Sick Of Dump Trailer Flats @ Landfills - Vehicles - Contractor Talk
Old 08-13-2014, 01:07 PM   #1
TLP's Avatar
Trade: Engineer/GC
Rewards Points: 306
Anyone know of a solution, we get them all the time, and our g rated tires are $200 a pop if we don't catch the nail/etc and ruin the sidewall. All I could I find on the net and site search is this....
"In waste hauling applications where operators run trucks into and out of landfills, Woodruff said Goodyear’s DuraSeal Technology tires have become commonplace. “Our self-sealing tires really took hold because nails and other debris have the potential to puncture tires and disable a vehicle.”
http://www.goodyeartrucktires.com/ne...2152010tt.aspx
TLP is offline
Old 08-13-2014, 01:14 PM   #2
fugsly's Avatar
Trade: general
Rewards Points: 71
Re: Sick Of Dump Trailer Flats @ Landfills
Ummmm dumpster?
fugsly is offline
Old 08-13-2014, 03:07 PM   #3
deter's Avatar
Trade: Project Managment & hack-of-all-trades
Rewards Points: 44
stop driving over nails? I'm always quite careful about where I drive at the dump
Also, you can get TPMS systems for trailers - if you want to catch it sooner.
deter is offline
Old 08-13-2014, 07:05 PM   #4
Patrick's Avatar
Rewards Points: 2,364
I threw a bitch fit one day at the dump so usually if its not a zoo one of the loader guys drops his bucket which has rubber under it and drags a path from the scale to the tipping floor. We still keep our tire guys pretty busy though.
We have three dump trailers so we keep a few extra tireand wheels on hand to swap and rotate to the tire shop
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 08-13-2014, 08:47 PM   #5
Box Builder
Morning Wood's Avatar
Rewards Points: 10,368
I run a broom over the ground behind the trailer before I back up too far. Has been working so far. If you're really anal, you could also go over it with a magnet.
Morning Wood is offline
Old 08-14-2014, 06:14 AM   #6
TLP's Avatar
Trade: Engineer/GC
Rewards Points: 306
Last time it happen it wasn't even a nail, it was a chunk of metal I missed at the visual inspection. I usually kick dirt around where I plan on backing in.
Think I'll get me a square shovel clean out some tracks to the fill. I bet it more than likely happens close to fill.
Wish I could find a set of these....
http:////www.google.com/search?q=air...w=1351&bih=671
Looks like they make the "tweel" for skids now...
http://www.michelintweel.com/
Coming to a tire store near you...
http://http://gizmodo.com/bridgeston...ady-1469598671
Probably cost a fortune at first....Polarius, Michelin, and Bridgestone are behind it for now....
Thanks for the replies.
TLP is offline
Old 08-15-2014, 01:48 PM   #7
dkillianjr's Avatar
Rewards Points: 2,464
I was going to a local landfill, until one day I got a chunk of cast iron pipe in the sidewall of a trailer tire. I had no spare, so I ratchet strapped that wheel up as much as I could and drove it to the closest tire dealer.
I found a transfer station that's actually a little closer to me and pretty much the same pricing.
Now I just back into the warehouse and dump on the floor. I still will always walk behind the trailer and truck before I back all the way in. Sometimes with a broom.
dkillianjr is offline
Old 08-22-2014, 04:10 PM   #8
ESSaustin's Avatar
Trade: Hauling/trucking
Rewards Points: 384
I bought a pro tire plug gun from O'Reilly, cost was maybe $40. We just plug our own.
We run Cooper Discoverers on the trucks and trailers, bought from Discount Tire with warrentee. If tire is too damaged to plug, DT replaces it.
ESSaustin is offline
Old 08-22-2014, 04:18 PM   #9
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I keep a plug kit in the truck, and new tires once a year on all trucks and trailers. It's too bad because there is always so much tread left on then
jlsconstruction is offline
Old 08-22-2014, 04:39 PM   #10
TLP's Avatar
Trade: Engineer/GC
Rewards Points: 306
Yeh last side wall I ruined was a $200 brand new g rate. That Oreilly plug guns sounds like a good idea...thanks!
