F250 Or F350 - Vehicles - Contractor Talk
F250 Or F350
Old 06-29-2018, 12:02 AM   #1
Stunt Carpenter's Avatar
Rewards Points: 1,460
F250 Or F350
Hey Guys, Iím sure this has be discussed before but I canít find it.
Looking to upgrade from my 07 F150. Iím getting to the point where I am maxing out the truck for towing and sometimes payload.
I have a 6x12 tool trailer thatís ~4000lbs that I load lumber and materials into often. I also put the mini skid in the truck and pull the trailer sometimes and would like to do that more.
I also have a 6x12 dump that I use for moving my mini skid and hauling garbage, dirt, pavers etc.
For example I have the dump on with the machine, and 30 bags of concrete in the truck tonight.
My question is will a F250 be a better buy than a F350? There isnít a lot of difference I can see between them
Stunt Carpenter is offline
Old 06-29-2018, 12:07 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,612
Re: F250 Or F350
things to consider:
new or used
price
age
miles
engine
transmission
rear end ratio
just not much difference between the two...
griz is offline
parkers5150 (07-04-2018)
Old 06-29-2018, 01:39 AM   #3
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,230
Re: F250 Or F350
Originally Posted by Stunt Carpenter View Post
Hey Guys, I’m sure this has be discussed before but I can’t find it.
Looking to upgrade from my 07 F150. I’m getting to the point where I am maxing out the truck for towing and sometimes payload.
I have a 6x12 tool trailer that’s ~4000lbs that I load lumber and materials into often. I also put the mini skid in the truck and pull the trailer sometimes and would like to do that more.
My question is will a F250 be a better buy than a F350? There isn’t a lot of difference I can see between them
I don't know much about fords but its usually the brakes and leaf springs. if you are actually maxing out the payload I would go for 350,
Another option is airbags in the rear for just solving squatting since most your weight in the trailer its very well priced for how much they can handle and install is easy. But I don't think this will increase your payload legally speaking. Does keep the rig looking legal haha them RCMP love spotting swatters and scaling them around here.
cedarboarder is offline
The Following User Says Thank You to cedarboarder For This Useful Post:
Fouthgeneration (01-29-2019)
Old 06-29-2018, 05:04 AM   #4
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 338
Re: F250 Or F350
I don't know about ford, but the only difference between a gm 2500 and 3500 single rear wheel (srw) is one leaf in the rear spring pack.
It doesn't sound like you're any where's close to dual rear wheel (drw) territory, but if you were, they make towing / carrying heavy loads alot more comfortable.
Sent from my SM-G900V using Tapatalk
mrcat is online now
Old 06-29-2018, 05:53 AM   #5
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,418
Re: F250 Or F350
On the chevys it is an extra single rear leaf and a stronger rear end as well
Of coarse it has a higher load rating as well for legal reasons if you hit the scales
Windycity is online now
Old 06-29-2018, 06:33 AM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 9,566
Re: F250 Or F350
Go with the F350. Gives you a higher GVWR.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
griz (06-29-2018)
Old 06-29-2018, 08:46 AM   #7
Re: F250 Or F350
I put 5000lbs air bags in the truck the first week I owned it. In my opinion you canít tow with a half ton without them anymore.
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
cedarboarder (06-30-2018)
Old 06-29-2018, 09:25 AM   #8
mrcat's Avatar
Rewards Points: 338
Re: F250 Or F350
https://youtu.be/XSw_4VTg98s
I should have clarified, the diesel 2500 and 3500 srw drive train is identical, except for the extra leaf.
I wasn't even thinking about the gas models, silly me.
mrcat is online now
The Following User Says Thank You to mrcat For This Useful Post:
A&E Exteriors (09-22-2018)
Old 06-30-2018, 10:26 AM   #9
Re: F250 Or F350
Iíll be buying used so it sounds like which ever one I find for the right price with the setup I need will work and that small difference between the 250 & 350 isnít going to make a difference for what Iím hauling.
Old 06-30-2018, 10:35 AM   #10
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 12,794
Re: F250 Or F350
Main difference between f250 and f350 is a 350 has stiffer leaves in the back and 4" blocks instead of 2.5 and a different rear end gear ratio.
https://dustrunnersauto.com/f250-vs-f350/
A&E Exteriors is offline
Old 06-30-2018, 10:36 AM   #11
Re: F250 Or F350
I've pulled 14k through muck and not gotten stuck yet with my f250
Old 06-30-2018, 11:10 AM   #12
Re: F250 Or F350
I think I would put airbags on either one. With a trailer and the mini skid in the bed I think it would be well worth the cost of the airbags again.
Do the block just make the 350 sit higher than the 350 or do the actual make a difference
A&E Exteriors (06-30-2018)
Old 06-30-2018, 11:13 AM   #13
Re: F250 Or F350
Sits a tad higher and has a higher payload capacity
Old 07-04-2018, 11:13 AM   #14
Trade: Workaholic
Re: F250 Or F350
I think no matter what the rcmp go by what's on the sticker for payload. I thought might be some way to get this change if you upgrade but havnt found much. If you do find a way let me know cause my next truck is a going to be a 1997-2001 ram Cummins
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 07-04-2018, 07:08 PM   #15
Re: F250 Or F350
Nope, gotta change the cab to get the higher rated sticker
Old 07-04-2018, 08:44 PM   #16
Re: F250 Or F350
What I have found with the airbags is that they donít increase payload just keep the Rcmp of you as your truck doesnít look like it has a bunch of weight on it
Old 07-04-2018, 09:41 PM   #17
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 672
Re: F250 Or F350
I like the air bags to keep the truck riding fairly level , personally I think a truck handles better loaded.
I like a dually for heavy loads even if a sw will handle it.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
mrcat (07-04-2018)
Old 07-04-2018, 10:44 PM   #18
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,434
Re: F250 Or F350
My brother's new 2012 f250 has been Nick named the super droopy. It has a cap and a 100 gallon fuel tank in it and looks like it has 4k pounds in the bed. Hook a skid loader trailer on it and the tounge drags, front end wonders and you can't stop for crap. It's pretty pathetic.
He has been eye balling the air bags I have in my 350. Great when I can't avoid a bit too much pin weight.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 01-26-2019, 09:21 PM   #19
Re: F250 Or F350
Well I finally bought a truck. Found a nearly mind 2010 F250 Lariat that was used only for pulling a travel trailer in the summers.
Only downside to the truck is the ugly cow catcher.
Luckily it came with the factory bumper so I can swap it back and sell this one
The Following 3 Users Say Thank You to Stunt Carpenter For This Useful Post:
Rio (01-28-2019), tgeb (01-26-2019), Tom M (01-27-2019)
Old 01-26-2019, 09:24 PM   #20
I like Green things
Re: F250 Or F350
6.4 psd?
Sent from my SM-N960U using Tapatalk
Warner Mill Works
Facebook
YouTube
F250 Diesel Mileage blackte Vehicles 31 12-22-2014 10:34 PM
F250 gas van ATLRoofer37 Vehicles 8 12-13-2014 11:26 PM
Ford F350 Dump Truck /Lift gate for sale Pedrobez Vehicles 0 11-14-2011 01:50 PM
Anyone has a 2008 or 2009 Ford F250 or F350? FremontREO Vehicles 1 04-30-2011 05:05 AM
Paslode f350 major air leak HRUBY Tools & Equipment 4 03-01-2009 06:53 PM
