I Made A Maintenance Mistake. - Vehicles - Contractor Talk
Old 03-27-2019, 01:47 PM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 15,486
I've been wanting to replace the starter-battery cable on my van for a while. Probably about twice a year on damp days it's kind of a jerk about starting after you drive it for a little. Weird, I don't know. Whatever. You can solve it by disconnecting the terminals and cleaning them off with a wire brush, which just takes a minute, but is annoying and makes you look like kind of an idiot if you're in the parking lot of the coffee spot in front of a bunch of other cops and contractors.
"No thanks, I'm fine. No, it's not the cap and rotor."
So finally today I got time to replace it. Warm day, sunny, nothing but shop work on the horizon this week and next. Let's party.
Took the cable off, which involved my neck straining and hand grime.
Turns out, the 96" side post 2 gauge cable is like a damn unicorn!
Dealship discontinued it and nobody else carries anything larger than 78". I could get it made at one of the big box auto places but it'd be in 4 gauge, which is smaller than the OEM's.
Amazon to the rescue, but it's not getting here until Friday. Well dang.
Hoping I've got everything I need for this project on site, of that whatever I don't have can fit in an Impala.
There's probably a lesson to be learned here. Not sure what it is, but there probably is one.
Easy Gibson is online now
Old 03-27-2019, 03:20 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,773
Re: I Made A Maintenance Mistake.
Maybe it would have been better to just replace the cable ends, dab a little bit of dielectric grease on the terminals, and get a new battery from Costco.
MarkJames is online now
Old 03-27-2019, 05:23 PM   #3
rrk's Avatar
Rewards Points: 3,260
He also could have gone to a welding supply house 8 miles away and they would have made one
rrk is online now
The Following 2 Users Say Thank You to rrk For This Useful Post:
dayexco (03-30-2019), SmallTownGuy (03-30-2019)
Old 03-27-2019, 06:49 PM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,336
Just got a new battery. My post clamps are shot too.
I'm going to get the heavier style clamps with 2 ga but only need 12"-15" leads.
Gonna pigtail old with new --- tape the coupling up --- leave the rest spooled up in the engine compartment.
Steve
We Fix Houses is offline
Old 03-27-2019, 06:52 PM   #5
I've done that already. I'm pretty sure the cable itself is cooked. Might have something to do with the time I literally set the starter on fire. I don't know. You can't prove that.
I really need a welder in my life. I've never known a welder or really any metal fab guys and I feel like I'm poorer for it.
Anyways, near-oem part is on the way, so I think I'll live.
The Following User Says Thank You to Easy Gibson For This Useful Post:
MarkJames (03-27-2019)
Old 03-29-2019, 08:38 PM   #6
Well, I fixed most of the problem.
That is, the new cable gives me just enough oomph in the voltage to be able to tell now where the rest of the problem is coming from. What's nice is there really aren't that many parts in these old trucks. Even if I replace every single piece of the truck individually, I'm really only looking at a couple grand, which is way cheaper than what they're selling these things for nowadays.
Silver linings everywhere.
The Following 2 Users Say Thank You to Easy Gibson For This Useful Post:
hdavis (03-30-2019), SouthonBeach (03-29-2019)
Old 03-30-2019, 04:06 PM   #7
Ok, I did it.
Ignition wire leading to the bulkhead connector had a loose terminal.
Weeeeeeee doggy. Zero dollars!
hdavis (03-30-2019), Rio (03-30-2019)
Old 03-30-2019, 07:17 PM   #8
hdavis's Avatar
Rewards Points: 1,556
FWIW, I if you need a long wire for the starter, cannibalize some cheap jumper cables that are the right gauge.
Boom, done.
hdavis is offline
The Following 3 Users Say Thank You to hdavis For This Useful Post:
mrcat (03-30-2019), Rio (03-30-2019), SmallTownGuy (04-02-2019)
Old 03-31-2019, 12:09 AM   #9
Thanks.
Got the near-oem part online for about $30, which is fine.
This dragon is slayed. Now I can go looking around for something else suboptimal to occupy my mind while I drive around from job to job.
Old 04-02-2019, 02:10 AM   #10
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,345
loose, bad battery connections will warm/HOT to touch after a few seconds cranking....
Check the ground lugs too...
my Silverado has short side mount cables that run at 3:00 pm, and self loosen from road bumps, a few extra cable ties help.
check that all ground straps are replaced over the years, some times an added ground strap parallel to the stock one increases starting rpms and Amperage.
In My big stereo days, every truck had TWO batteries,,,
Fouthgeneration is offline
Old 04-02-2019, 06:29 AM   #11
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Boom, done.
I drove a poncho all winter with cables clamped on under the hood.
No need to ruin a perfectly good set of jumpers !
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
Fouthgeneration (04-02-2019), hdavis (04-02-2019)
1927 Oliver 117-A Bandsaw Restoration..... PrestigeR&D Tools & Equipment 49 01-12-2014 11:35 AM
Porter Cable Millworker Tools & Equipment 55 11-01-2013 05:42 PM
Hard earned money on foreign made tools (RANT) Irishslave Tools & Equipment 45 07-09-2010 12:01 AM
American Made wallmaxx Tools & Equipment 13 11-24-2008 06:16 PM
