It's The Last Night I'll See Her - Page 5 - Vehicles - Contractor Talk
Old 12-04-2012, 12:08 AM   #81
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Re: It's The Last Night I'll See Her
You PA guys get all the good weather. We have had 12" of rain in the last 4 days and more is expected tomorrow. A might chilly of highs in the 50's, as well.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
The Following User Says Thank You to redwood For This Useful Post:
superseal (12-04-2012)
Old 12-04-2012, 09:04 AM   #82
Tom M's Avatar
Rewards Points: 9,362
Originally Posted by superseal View Post
Some savvy eyed folks may realize I can no longer carry 4x8 sheets laying flat Don't bother me much as with this system there are 3 different ways of doing so,...On edge and roped, one wall leaf down on an angle or both leafs down and on top. The latter two might require some center support depending on how many sheets or what your carrying.
I normally just stand them up and rope them in unless I'm packed up with ladders.
Hey, tomorrow's supposed to be like 70 deg Golf anyone
The plywood was the first thing I thought about. If all leafs folded flat to the middle you would be fine. Then you could have had a cotter pin to hold the leaf into the tool box bracker. Maybe a slide latch or landscaping spikes through eye bolts to hold the second leaf up.
Tom M is online now
Old 12-04-2012, 09:09 AM   #83
master hacker of wood
FRAME2FINISH's Avatar
Trade: restoration carpentry
Rewards Points: 1,730
Bolt in some joist hangers and make a deck above the floor
FRAME2FINISH is offline
The Following User Says Thank You to FRAME2FINISH For This Useful Post:
dkillianjr (12-04-2012)
Old 12-04-2012, 07:58 PM   #84
Renaissance Man
superseal's Avatar
Rewards Points: 5,844
Your never too old for fresh ideas so keep them coming guys
Probably shouldn't have said I can't lay sheets flat, just not on the bed floor. Both leafs folded down will allow a full sheet to slide in flat, just elevated by a 2 x 12 on each side. If you picking up studs or other nominal lumber, it's easy to place that first, then lay your sheets on top.
Also talked to my alarm guy today who is ford certified and he's going to use the upgrade system ford offers which will utilize the same keypads as I have now. It won't have the auto window close feature since it not available, but the doors, glass, boxes and some type tow sensor feature are included. He's a mobile installer so the job is done where ever I want which is quite convenient.
Each day passing offers a little more progress as today I was able to craft of some box shelves using aluminum C-channel and birch plywood. Nothing fancy here just the basics that I'm use to.
Rock guard is getting bolted on today also which I made from 10ga steel and is what offers roof protection from loader dumps and such that inevitably happen from time to time. I think it's 15" wide with reverse bends on either side. Buffered on some rubber spacers and through bolted so shes stays put.
Also strung some cable for all the wonderful bungees I'm known to carry , but will also accommodate hooks, rope and whatever else I need hung.
It's the last night I'll see her-dodge-ram-2250a.jpg   It's the last night I'll see her-dodge-ram-2249a.jpg   It's the last night I'll see her-dodge-ram-2252a.jpg   It's the last night I'll see her-dodge-ram-2254.jpg   It's the last night I'll see her-dodge-ram-2255a.jpg
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 12-04-2012, 08:12 PM   #85
Renaissance Man
superseal's Avatar
Hey, what do ya know,...got a few bungees on the truck already
Old 12-04-2012, 11:33 PM   #86
Renaissance Man
superseal's Avatar
Went out to the garage tonight to fiddle with the shelves I made earlier and did a dry fit,...Nice cup of coffee and some tunes and I'm actually enjoying this part of the fit out.
I leave two boxes full size and place center shelves in the remaining two. Adds a little bit of flexibility in storage so it work for me.
Little change of plans in terms of the rubber liner I bought earlier - decided to carpet the bottom with that interior /exterior carpet the big box sells and I'll use the rubber runner for sections of the back side.
I'll partition off the end of the shelf so stuff don't fly around from box to box and that should do it.
Might be able to start loading some tools in here tomorrow guys and believe me,...it's good feeling.
