Setting Up A New Trailer - Vehicles - Contractor Talk
Old 08-31-2018, 05:58 PM   #1
PecosBill's Avatar
Trade: General
Rewards Points: 14
After almost three months of waiting, my new trailer finally showed up. I'm starting to work on setting it up, and the flaws in my design are starting to appear.
First off, the basics. I ordered a 8.5'x24' car hauler. I had them push the man door back against the wheel well on the right side, and I added double 4' doors on the left side.
I wanted the double doors because I was planning on being able to load pallets in through the side, where I could then jockey them around with a pallet jack. And here is where I ran into my first problem. I tried it for the first time the other day, and when I went to raise the pallet jack, a wheel punched through the floor.
When I ordered the trailer, I specified 12" on center framing, and they said the 3/4" ply would be plenty strong enough... wrong. The manufacturer says it shouldn't have happened, and is repairing it under warranty, but I'm not trusting it. So I'm trying to come up with an ideas to keep this from occurring in the future. I am considering adding 1/4" aluminum diamond plate, which would run $1200+, and worse than that, deduct a few hundred pounds from the payload capacity. Does anybody else have any better ideas?
On another note, I have everything to add Ford's trailer camera, and am getting ready to tackle it, has anybody else installed one, and do they have any pointers?
PecosBill is offline
Old 08-31-2018, 07:25 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,888
Re: Setting Up A New Trailer
Raise the ball up on the truck or get an adjustable neck for trailer.
Not moving pallet jack over diamond plate very easily. Add 11 gauge steel.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
TimNJ (09-03-2018)
Old 09-01-2018, 02:38 PM   #3
tang's Avatar
Trade: Remodel contractor
Rewards Points: 549
Nice trailer!! Anxious to see how you set it up!! Post'em up when you get going.
tang is offline
Old 09-02-2018, 09:27 AM   #4
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
I'm going to give him the benefit of the doubt and say he's only using that receiver/ball combo to get the trailer home.
But as for the diamond plate, 100% concur.
Rolling anything on that would be a MAJOR headache
I'd go with the steel if pallets and jacks are a common business practice.
Aaron Berk is offline
Old 09-02-2018, 11:05 AM   #5
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,727
Make a spot for sheet goods on the passenger side. Most of the time the trailer is leaning to that side from the roads. So when you unstrap them they will stay in place.
Jay hole is offline
Old 09-03-2018, 07:55 AM   #6
TimNJ's Avatar
Rewards Points: 962
Nice looking trailer.
Maybe have them add some extra cross braces underneath to help stiffen the floor or for a cheap way out if you are only keeping the pallets in one specific area, double up the plywood.
TimNJ is offline
Old 09-05-2018, 10:19 AM   #7
PecosBill's Avatar
Trade: General
Rewards Points: 14
It's an adjustable hitch, I just had it low because I didn't tall enough blocks when I hooked it up. I really need to find a taller tongue jack for it.
I thought about steel, but this is Oregon, and wet shoes on steel seems a little iffy, plus the steel is significantly heavier. It is a lot cheaper though.
Old 09-05-2018, 10:23 AM   #8
Mordekyle's Avatar
Rewards Points: 6,504
You on the Wet-side?
Mordekyle is online now
Old 09-05-2018, 10:25 AM   #9
I like Green things
A pallet jack wont roll on diamond plate. 11ga. Isn't that heavy.
Warner Mill Works
Facebook
YouTube
Old 09-05-2018, 10:39 AM   #10
PecosBill's Avatar
Trade: General
Rewards Points: 14
I'm down in southern Oregon, but we still see quite a bit of rain during the season. We also travel throughout the state.
Old 09-05-2018, 10:40 AM   #11
PecosBill's Avatar
Trade: General
Rewards Points: 14
I'll have to look into that, thanks.
Old 09-06-2018, 12:07 AM   #12
Frank Castle's Avatar
Rewards Points: 4
To save on weight, just put a "track" of steel where the pallet jack will roll instead of the whole floor.
Just my .02¢
Adapt, Improvise, Overcome.
Frank Castle is offline
Old 09-15-2018, 12:19 PM   #13
PecosBill's Avatar
Trade: General
Rewards Points: 14
I haven't solved the floor problem yet, but the lettering has been done.
Old 09-15-2018, 06:51 PM   #14
Box Builder
Morning Wood's Avatar
Rewards Points: 6
You could skin over the floor with an additional layer of 3/4” underlayment. It would make your entry doors have a lip though.
What’s the GVWR of your trailer?
Morning Wood is offline
Old 10-07-2018, 11:56 AM   #15
PecosBill's Avatar
Trade: General
Rewards Points: 14
It's a 12,000# trailer.
I ordered some 10g steel to sheet the floor. There are now four 8'x12' sheets stacked in the middle of the trailer floor, just waiting for me to cut it up and install it. The steel ended up a little heavier than I planned, but I think the added strength will be worth it. Since this means 800+ lbs off the payload, I think I need to figure out a way to install removable racking and cabinets so they can be pulled when I need the full payload for cargo. Since I am doing this all myself, and already work 50-60 hours a week, plus am constantly out of town on the weekends, this might end up being the world's slowest trailer build.
I think the latest plan is to run e-track down both sides of the length of the trailer, then cut the steel sheet into it, and then spray the steel with Line-X. Anybody see any issues with this idea?
low boy trailer kauai88 Sandblasting 24 05-08-2013 07:54 AM
Watch your trailer weights! BCConstruction Tools & Equipment 24 04-15-2013 08:53 PM
What tow vehicle do you think would be best for a mobile blasting trailer? Blast Off Sandblasting 0 03-06-2013 02:06 PM
Trailer size & Truck size(towing capacity) Dmitry Vehicles 19 01-24-2013 09:30 PM
Drawer-Based Trailer Project (Lots of Photos) BuildersII Tools & Equipment 48 04-10-2011 11:12 AM
