NAPA Batteries: Never Again. - Vehicles - Contractor Talk
Old 01-04-2018, 11:09 PM   #1
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,402
Four years ago (December 2013), I noticed the battery in my war wagon was 8 years old. So I stopped at the local NAPA store and bought a replacement so I wouldn't have to worry about it for a few more years.
January 2015, it wouldn't hold a charge. I pulled it, and the ends were bulging out. So back to the store I go, battery and receipt in hand to get a warranty replacement.
December 2015, same thing. Won't hold a charge, and the ends were bulged out. I return it, but can't find my receipt. So I end up buying a third battery.
Yep, you guessed it. January 2017, it starts all over again. Even sitting overnight with the negative disconnected, it won't hold a charge. Pull it out, and the ends are bulging out. Again, back to the store I go, battery and receipt in hand to get a warranty replacement.
Now here we are starting out 2018. And............ the FOURTH BATTERY won't hold a charge. Yeah, it's damned cold out now, but it should at least turn on the friggin' LED dome light! You guessed it...... ends are bulging out like Oprah's love handles.
Now, swapping out the battery isn't a big deal. Pop the hood and in two minutes I've got it out with just a 5/16" socket. Drop it into my pickup bed and stop by for a replacement. Two minutes to reinstall. But dammit, it's a friggin' pain to have to drag out the engine starter just to go to work for the day.
Screw their warranty. Screw their batteries. Four strikes, they're OUT! NAPA = Not Another Pain in the Arse.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
Old 01-04-2018, 11:38 PM   #2
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
Re: NAPA Batteries: Never Again.
I only got a couple years out of my last Napa batteries and now my current ones have me worried. We rarely get very cold here but the last few morning have been in the 20's and it definitely didn't kick over like it usually does. I have 2 batteries so I have to change 2 at a time!
What are you going to change to?
SuperiorHIP is offline
Old 01-04-2018, 11:45 PM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,120
That sure seems strange it is bulging out the ends. Dumb question, but it is not over charging is it.
Randy Bush is offline
Old 01-05-2018, 12:04 AM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 3,275
Was thinking the same thing. Batteries bulge for a few reasons. Overcharging, to fast of a charge or to rapid of a discharge for to long of a period of time.
Especially if it keeps happening on the same vehicle. If you had this happen on different batteries in different vehicles then something would be out of sorts with the NAPA batteries.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 01-05-2018, 01:22 AM   #5
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
I agree, something else is going on. Recheck voltage as it should be between 13.7-14.3 volts. Check it with everything off and vehicle at 2,000RPM. Check it with a full load at idle, and at a higher RPM.
"Most aftermarket car batteries sold in the United States are made by three companies that build them for retailers: Johnson Controls, which supplies more than half of the market, Exide, and East Penn."
https://www.consumerreports.org/cro/...s/buying-guide
Peter_C is offline
The Following 2 Users Say Thank You to Peter_C For This Useful Post:
hdavis (01-05-2018), rrk (01-05-2018)
Old 01-05-2018, 02:47 AM   #6
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
yup
SmallTownGuy is offline
Old 01-05-2018, 07:18 AM   #7
SouthonBeach's Avatar
Rewards Points: 1,133
If I remember correctly Napa batteries are made by exide. Iíve never had an exide battery last any length of time. The best ones have been Johnson controls, followed by East Penn for long life.
SouthonBeach is offline
Old 01-05-2018, 07:43 AM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I'm pretty sure they have been DEKA for the past decade, which I think is made by East Penn.
Inner10 is offline
backhoe12 (01-09-2018)
Old 01-05-2018, 07:54 AM   #9
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 1,258
I just got a new battery for my van yesterday, did a little research and Walmart Maxx (made by JC I think) batteries came pretty highly recommended. The old battery was a NAPA. No bulges.
Big Johnson is online now
Old 01-05-2018, 08:37 AM   #10
hdavis's Avatar
Rewards Points: 1,006
The bulges happened when the battery froze. Weak cell or the battery didn't fully charge.
FWIW, some vehicles have an insulating sleeve around the battery to protect it from heat from the radiator or some other component. I've seen these get taken out and not put back in, so you go through batteries.
hdavis is online now
Old 01-05-2018, 08:40 AM   #11
LRG WoodCrafting
Leo G's Avatar
FWIW, some vehicles have an insulating sleeve around the battery to protect it from heat from the radiator or dome other component. I've seen these get taken out and not put back in, so you go through batteries.
OK, then there's 4 ways.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-05-2018, 08:59 AM   #12
hdavis's Avatar
Old 01-05-2018, 11:33 AM   #13
XJCraver's Avatar
Trade: Building Official
Rewards Points: 8
In my local NAPA store there are 2 kinds of batteries - red-stickered, cheap ones, and blue-stickered, more expensive ones. We go through a fair amount of batteries at the farm and have had pretty good luck with the blue-stickered ones. The red ones are crap, and we won't buy them.
I agree with the others up there though that if all this is happening in the same rig, it's probably not the batteries.
XJCraver is online now
Old 01-05-2018, 12:24 PM   #14
Railman's Avatar
Trade: Railing
Rewards Points: 989
Bad diode in alternator?
When they go bad, they still show up in voltage, but it's ac current instead of dc.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
hdavis (01-05-2018)
Old 01-05-2018, 01:40 PM   #15
They use to be exide around here. They could have changed though, itís been awhile.
Old 01-05-2018, 04:29 PM   #16
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,748
I have Napa batteries in everything. My Napa is a 2 minute walk from my shop and I buy everything I can there. They treat me great.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 01-05-2018, 06:44 PM   #17
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
This last cold snap, my truck had been parked for a week over Christmas. Battery calfed and would barely pop the solenoid.
Pulled the battery into the house over night, reinstalled in the morning and it fired right up.
No bulge to the case, and the posts were a bit skanky with corrosion, so cleaned that mess up.
Napa battery from early 2012, so it has paid itself off already. Usually get 5 to 7 years on a truck battery out here.
jlhaslip is offline
The Following User Says Thank You to jlhaslip For This Useful Post:
SmallTownGuy (01-06-2018)
Old 01-05-2018, 08:40 PM   #18
kapena's Avatar
Trade: General Building Contractor
Rewards Points: 336
A bulging battery is usually a sign of overcharging, which would indicate a faulty voltage regulator. Overcharging will overheat the battery and quickly kill it.
kapena is offline
Old 01-06-2018, 01:38 PM   #19
dayexco's Avatar
Rewards Points: 92
uncharged freezing batteries bulge also. i've had them split the case
dayexco is offline
The Following User Says Thank You to dayexco For This Useful Post:
hdavis (01-06-2018)
Old 01-06-2018, 01:56 PM   #20
hdavis's Avatar
I see that every winter, or almost every winter. I have about half a dozen used spares that if they lose too much of their charge, they freeze and bulge. Sometimes there is just one weak cell that freezes.
Landline cordless phone batteries VinylHanger Technology 11 03-11-2017 10:29 PM
A note to Makita about their batteries RobertCDF Tools & Equipment 130 06-17-2014 06:21 AM
WTS Milwaukee M12 Red Lithium 12v Batteries (4-6 For Sale) EDCivilian Contractor Swap 2 12-17-2012 11:47 AM
v18 batteries??? nwksremodeler Tools & Equipment 6 03-02-2010 01:48 PM
Batteries & cold temps Danno6102 Tools & Equipment 5 01-05-2009 11:04 PM