A lot of damn work putting this truck together I'll say
It's the last night I'll see her-dodge-ram-2263a.jpg   It's the last night I'll see her-dodge-ram-2264a.jpg   It's the last night I'll see her-dodge-ram-2265a.jpg   It's the last night I'll see her-dodge-ram-2269a.jpg   It's the last night I'll see her-dodge-ram-2270a.jpg
The Following 2 Users Say Thank You to superseal For This Useful Post:
dkillianjr (12-04-2012), redwood (12-05-2012)
Old 12-05-2012, 05:43 PM   #87
Renaissance Man
superseal's Avatar
Here's the partitions I needed to make,...two fold in effect as a support
and partition to keep gear in their respective boxes. Had a little 3/4 birch plywood hanging around, so that's what I used
I'm gluing down the rubber material with flo free gutter top adhesive and it's workin' pretty nice. Don't want to completely partition the boxes as I store longer levels and such, just enough to keep things in place.
Thought it was supposed to rain today
It's the last night I'll see her-dodge-ram-2271a.jpg   It's the last night I'll see her-dodge-ram-2272a.jpg   It's the last night I'll see her-dodge-ram-2273a.jpg   It's the last night I'll see her-dodge-ram-2274a.jpg   It's the last night I'll see her-dodge-ram-2275a.jpg
Old 12-05-2012, 06:02 PM   #88
Renaissance Man
superseal's Avatar
Did the other side the same way,...Added a few gussets along the partition to stiffen it up and it looks pretty good. Only thing i want to do is support midspan with an small angle which I'll stick right to the rubber wall.
Looky here, I'm starting to put stuff in already
It's the last night I'll see her-dodge-ram-2281a.jpg   It's the last night I'll see her-dodge-ram-2283a.jpg   It's the last night I'll see her-dodge-ram-2284a.jpg   It's the last night I'll see her-dodge-ram-2285a.jpg   It's the last night I'll see her-dodge-ram-2287a.jpg
Old 12-05-2012, 06:23 PM   #89
Renaissance Man
superseal's Avatar
So how does one go about stickin' a small angle to a rubber wall without drilling more holes ?...Improvise
Since I'm just using various material I got laying around to do these and no real blueprint, you just swing it.
Had some 3M window tape and steel angle I seen laying around so I joined them up. Once the glue sets on the rubber, I'll peel and stick this sucker right under the center of the shelf and I should be golden.
Yea right, watch the whole thing come crashing down once the glue and tape fails
Hey, here's a good daylight shot of my rock/roof guard
It's the last night I'll see her-dodge-ram-2298a.jpg   It's the last night I'll see her-dodge-ram-2299a.jpg   It's the last night I'll see her-dodge-ram-2297a.jpg   It's the last night I'll see her-dodge-ram-2293a.jpg   It's the last night I'll see her-dodge-ram-2294a.jpg
dkillianjr (12-05-2012)
Old 12-05-2012, 08:25 PM   #90
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,272
That 3m VHB holds like a mofo! I love that stuff!
overanalyze is online now
Old 12-05-2012, 10:26 PM   #91
Renaissance Man
superseal's Avatar
Went back out tonight trying to take advantage of the mild weather we've had the last couple of days, but a cold front is brewing. Winds picked up big time and it's chilly out here tonight
Just a few finishing touches with the angle placement and door guard material I had left over from the dodge. Stuff has been sitting in my attic for about 16 years but it still looks pretty good.
Every time I scrape my hand on this piece, I tell myself to do it,...just never found the time or energy I suppose. What a nice fit, looks like it was made for this purpose
I knew there was a reason I like my Makita radio
It's the last night I'll see her-dodge-ram-2302a.jpg   It's the last night I'll see her-dodge-ram-2305a.jpg   It's the last night I'll see her-dodge-ram-2306a.jpg   It's the last night I'll see her-dodge-ram-2308a.jpg   It's the last night I'll see her-dodge-ram-2309a.jpg
Old 12-06-2012, 01:02 PM   #92
President
CarrPainting's Avatar
Trade: Residential Repaints
Rewards Points: 1,316
Ah yes, so many options, so few bucks
Just have to pace myself I guess
I know the feeling! But your truck is coming along very nicely and looks great! Im not a big fan of working out of a pick up, but to each his own..
