Ford Transit - Making The Big Switch - Page 50 - Vehicles - Contractor Talk
Old 11-25-2013, 02:00 PM   #981
Tall Moose
Nepean GC's Avatar
Rewards Points: 179
Re: Ford Transit - Making The Big Switch
You running snow tires Mike?
Nepean GC is offline
Old 11-25-2013, 02:08 PM   #982
Oconomowoc's Avatar
Trade: construction
Rewards Points: 2,000
No, but I've heard those Blizaks are good. I'm not sure what to do? I've always had big 1 tons and they never really slide.
Kind of a new experience for me here.
Oconomowoc is offline
Old 11-25-2013, 02:15 PM   #983
Tall Moose
Nepean GC's Avatar
Rewards Points: 179
Coming from the land of snow and cold... Snow tires are where it's at for small light vehicles. I typically run a bit narrower tires in the winter than summer. It helps the tires cut through the snow and get grip. Oh, and make sure you get a separate set of rims for winter. It's just more efficient for changeover in spring/fall.
I run Michelin XI2 on my 2WD Ranger, and I don't have any issues.
Old 11-25-2013, 02:17 PM   #984
Oconomowoc's Avatar
Trade: construction
I'll check in to those today. Thanks for the tip.
Old 11-25-2013, 05:01 PM   #985
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
As long as you have decent all seasons that are fairly skinny you should be fine w/o snows.
Inner10 is offline
Old 12-05-2013, 12:02 PM   #986
Santi78342's Avatar
Trade: Flooring
Rewards Points: 160
Any updates on this thing?
Santi78342 is offline
Old 12-05-2013, 12:08 PM   #987
Oconomowoc's Avatar
Trade: construction
Ran out of rivets. On order.
Working on a rack for lav and toilet supplies that will hang on the door.
Old 12-05-2013, 05:28 PM   #988
Northwood's Avatar
Rewards Points: 266
I looked through and couldn't find a detailed shot of the inside corners. If you get a chance do you mind taking a pic showing how you put them together
Northwood is offline
Old 12-05-2013, 05:37 PM   #989
Oconomowoc's Avatar
Trade: construction
Absolutely.
Old 12-05-2013, 07:45 PM   #990
Oconomowoc's Avatar
Trade: construction
It's just a straight piece of angle with a square notch cut out of only one side.
I cut it with a hack saw in just a few seconds then filed it, then sanded it.
Super easy.
The Following 2 Users Say Thank You to Oconomowoc For This Useful Post:
aptpupil (12-06-2013), dkillianjr (12-05-2013)
Old 12-05-2013, 10:51 PM   #991
Burns-Built's Avatar
Trade: Residential Construction & Masonry
Rewards Points: 434
The Ford Transit is ridiculously dangerous in snow.
I second that. You would think.. front wheel drive van... should do good in snow. Lol. It would probably be better with out one ton in the back.
There will always be a market for quality.
Burns-Built is offline
Old 12-06-2013, 10:24 AM   #992
Tall Moose
Nepean GC's Avatar
Rewards Points: 179
Have either of you guys put snow tires on yet? I'm genuinely curious if that helps. It appears they are specd with low rolling resistance tires which I find suck at the best of times.
Old 12-06-2013, 10:26 AM   #993
Oconomowoc's Avatar
Trade: construction
I've talked to a couple guys who swapped tires and it didn't help at all.
It's not a tire problem
Old 12-06-2013, 10:33 AM   #994
Oconomowoc's Avatar
Trade: construction
It's a design flaw. These have that traction control system where the vehicle slows down to like 2 mph. I was going up a hill in the last snow storm and the tires slipped just a little. Immediately the anti slip lights go on and I couldn't barely move, then it grabbed, then I slid sideways. It's very dangerous, there's no natural feel to it like on a rear wheel drive van.
Old 12-06-2013, 10:33 AM   #995
Tall Moose
Nepean GC's Avatar
Rewards Points: 179
That sucks. Keep a recovery strap on board I guess!
Old 12-06-2013, 10:36 AM   #996
Tall Moose
Nepean GC's Avatar
Rewards Points: 179
Ahhh! that explains it! I drove a Smart car that behaves like that. It was unbelievably frustrating. Fortunately traction control (and ABS at the same time) could be shut off with a simple jumper on the OBD2 connector. I wonder if turning off TC is possible on the Transit.
Edit : Found a link with info on which fuse pertains to the traction control. Might be worth trying on a quiet side rd. http://www.justanswer.com/ford/7ecqi...-traction.html
Old 12-06-2013, 11:07 AM   #997
Inner10's Avatar
Get some little pizza cutter tires on it.
Inner10 is offline
Old 12-06-2013, 04:31 PM   #998
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
I would be careful with going that route, these systems are likely to be considered safety features, and if you get into an accident with them disabled I could see the insurance company telling you that you disabled a safety feature of the vehicle and they will not be covering you.
SectorSecurity is offline
Old 12-06-2013, 07:18 PM   #999
Rewards Points: 434
Mine is a 2011, with Michelin tires on it. Haven't really gotten to try them out for traction yet.
I don't have traction control that I know of and mine is loaded.
All I know is when your trying to steer and go with it it gets hairy fast.
Old 12-06-2013, 08:51 PM   #1000
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Post number 1000. Thank you very much!
BamBamm5144 is offline
Need help with saw switch Irishslave Electrical 15 04-02-2013 11:02 PM
I need to add a ceiling light to a switch that activates an outlet supafly917 Electrical 23 12-10-2012 05:03 PM
Buying a new vehicle from ford questions? rtztgue Business 27 08-02-2011 02:54 PM
Double Pole Switch jproffer Electrical 20 04-02-2011 09:56 AM
Are you making..... Cole82 General Discussion 21 03-23-2010 08:33 AM
