Starter? - Vehicles - Contractor Talk
Starter?
Old 02-21-2011, 10:05 PM   #1
MRstark44's Avatar
Rewards Points: 25
Starter?
So my 1997 F350 mason dump ran yesterday, and is dead this morning. Yesterday, I put my plow on at about 430pm and then at 1 this afternoon all i could get from it was a single click. Has this happened to anyone? is it the starter???
MRstark44 is offline
Old 02-21-2011, 10:06 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Starter?
battety? alt? belt? check the easy stuff first
Tom Struble is offline
Old 02-21-2011, 10:08 PM   #3
MRstark44's Avatar
Rewards Points: 25
Re: Starter?
batteries are fine, tried jumping, and even jumping with a power pack. everything on the dash is status quo. I sanded down the battery terminals, cleaned the connectors and still, just a click when the key is turned, then nothing. no noise, nothing...
Old 02-21-2011, 10:09 PM   #4
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 335
Re: Starter?
I am no mechanic, but is there a solenoid that you can cross?
Easy Gibson
Warren is offline
Old 02-21-2011, 10:13 PM   #5
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: Starter?
I would check the solenoid.
"Industry without art is brutality"
shanekw1 is offline
Old 02-21-2011, 10:52 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,355
Re: Starter?
Yep, solenoid would be the first stop after the battery.
Tinstaafl is offline
Old 02-21-2011, 11:14 PM   #7
New and Remodel Carpentry
cooks's Avatar
Trade: General Contractor/Remodelor
Rewards Points: 75
Re: Starter?
Check the cables that go down to the starter. I had this happen multiple times until i could trace it back to the starter. The cable was either loose or dirty. Cant tell which one as i pulled loose and cleaned at the same time. You can test this when it gives you nothing, crawl underneath and wiggle cables. Then try to start.
cooks is offline
Old 02-21-2011, 11:22 PM   #8
Trade: siding
Rewards Points: 20
Re: Starter?
usually you get a click that's your solenoid working,sounds like a cable or corroded terminal
Old 02-21-2011, 11:26 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Re: Starter?
Agreed, but that doesn't mean it's passing juice. I'd rather check that first before crawling underneath.
Old 02-22-2011, 12:12 AM   #10
Trade: siding
Rewards Points: 20
Re: Starter?
no i agree Tinmaster
Tinstaafl (02-22-2011)
Old 02-22-2011, 12:29 AM   #11
Willy is's Avatar
Trade: residential restoration
Rewards Points: 250
Re: Starter?
Solenoid, battery connections; remove and clean. wd-40, baking soda, vaseline, wrenches and you may be fine.
Never hurts to stick a charger on the battery while you are doing this.
You can trying jumping across the solanoid, or jumping bypassing the starter cable using jumper cables. Make sure you have a clean ground connection as well. Check the smaller wires that run to the soleniod as well, could be dirty/corroded
Be damned careful jumping if you don't know what you are doing.
Usually if it is a starter you'll get some noise, chatter, clicking. If you have a spare person have em tap the starter while you attempt to start the engine. It doesn't sound like this is la problema, but it's a last gasp try.
willy
Willy is is offline
Starter Fluting Jig Bergstrom Finish Carpentry 17 04-14-2011 08:18 PM
square d motor starter. [email protected]#e Electrical 4 04-16-2010 09:16 PM
Starter Row clips for CONCEALoc Swanny Decks & Fencing 2 07-15-2009 10:40 AM
The reason for rake starter strip? True North Roofing 40 11-23-2007 03:32 PM
Starter Website krthomp33 Electrical 6 08-12-2006 09:15 PM