I took me 4 years to 'build' my personal truck into the truck I really wanted...
From this:
[IMG][/IMG]
to this:
[IMG][/IMG]
Dont mean to hijack your thread or anything
Originally Posted by Easy Gibson View Post
Explain like I'm five. Thanks.
CarrPainting is offline
The Following User Says Thank You to CarrPainting For This Useful Post:
superseal (12-06-2012)
Old 12-06-2012, 03:33 PM   #93
Renaissance Man
superseal's Avatar
From this:
[IMG][/IMG]
to this:
[IMG][/IMG]
Nice,...My fav color too!
Old 12-07-2012, 01:11 AM   #94
bpg's Avatar
Trade: carpenter
any pictures fully loaded????????? do you you store tools behind the seat also ?
bpg is offline
Old 12-07-2012, 03:53 PM   #95
Renaissance Man
superseal's Avatar
Not fully loaded yet,...still workin' on a plan for the back seat as I do use this space often.
Thinkin' about removing the seat assembly and maybe some van style wall shelves.
No worries, I'll keep ya posted...
Old 12-07-2012, 04:02 PM   #96
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: Finish carpentry, drywall, Tile
Back seat pictures a must!!!! Ive been needing to do something to mine and Im back and forth on what to do
mnjconstruction is offline
Old 12-08-2012, 05:18 PM   #97
Renaissance Man
superseal's Avatar
Since I've lately been decreasing payload capacity by piling equipment on ,...I've decided to do an about face and shed a few pounds if you will
Lets see here,...how the hell does this thing come out
Pretty easy actually. As long as you have the proper metrics and t-55/60 torx, you'll be alright. Seat cushions were no sweat,...back rest was another story Where the hell are those release clips anyway
Wow,... really opens up this space and gives me an idea of what I'm dealing with in terms of storage design.
Although, I got my ideas,...I'd love to hear what some others think.
I know my alarm guy will be happy with the access back to the boxes now so that should make his job a bit easier.
Hey, anyone need superseals 2012 superduty supercab rear seat
Try saying that 10 times real fast
It's the last night I'll see her-dodge-ram-2318a.jpg   It's the last night I'll see her-dodge-ram-2317a.jpg   It's the last night I'll see her-dodge-ram-2319a.jpg   It's the last night I'll see her-dodge-ram-2320a.jpg   It's the last night I'll see her-dodge-ram-2321a.jpg
dkillianjr (12-08-2012), overanalyze (12-08-2012)
Old 12-08-2012, 05:38 PM   #98
Renaissance Man
superseal's Avatar
I finally found the three clips that need to be released to remove the backrest and put the seat in long term storage. I never took the dodge one out although I probably should have as it really does open up some space.
Been looking into van style shelves and been tossing around making whatever I need to fit it out. Came across a wiring harness, which during assembly became severely pinched in place which made me hair stand up , so I fixed that along the way.
Looks like I got a blank slate here folks - lets get some ideas rolling
It's the last night I'll see her-dodge-ram-2323a.jpg   It's the last night I'll see her-dodge-ram-2324a.jpg   It's the last night I'll see her-dodge-ram-2325a.jpg   It's the last night I'll see her-dodge-ram-2326a.jpg   It's the last night I'll see her-dodge-ram-2327a.jpg
Old 12-08-2012, 05:44 PM   #99
Always Learning
I was going to ask if you were going to add some helper springs or bags. We have an F-250 and I like the ride and it can tow plenty...but it always looks like the ass is sagging.
Old 12-08-2012, 05:51 PM   #100
Renaissance Man
superseal's Avatar
I wish the ass would sag a bit - damn near need a step ladder to get up the tailgate still.
Still haven't thrown a ton or two on her so I'll keep you posted on that one.
Why do plumbing disasters happen at night? VinylHanger Plumbing 6 01-18-2012 11:44 AM
Night stop/night seal help, please Walason Roofing 4 03-20-2009 12:11 AM
