Dump Trailers - Vehicles - Contractor Talk
Dump Trailers
Old 05-09-2017, 08:48 AM   #1
dayexco's Avatar
Rewards Points: 256
Dump Trailers
Going to buy 14 foot dump trailer. Buying from a local dealer that I've done business with has narrowed my choices to two brands.
Either a PJ or midsota. Both have good reviews, both good dealers and parts support.
Any of you own either brand? Even other brand owners, what do you like/dislike about ones you have?
dayexco is online now
Old 05-09-2017, 09:15 AM   #2
twinfallsroof's Avatar
Trade: Roofing and general home improvement
Rewards Points: 40
Re: Dump Trailers
I've got a PJ, it's about 5 years old, learned that I don't like spring loaded hinge locks for the doors and that I'd prefer a gravity down instead of power down because the battery died at full tilt on me once
twinfallsroof is offline
The Following User Says Thank You to twinfallsroof For This Useful Post:
dayexco (05-09-2017)
Old 05-09-2017, 11:12 AM   #3
Lettusbee's Avatar
Rewards Points: 1,358
Re: Dump Trailers
I have a travalong. It is battery down, but if the battery dies when trailer is in up position, it somehow knows this, and will spit out all the hydraulic fluid to let the deck back down. I'm glad I learned this at the landfill, and not dumping dirt at a clients house.
Lettusbee is online now
The Following User Says Thank You to Lettusbee For This Useful Post:
Old 05-09-2017, 12:14 PM   #4
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,260
Re: Dump Trailers
Not an answer to your question, but if you get a dump trailer, definitely get the charging line installed on your truck. It'll save you having the dump die on you.
Delta
Old 05-09-2017, 12:16 PM   #5
Bull Trout's Avatar
Rewards Points: 130
Re: Dump Trailers
I carry one of those jump start packs there is enough juice to power down the dump in case needed
Bull Trout is offline
The Following User Says Thank You to Bull Trout For This Useful Post:
Pearce Services (05-16-2017)
Old 05-09-2017, 12:32 PM   #6
dayexco's Avatar
Rewards Points: 256
Re: Dump Trailers
Delta
I've been thinking the same thing
Old 05-09-2017, 12:43 PM   #7
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,592
Re: Dump Trailers
Yea don't you have it set to charge the battery when you hook it up to the truck and drive?
I have seen guys also use jumper cables to a vehicle to operate the dump in a pinch
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
Old 05-09-2017, 01:05 PM   #8
dayexco's Avatar
Rewards Points: 256
Re: Dump Trailers
Dumb question, how many dumps can you get out of a charge?
Old 05-09-2017, 01:15 PM   #9
Lettusbee's Avatar
Re: Dump Trailers
I can get 2 if the battery isn't too old, anf load isn't too heavy. My 7x14 usually has 3000 lbs of construction trash in it. I rarely haul dirt any more.
I keep long enough jumper cables for those desperate times. Would like to hardwire a winch connector to the back bumper, and get the jumper cables that plug into the winch plug. I will probably never get around to it though.
I don't drive far enough to charge battery in transit.
Sent from my SM-G860P using Tapatalk
Old 05-09-2017, 02:48 PM   #10
Windycity's Avatar
Trade: Masonry
Re: Dump Trailers
You guys ever think about adding a small solar charger to keep the battery topped off?
Old 05-09-2017, 04:02 PM   #11
dayexco's Avatar
Rewards Points: 256
Re: Dump Trailers
Great idea, but both I'm looking at one with built in trickle charger you plug in at night. Plus pickup battery is charging while it's hooked up and running
Old 05-09-2017, 04:08 PM   #12
Lettusbee's Avatar
Re: Dump Trailers
Yep. Think about it all the time. Acting on it seems to never happen.
Old 05-09-2017, 04:26 PM   #13
Windycity's Avatar
Trade: Masonry
Re: Dump Trailers
Kinda like how I think about it when the batteries are dead, and forget about it all the other times! lol
Old 05-09-2017, 09:34 PM   #14
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Dump Trailers
I have this Diamond C 8x14 deckover. I love this trailer. Both sides flip down, and the back is a 3 way gate. I had my welder add stake pockets to the inside and added (2) 2x10's to the sides giving me a roughly 15 yd capacity (mostly deck debris). When the wood sides are on it doesn't allow the side doors to drop all the way down, but I can also remove them if I want/need the ability.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
Old 05-09-2017, 09:35 PM   #15
RobertCDF's Avatar
Re: Dump Trailers
Here it is with the sides.
Old 05-09-2017, 10:39 PM   #16
MOC's Avatar
Trade: General Contractor (Historic Preservation)
Re: Dump Trailers
7x12 Cam Superline here, it's perfect for us. Had it about two years and zero issues.
MOC is offline
Old 05-10-2017, 12:20 AM   #17
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,262
Re: Dump Trailers
I have the PJ. It's 4 years old. Used mostly as a garbage trailer but occasionally for a load of dirt or gravel.
50% of the paint is gone and the rest will follow soon. So it needs to be blasted and painted properly before it's completely rusted.
I've redone the whole swinging gate latch open system already. It came with a spring loaded latch thing that held the gates open at about 225 degrees. I found that real awkward when I had to drive with the doors open because they stuck out so far out the side. Also the latch pins continually bent from the weight of the door when the box is dumped. I cut the entire latch system off so that the doors swing 260 degrees flat against the fender and welded a chain onto the box to hold it open. It works a hunnerd times better than factory.
The battery charging system from the truck has never worked properly either. But I do have the 120V charger, which is awesome.
The equipment ramps are no picnic to get out of the holders, but they do work in a pinch. I don't often haul my skidsteer in it anyway.
I think next time I'd be tempted to spend the extra 3k and get a Precision or Southland that comes with some more quality.
Anthill is offline
Old 05-10-2017, 01:41 AM   #18
Bull Trout's Avatar
Rewards Points: 130
Re: Dump Trailers
5 or 6 with the larger deep cycle battery from costco, 14' big tex powers up, not down
Old 05-10-2017, 05:15 AM   #19
Box Builder
Morning Wood's Avatar
Rewards Points: 10,352
Re: Dump Trailers
I've got a 7x12 deck over. It's a cam super line. Sides drop down. Paint job on any trailer seems to be a joke. I think the pj's are powder coated so touching up paint can be a problem on them. I've got dual 2 stage telescoping cylinders. Gravity down. No issues there. It's slow coming down in cold weather. I built up my sides with some welded brackets. It works ok. Going to redo them this year so I can put racks on it though for carrying ladders and staging. I've never had my battery die, but haven't done many back to back dumping cycles. I just have a straight tailgate which is a little slow to open but straight forward. No ramps
Morning Wood is online now
Old 05-10-2017, 09:14 AM   #20
Bull Trout's Avatar
Rewards Points: 130
Re: Dump Trailers
don't know why I cant edit, but two or three on basically the same trailer and battery that powers up and down
I am looking for input on side dump trailers burntside bob Excavation & Site Work 11 03-05-2016 09:58 PM
Dump Trailers TLP Vehicles 1 06-17-2013 08:47 PM
Dump Truck mango3493 Business 0 11-24-2012 10:15 PM
NJ guys with dump trailers, questions... ApgarNJ Vehicles 9 04-30-2011 07:23 PM
Dump Trailers & Equipment Trailers txgencon Vehicles 6 03-23-2011 09:15 AM
