailers with brakes. Cost me a few hundred extra per axle, but it saves tons of wear and tear on the truck.
Nepean GC is offline
The Following User Says Thank You to Nepean GC For This Useful Post:
Dmitry (01-24-2013)
Old 01-24-2013, 05:17 PM   #15
Tall Moose
Nepean GC's Avatar
Rewards Points: 179
Forgot to note - with regards to towing...don't look at just weight. A lot of compact trucks have limits on frontage (sq ft of the front of the trailer). Enclosed trailers tow like sails.
5k in 6x10 trailer tows and handles way differently compared to 5k of gravel in a dump trailer. Less surface area for wind means less sway in high winds, and generally an easier towing experience.
Old 01-24-2013, 05:32 PM   #16
Dmitry's Avatar
Rewards Points: 536
Thanks again, everybody. Your experience really helps a lot.
I guess know I am pretty sure about getting an F150, just gotta pick the package that would work for me best.
Dmitry is offline
Old 01-24-2013, 05:46 PM   #17
tjbnwi's Avatar
Rewards Points: 1,142
Just remember, the weights are for a properly equipped vehicle. If you feel you will be at the high end of the weight you need to look at equalizer bars.
I believe the DOT rule for brakes is 3000 pounds gross. If your trailer has electric brakes you will need a brake controller.
I drive an Excursion with Hawk LT pads and slotted cryo rotors, I still make sure the brakes on the trailer function properly and adjust the controller for the weight being towed.
Check the GVW of the trailer then the curb weight of the trailer empty, the difference is your maximum load in the trailer. ALWAYS load the trailer 60% heavy to the front.
Tongue weight plus truck cargo cannot exceed the GVW of the truck.
Get the F150.
tjbnwi is offline
Old 01-24-2013, 06:36 PM   #18
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
If you can do it, get the F150 or something comparable.
I pulled a 6x12 with my Ranger and as others have said, it's no fun. It's not as easy as it looks when you see someone else going down the road with the tail wagging their dog.
I did that for several months thinking that either I was just being a wuss or that being shifted around was part of towing a trailer. Then I borrowed my buddy's F250 and realized that I didn't have a big enough truck.
From experience, I can tell you that I never thought that I'd be hauling that much stuff in my trailer but eventually you have those few instances where you need to put something in there that's large and/or heavy.. and you do it simply because you can.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 01-24-2013, 09:02 PM   #19
nhill2090's Avatar
Trade: Flooring
Rewards Points: 109
If you can swing it buy a diesel. Your initial purchase will be higher and the maintenance a little more but your fuel mileage will be drastically better than a gasser. Not to mention resale on. 4x4 diesel is much higher.
I have a Chevy 6.0 and ford 7.3 diesel. Forget the Chevy unless I'm driving empty!
nhill2090 is offline
Old 01-24-2013, 09:30 PM   #20
pizalm's Avatar
Rewards Points: 826
I love my diesel f350 towing, but maintenance is way higher than a gas half ton. And most of the time I don't need the truck I have, I could get away with a f150. Not to mention a half ton will ride way nicer.
pizalm is offline
QR Code size test BCConstruction Marketing & Sales 2 09-25-2012 10:09 AM
Box truck/ step van vs. Truck and trailer kyia Vehicles 12 12-06-2011 05:01 PM
What size truck and trailer? birdhunter Excavation & Site Work 5 09-19-2010 08:15 PM
Max Trailer size for Dodge Dakota 4 cylinder? ChadTheAnimal General Discussion 31 01-04-2010 04:22 AM
Trailer size activepainter Vehicles 27 12-26-2009 10:24 AM
