Power Supply For Lights In Trailer. - Vehicles - Contractor Talk
Old 12-21-2014, 09:17 PM   #1
mako1's Avatar
Rewards Points: 1,094
Have a small trailer.12 ft. v nose .Just wondering what others do to [power some lights.There is one installed that is not bad but I need more and have one big one LED I'd like to install that would light up the back of the truck and trailer.
Not lookimg for types of lights but how to power them.The one in the trailer now does not work unless the truck is hooked up and running and the running lights are turned on.I know I could mount a battery to the tongue to run the lights but looking for a better option?
mako1 is offline
Old 12-21-2014, 10:44 PM   #2
tjbnwi's Avatar
Rewards Points: 2,810
Re: Power Supply For Lights In Trailer.
You want to run the lights without the truck connected to the trailer?
If so, a battery is your only best option. If you went with a small solar panel you would still need a battery to carry the load. Cord and inverter is impractical.
Wind turbine will not work on calm days.
tjbnwi is online now
CarpenterSFO (12-21-2014)
Old 12-21-2014, 11:25 PM   #3
mako1's Avatar
That's what I figured.Thought maybe someone here was smarter than I am.Should have known better
mako1 is offline
Old 12-21-2014, 11:35 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 678
Them's fightin' words.
Park the trailer beside a stream in which you have set up a waterwheel generator, hook it up and enjoy.
Hah! Didn't think of that one, did you?
Tinstaafl is online now
Old 12-22-2014, 12:14 AM   #5
Business Owner
JD@SBS's Avatar
Trade: Schluter Systems ASD, General Bathroom Remodeling
Rewards Points: 330
My trailer runs on a small Nuclear Reactor
But seriously I have seen quite a few motorcross trailers that had solar panels on top that charged a battery and ran a few lights that way.
I suppose you could also just tie your battery into your break away battery line, and have it charge that way, but I would look into it more before doing anything like that.
JD
JD@SBS is offline
Old 12-22-2014, 01:01 AM   #6
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Good thing you run on BS.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 12-22-2014, 01:48 AM   #7
concrete2013's Avatar
Trade: Concrete
Rewards Points: 260
You need a battery
concrete2013 is offline
Old 12-22-2014, 06:39 AM   #8
AustinDB's Avatar
Rewards Points: 1,470
How about rigging up a hand crank radio, like what was found around Y2K, to run those lights 😎
AustinDB is offline
Old 12-22-2014, 07:38 AM   #9
GTX63's Avatar
Trade: Contracting
Rewards Points: 694
My 20' cargo trailer has led rope lights. I keep a 2k invertor generator inside and anything that needs juice I just fire it up and plug them in. My gennie runs about 58 db so it isn't loud.
GTX63 is offline
Old 12-22-2014, 09:57 AM   #10
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,198
some lanterns or candles might work pretty good too.
Randy Bush is online now
Old 12-22-2014, 02:33 PM   #11
mako1's Avatar
I have seen the same and may look into it.Never thought of it until you posted.May mount a battery and look into a solar charger.It;s just getting dark to damn early these days.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
[email protected] (12-22-2014)
Old 12-22-2014, 10:10 PM   #12
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,719
At least we just turned the corner (winter solstice). Daylight hours are now getting longer each day. I can hardly wait. Enjoy.
MarkJames is online now
Old 12-22-2014, 11:10 PM   #13
Randy Bush's Avatar
Will be well into Jan before we even start to notice it here.
Old 02-23-2015, 11:23 PM   #14
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Certified Building Contractor
Rewards Points: 1,458
If that trailer has electric brakes just piggy back off the battery that runs the breaks in the event it disconnects from the truck. It will recharge from your seven way pig tail when you plug up the thing to haul it. Hook the blue wire from the seven way tail to the battery source with an inline fuse.
Builders Inc. is offline
Old 02-25-2015, 09:55 AM   #15
tgeb's Avatar
Rewards Points: 620
Originally Posted by Builders Inc. View Post
If that trailer has electric brakes just.... .....Hook the blue wire from the seven way tail to the battery source with an inline fuse.
The Blue wire operates the brakes.
www.gebcon.com
tgeb is offline
Old 02-25-2015, 12:52 PM   #16
GettingBy's Avatar
Rewards Points: 6,486
Have a huge capacitor that charges whenever the trailer is hooked to the vehicle and discharges to run the LEDs.
http://en.wikipedia.org/wiki/Supercapacitor
How long do you need the LEDs to light?
GettingBy is offline
Disabled Cruise ship stuck in Gulf... Stinks! CarrPainting Off Topic (Non Trade) 53 02-16-2013 12:36 AM
Trailer brake question dkillianjr Vehicles 10 03-30-2012 07:14 PM
Considering a 20' Trailer any pros/cons svon89 Vehicles 15 12-24-2010 01:42 PM
Power in trailer for battery chargers? Clydesdale Tools & Equipment 4 12-23-2009 11:09 AM
Trailer Heaters and Power jakejorgenson Tools & Equipment 3 12-10-2009 11:28 PM
