How To Remove Thick Paint From Radiator?? - Vehicles - Contractor Talk
Old 02-16-2015, 01:49 PM   #1
burntside bob's Avatar
Trade: excavating
Rewards Points: 95
I want to remove many layers of paint from a radiator.
The radiator is fine not thing wrong with it, just to much paint on it, when its very hot the temp of oil in radiator increases even with fan running.
Question is what removes several layers of paint on a radiator?
burntside bob is offline
Old 02-16-2015, 01:52 PM   #2
Tom M's Avatar
Rewards Points: 4,216
Re: How To Remove Thick Paint From Radiator??
Heat?
Tom M is offline
Old 02-16-2015, 02:00 PM   #3
Trade: excavating
Rewards Points: 95
Not heat, I do want to melt the sodder sealing the fins.
Thank you for your reply.
Old 02-17-2015, 12:03 AM   #4
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Like a car radiator? Or an old boiler radiator found in old homes?
Try the orange paint remover at depot. Stuff works great and is safe.
www.callbathdoctor.com
Driftweed is offline
Old 02-17-2015, 01:14 AM   #5
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,428
I think they are typically shot blasted. This old house had a segment on them.
Metro M & L is offline
Old 02-17-2015, 07:37 AM   #6
rrk's Avatar
Rewards Points: 1,970
Car/machine radiator I believe.
A house rad would not have a fan.
rrk is online now
Old 02-17-2015, 08:36 AM   #7
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 834
http://www.bencosales.com/
pinwheel is online now
Old 02-17-2015, 09:52 AM   #8
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
As mentioned above this stuff works great. I've used it a bunch. On the flip this paint has been baked over and over. What type of radiator? Theres probably a bunch of led (spelling) there so I would ventilate well and if possible use a respirator how ever you tackle it.
kingcarpenter is offline
Old 02-17-2015, 11:53 AM   #9
giantfan's Avatar
Trade: Custom Home Builder
Rewards Points: 63
Use this stuff all the time..... works great!
https://www.dumondchemicals.com/home-peel-away-1.html
giantfan is offline
Old 02-17-2015, 12:05 PM   #10
rrk's Avatar
It is a car radiator
rrk is online now
Old 02-17-2015, 08:14 PM   #11
Trade: excavating
Rewards Points: 95
The radiator is on my small wheel loader. Its a Deutz oil cooled engine.
After a couple paint jobs it has a problem of cooling the oil when the air temp is hot in the 90's.
Old 02-17-2015, 08:17 PM   #12
rrk's Avatar
Not an easy one to replace either I guess?
rrk is online now
Old 02-18-2015, 01:01 PM   #13
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
I would try heat, a heat gun wouldn't get it hot enough to melt the solder.
Call around to a radiator shop and see how they do it. I'd guess blasting or chemical bath.
1985gt is offline
Old 02-18-2015, 07:57 PM   #14
TimNJ's Avatar
Rewards Points: 4,850
Take it to a radiator shop.
They will cook it inside and out. If the tubes have crud in them it will help restore the cooling.
TimNJ is online now
The Following User Says Thank You to TimNJ For This Useful Post:
woodchuck2 (02-24-2015)
Old 02-23-2015, 05:41 PM   #15
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
Purple Power will melt the paint off of the aluminum fins. You can get it at most auto parts stores. Lightly cut it with water, spray it with a spray bottle. Then use a garden hose to wash the paint away. Trojan Loader?
JAH is offline
Old 02-24-2015, 08:52 AM   #16
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
I agree with Timnj. If it is a hard to find radiator it would be well worth having flushed, dipped, pressure tested and flow tested. When finished they will paint it black like original. Money well spent IMO.
woodchuck2 is offline
Old 02-24-2015, 09:08 AM   #17
summithomeinc's Avatar
Trade: Painter/Handyman
Rewards Points: 2,422
Laquer thinner. Don't smoke and make sure nothing is hot around it.
I need more tools.
summithomeinc is offline
Pre-finished paint problems CompleteW&D Painting & Finish Work 13 05-29-2013 10:39 AM
Paint chipping Dpear Painting & Finish Work 8 05-28-2013 11:23 AM
[Leaking Roof] how do I remove old mastic/elastomeric coating? plasticslug Roofing 1 01-26-2013 06:24 PM
Best paint / advice for aluminum siding? Jdub2083 Painting & Finish Work 15 07-12-2012 01:15 AM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