TLP is offline
Old 08-22-2014, 08:30 PM   #11
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
fill all yer tyres with green slime, it works, truck and trailer
sunkist is offline
Old 08-23-2014, 07:12 AM   #12
TLP's Avatar
Trade: Engineer/GC
Rewards Points: 306
I heard it doesn't work. Do you have in your tires now and had a puncture it sealed?
TLP is offline
Old 08-23-2014, 07:56 AM   #13
master hacker of wood
FRAME2FINISH's Avatar
Trade: restoration carpentry
Rewards Points: 1,730
That green slime doesn't work and it makes a mess when you change a tire!!
Put a bar magnet hanging off your bumper or trailer an inch off the ground!!
FRAME2FINISH is offline
The Following User Says Thank You to FRAME2FINISH For This Useful Post:
jb4211 (08-23-2014)
Old 08-23-2014, 09:01 AM   #14
TLP's Avatar
Trade: Engineer/GC
Rewards Points: 306
Is this the gun you are talking about online? My local store only had t-handle kits not sure I like those for g loads. Inserts that 'vulcanize' huh, wonder if they work? $110 ouch, well thats ll patches before an ROI.
http://www.oreillyauto.com/site/c/de...=tire+plug+gun
TLP is offline
Old 08-23-2014, 10:34 AM   #15
dougger222's Avatar
Trade: Roofing Contractor
Rewards Points: 1,116
Never hear of a plug gun sounds interesting.
As far as holes in trailers always seems like the back tires on the dump trailers get the most. Back when you never left pavement at the dump always got a lot of nails. Seen some guys get out of there trucks and magnet roll before they backed up. Problem with that was there's still nails everywhere.
I've found running higher quality tires like Michelin has greatly reduced holes in the dump trailer tires. Back when I ran cheaper tires my mechanic counted 16 plugs in one tire!!! I think for the first time ever I'll replace a set of Michelin tires on one of the dump trailers for wearing out. They were on the dually for the first half of there life but a BFG recall landed me 5 new Michelins. Bought a 6th and had the new ones put on the dually and the old ones on a dump trailer with spare.
I like to own my equipment and not end up with a pile of rental receipts at the end of the year. When we leave a tear off the driveway is clear of all debris.
dougger222 is offline
Old 08-23-2014, 12:09 PM   #16
Box Builder
I sweep the ground behind my trailer. Still amazing that I don't get more flats. Magnets are good but not for stainless. Just visually inspecting the ground as I sweep usually gets all fasteners. This week if I didn't sweep I would have backed over a ton of roofing nails.
Old 08-23-2014, 07:47 PM   #17
Wcceric's Avatar
Trade: General contracting/ carpentry
Rewards Points: 38
Might seem weird but how bout a couple magnets one behind each wheel that you can hook with chains while your waiting on line. Just thinking outside the box.
Wcceric is offline
Old 08-24-2014, 01:23 PM   #18
dougger222's Avatar
Thought about magnets attached to trailer and seen someone is manufacturing one. A little spendy but could pay for itself.
In the pit between 3 trailers pick up a nail every 3-4 months. I worry more about boards with nails in them. Last weeks got inches from a 1 by with half a dozen 8 Penny's in it. Would have messed up two tires.
Old 08-24-2014, 05:14 PM   #19
ESSaustin's Avatar
Rewards Points: 384
Yes that's the gun, although I didn't pay the extra $70 for the plastic case.
It works like a caulk gun.
Old 08-31-2014, 12:01 PM   #20
Board Shortener
Johnny_5's Avatar
Trade: Carpentry / Remodels
Rewards Points: 706
Seen this stuff used for motorcycle tires, seems it'll work with anything...
http://www.ride-on.com/
Johnny_5 is offline
low boy trailer kauai88 Sandblasting 24 05-08-2013 07:54 AM
Drywall Patch Flashes Through Paint BobbyCA Painting & Finish Work 18 05-04-2013 07:04 AM
Flat roof - What roofing system should I use? acro Roofing 10 04-15-2013 04:47 PM
A 5 x 10 dump trailer will hold how many squares? 232323 Roofing 9 05-08-2011 05:30 PM
Is a Carryon dump trailer decent? ranagent Vehicles 7 01-27-2011 07:16 AM
