New Trailer Build! - Page 2 - Vehicles - Contractor Talk
New Trailer Build!
Old 03-06-2018, 01:20 PM   #21
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 938
Re: New Trailer Build!
Originally Posted by Bedfordboy116 View Post
I havenít decided yet. We needed them this week, but with the walk on roof, I donít think Iíll keep the big ones up there all the time. Probably keep one or two of the small ones. And yeah Iím pretty stoked to have this trailer now. Been pulling a flat nose 6x12 with a hole in the floor, and doors that you have to kick closed. Itís a major improvement.
Nice trailer, what did the ladder rack cost?
Big Johnson is online now
Old 03-06-2018, 01:29 PM   #22
Bedfordboy116's Avatar
Trade: Construction/Remodeling
Rewards Points: 162
Iím not exactly sure, but I believe the addition of the walk on roof was $600-800. They added 1/2 ply on the roof, double up every third rib on the ceiling, and add the ladder on the front of the trailer. The trailer was around $8,000 total.
Bedfordboy116 is offline
The Following User Says Thank You to Bedfordboy116 For This Useful Post:
Big Johnson (03-06-2018)
Old 03-06-2018, 03:02 PM   #23
Rewards Points: 162
Originally Posted by tang View Post
I would suggest painting the floor, to protect the plywood.
Mine came with treated plywood floor. My last trailer had the floor painted, and it was in terrible shape. No idea how long ago it had been done, but it was quite awhile.
Old 03-06-2018, 03:19 PM   #24
tang's Avatar
Trade: Remodel contractor
Rewards Points: 505
Originally Posted by SearchforSignal View Post
Does everyone build out their trailer with wood because of weight savings? Or cheaper? Both?
I'm eyeing these.. A few of them with my high capacity tool box will save me some time in building out drawers and shelves I think.
I ripped strips of 3/4"
ply, glued and screwed to the walls and floor as mounting cleats, to hang my boxes. Consider weight in your design, and load heavy to the front, and equally down each side. Leave a spot to slide in sheet goods, and lumber. A small bench area is nice for assembly. I would start with a templet of the nose. Grab some plywood, and go for it. Working out of a trailer is great once you get organized.
tang is offline
Old 03-06-2018, 03:51 PM   #25
tang's Avatar
Rewards Points: 505
Great idea, with the treated floor. My trailer was MUCH cheaper! I think it was $2.300 new. (single axle) I applied three coats of paint when I got it, and it has held up well. I prefer the barn doors, over the ramp, but it should be treated or painted IMO. Or it will go to **** quick.
tang is offline
Old 03-06-2018, 04:11 PM   #26
Donohue Const's Avatar
Rewards Points: 1,668
I have 3 tool boxes in mine
works good for organizing smaller stuff
Ryan
www.ryandonohueconstruction.com
Donohue Const is online now
The Following User Says Thank You to Donohue Const For This Useful Post:
META (11-10-2019)
Old 03-06-2018, 05:41 PM   #27
Rewards Points: 162
Mine has barn doors. I would get annoyed with a ramp. Mine is also double axle, which is nice. And itís aluminum.
Old 03-06-2018, 08:05 PM   #28
SearchforSignal's Avatar
Trade: Low voltage
Rewards Points: 712
Thanks. I am. Only reason I see it work building storage out of wood is the savings over metal tool boxes. I will start by insulating walls and ceiling once I get to tear into it.
SearchforSignal is offline
Old 03-06-2018, 08:07 PM   #29
Trade: Low voltage
Rewards Points: 712
The way I looked at it is I use my side door 90% of the time. If I need more accessibility then the ramp door will come down.
Old 03-06-2018, 10:23 PM   #30
Mordekyle's Avatar
Rewards Points: 5,594
Don't fall for the trap of loading every tool you have in your trailer.
I know someone who has a welder in his. Never used. Too much weight and space for a never used tool.
Mordekyle is offline
Old 03-07-2018, 05:57 AM   #31
Trade: Low voltage
Rewards Points: 712
No. Mine will be more for supplies as well. Really hate having to go to the store for one thing here and another thing her.
Old 03-07-2018, 06:26 AM   #32
The Sheriff
Jaws's Avatar
Rewards Points: 13,898
Nice and shiny!
Congrats
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is offline
Old 03-07-2018, 07:38 AM   #33
TimNJ's Avatar
Rewards Points: 5,700
Something to keep in mind, pressure treated against steel=not to good unless they laid some kind of isolation between the steel and the pressure treated.
I would keep an eye on it.
TimNJ is online now
The Following User Says Thank You to TimNJ For This Useful Post:
Bedfordboy116 (03-07-2018)
Old 03-07-2018, 08:06 AM   #34
Rewards Points: 162
The entire trailer is aluminum, including all the frame and wall/roof ribs. I would guess that would extend the life of the treated floor, but Iím no expert.
Old 03-07-2018, 08:16 AM   #35
Trade: Low voltage
Rewards Points: 712
Yeah I'm not worried about the floors. Though the plan is to do a undercoat and Rino line them as well
Old 03-07-2018, 06:44 PM   #36
Trade: Low voltage
Rewards Points: 712
Even without it organized, the trailer is already saving me time with having my stuff in one place and not in multiple places.
Old 03-08-2018, 08:18 AM   #37
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,074
Don't you find a trailer to be a huge pain in the ass when working in urban areas?
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
Old 03-08-2018, 08:34 AM   #38
Trade: Low voltage
Rewards Points: 712
I'm sure it will be a bit of a pain if I go downtown or in cramped area, but so far I don't think I will mind that asong as I have all my stuff where and when I want it.
Old 03-08-2018, 08:45 AM   #39
Trade: Low voltage
Rewards Points: 712
I did consider getting a high roof Ford transit, but having 4x4 and a truck was a positive. Having ability to unhook and just drive the truck around when need is nice.
Old 03-08-2018, 09:35 AM   #40
Trade: Low voltage
Rewards Points: 712
When you have to carry 20+ boxes of cat6 and coax. A trailer is going to be nice.
Estimating with Excel for the Small Contractor YouTube cargin2 Business 127 12-09-2019 12:06 PM
Watch your trailer weights! BCConstruction Tools & Equipment 24 04-15-2013 08:53 PM
What tow vehicle do you think would be best for a mobile blasting trailer? Blast Off Sandblasting 0 03-06-2013 02:06 PM
Kitchen Cabinet Build CITY DECKS INC Finish Carpentry 70 01-03-2013 07:51 PM
Drawer-Based Trailer Project (Lots of Photos) BuildersII Tools & Equipment 48 04-10-2011 11:12 AM
