Installing Brakes On A Trailer - Vehicles - Contractor Talk
Old 02-21-2019, 12:10 PM   #1
GC/carpenter
Calidecks's Avatar
Rewards Points: 16,540
If I drill a 3/4" hole on the opposing side of the wire harness that the manufacturer drilled, (on the Square tubing) . Will it weaken the strength to much? This is all hypothetical speaking.
Ideally I would like to phish my wire through the tubing and install a grommet.
Mike.
_______________
Calidecks is online now
Old 02-21-2019, 01:03 PM   #2
TheConstruct's Avatar
Rewards Points: 900
Re: Installing Brakes On A Trailer
As long as the hole doesn't exceed 1/3 the depth of the joist... oh wait.
Sounds safe to me but I have no idea. Interested to see pics of the install though.
TheConstruct is online now
The Following User Says Thank You to TheConstruct For This Useful Post:
Calidecks (02-21-2019)
Old 02-21-2019, 01:32 PM   #3
rrk's Avatar
Rewards Points: 1,486
could always use conduit clamped to frame
rrk is online now
The Following 2 Users Say Thank You to rrk For This Useful Post:
Calidecks (02-21-2019), TimNJ (02-21-2019)
Old 02-21-2019, 02:25 PM   #4
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 800
You could run it down the other frame rail, or make the new hole a few inches away from that existing one so it is not creating a possible weak area.
Or better yet, see if there is enough room to run the new wires through that existing grommet.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
Old 02-21-2019, 02:58 PM   #5
GC/carpenter
Calidecks's Avatar
Actually I just came though the existing. Thanks gentlemen.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
tgeb (02-21-2019), TheConstruct (02-21-2019)
Old 02-21-2019, 02:59 PM   #6
GC/carpenter
Calidecks's Avatar
Yep that's what I did.
Mike.
_______________
tgeb (02-21-2019)
Old 02-21-2019, 04:02 PM   #7
GC/carpenter
Calidecks's Avatar
Tom didn't you say the color codes are different in that junction box?
Mike.
_______________
Old 02-21-2019, 05:58 PM   #8
TimNJ's Avatar
Rewards Points: 4,364
https://www.etrailer.com/tv-demo_tra...nd_wiring.aspx
Those guys are good source of info for anything trailer related.
TimNJ is offline
Old 02-21-2019, 06:47 PM   #9
GC/carpenter
Calidecks's Avatar
That's where I got all my parts. But it's no help for what I needed. I figured it out so I'm good.
Mike.
_______________
TimNJ (02-21-2019)
Old 02-21-2019, 08:40 PM   #10
tgeb's Avatar
Rewards Points: 800
Mike.
_______________
What I had read in the reviews was that the wires , coming from the molded plug, may not match up with the circuit that they are supposed to.
It seems that some are correct and others are not. That's why I suggested that you test the wires and not rely on the color code.
Sent from my SM-G930P using Tapatalk
www.gebcon.com
tgeb is online now
Old 02-22-2019, 06:00 PM   #11
GC/carpenter
Calidecks's Avatar
Success
Mike.
_______________
Old 02-22-2019, 06:32 PM   #12
tgeb's Avatar
Rewards Points: 800
Looks good Mike!
That junction box makes it easy to do a professional job that will be trouble free.
How did the brake add-on at the wheels go?
www.gebcon.com
tgeb is online now
Calidecks (02-22-2019)
Old 02-22-2019, 08:40 PM   #13
GC/carpenter
Calidecks's Avatar
Looks good Mike!
Went great. Replaced the bearings and seals as well. I do have a question about that. How do you know when you have enough grease and can you put in to much? I did pack each bearing first in the tacky ****. Also how much trailer gain does one need and how do I know ?
Mike.
_______________
Old 02-22-2019, 08:47 PM   #14
TimNJ's Avatar
It will be hard to set the gain at first.
Every new trailer I got it took a 100 or so miles for the brakes to "set".
At first you could max the gain out to get the brakes to grab and then once they set you would dial it way back.
The heavier the load the more gain it will take.
Also the truck's controller factors in. When I had my Chevy the gain was really sensitive and I could run it on 3 with a light load and lock the brakes.
My Ram I have now is opposite. Light load and I have it up on 6.
TimNJ is offline
The Following 2 Users Say Thank You to TimNJ For This Useful Post:
Calidecks (02-22-2019), tgeb (02-22-2019)
Old 02-22-2019, 08:55 PM   #15
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,970
You need to do some test stops to set the gain to just before the trailer wheels lock up. Basically if your trailer tires lock up at seven then you want to back off the gain to six or five
When towing, the trailer should not push you at all
If youíre constantly changing the load in your trailer youíll have to add or subtract gain
When My dump trailer when is empty(2200 lbs) i have it set at five, and fully loaded (10k) i kick it all the way up to 10.
Even when Iím towing nearly 11,000 pounds the truck does not really take any longer to slow down than when itís lightly loaded
Windycity is online now
The Following 2 Users Say Thank You to Windycity For This Useful Post:
Calidecks (02-23-2019), tgeb (02-22-2019)
Old 02-22-2019, 08:58 PM   #16
tgeb's Avatar
Rewards Points: 800
I agree about setting the gain, it's kind of hit and miss.
I'm not familiar with your controller but I set mine so that it will lock the wheels in loose gravel when empty, then back it off. Adjust as needed to get a smooth engagement. You don't want to have the wheels locking up.
As far as the grease, if those are "easy lube", you add grease through the fitting in the center of the axle until grease pushes out through the outside bearing.
www.gebcon.com
tgeb is online now
Old 02-22-2019, 09:19 PM   #17
GC/carpenter
Calidecks's Avatar
Yep they are easy lube
Mike.
_______________
Old 02-22-2019, 09:34 PM   #18
tgeb's Avatar
Rewards Points: 800
Here ya go.
If you have already repacked the bearings as shown in the second video, I wouldn't worry about adding grease at this time.
www.gebcon.com
tgeb is online now
Old 02-22-2019, 10:12 PM   #19
Juan80's Avatar
Trade: General contractor
Rewards Points: 490
As far as the setting , I drove in a big parking lot at 15-20 mph , engaged the controller and slowed down.
No skids and no prolonged slowing .
The heavier the more gain.
My dump trailer when loaded runs at 6.5 /7
Good luck,Charlie
Sent from my iPad using Tapatalk Pro
Juan80 is offline
The Following User Says Thank You to Juan80 For This Useful Post:
Old 02-22-2019, 11:46 PM   #20
GC/carpenter
Calidecks's Avatar
https://www.youtube.com/watch?v=XT0RKDGgDm8
https://www.youtube.com/watch?v=GnH-h3W9XvI
Here ya go.
That's exactly what I did. Put a big goop in my palm and forced it into the bearings. The only thing I didn't do was put grease around the seal. The green one. I hope that doesn't present a problem.
Mike.
_______________
tgeb (02-23-2019)
Job site trailers, show off your set ups! Joasis Tools & Equipment 3002 04-27-2019 05:59 AM
Installing grab bars in fiberglass tub shelf guy Kitchens & Baths 26 09-22-2015 01:42 AM
Trailer Power/ Electricity Inside POWER STROKE Vehicles 24 08-26-2012 05:16 PM
installing 250 cfm compressor into enclosed trailer JohnnysMB Sandblasting 44 12-31-2010 11:03 AM
Trailer Heaters and Power jakejorgenson Tools & Equipment 3 12-10-2009 11:28 PM
