Dump Trailer Liner - Vehicles - Contractor Talk
Dump Trailer Liner
Old 06-17-2020, 08:52 PM   #1
Stunt Carpenter's Avatar
Rewards Points: 2,896
Dump Trailer Liner
Hey Guys,
Since I no longer need to transport my skid steer in the dump box of my trailer I was thinking about getting so sort of liner to help clay and sod dump easier.
I remove a fair amount of sod for deck builds and it is the biggest pain to get out of the box.
I know that full size dump trucks use UHMW but I donít think I need to go to the extent. I was hoping for a paint on product but havenít had much luck finding one.
Was also considering bolting two sheets of FRP to the bottom since they are slick but I donít think they would hold up to demo materials being dumped in.
Any suggestions?
https://builddaley.com/
Stunt Carpenter is online now
Old 06-18-2020, 08:42 AM   #2
Mordekyle's Avatar
Rewards Points: 6,086
Re: Dump Trailer Liner
A light coat of diesel?
Mordekyle is offline
Old 06-18-2020, 08:50 AM   #3
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,406
i would think it could be sprayed with something .some sort of teflon like coat .adding another box would add weight .i get you point though .stuff sticks in my dump also
JFM constr is offline
Old 06-18-2020, 11:47 AM   #4
hdavis's Avatar
Rewards Points: 1,970
I've used heavy sheet plastic for that, but it dumps out with the material, and you have to get it out from under anything on top of it.
Diesel is used for asphalt. Vegetable oil is a reasonably priced alternative for soils.
None of the 13yd trucks here do anything special.
hdavis is online now
Old 06-18-2020, 01:54 PM   #5
I knew diesel was for asphalt from when I build roads after high school.
Iíll try the vegetable oil for the next load of sod I have Monday. That might be a cheap solution with a garden sprayer.
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
hdavis (06-18-2020)
Old 06-18-2020, 02:18 PM   #6
JFM constr's Avatar
the trailers do not general tip like a 13yd truck . 13yd boxes ,at least the ones I am remembering they round over where sides and bottoms meet .
I recall looking into having something sprayed in my dump trailers bed to make it slide ,or not stick .Did not ever get the cost ,just decided did not want to spend the money .
The Following User Says Thank You to JFM constr For This Useful Post:
hdavis (06-18-2020)
Old 06-18-2020, 02:21 PM   #7
JFM constr's Avatar
imagine spraying diesel in your dump ,that stink will get into the cab of your truck and be there for ever .it just will . even veg oil smells but it is bound to get on you and bound to get into the cab .
Old 06-18-2020, 05:17 PM   #8
Mordekyle's Avatar
I recall when people were trying to save the earth by converting their cars to run on used vegetable oil.
You could go get used vegetable oil from the Burger King. Spray everything with it.
Everybody could smell you coming. It would be your aroma brand.
Old 06-18-2020, 05:51 PM   #9
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,758
My trailer lifts to a pretty steep angle, never really have had much trouble with stuff coming out.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
hdavis (06-19-2020)
Old 06-18-2020, 09:32 PM   #10
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,706
Yeah that's interesting, never had an issue dumping anything either aside from stuff getting hung up on the D rings near the back.
TheConstruct is online now
Old 06-18-2020, 09:51 PM   #11
Only thing that I have problems with is sod. Last load was so stuck that even when I got to bottom moving to top stayed
Old 06-19-2020, 08:49 AM   #12
RichVT's Avatar
Rewards Points: 1,283
There are coatings that are designed to go on mower decks to keep the grass from sticking. Maybe that would work if you can find a large enough quantity.
RichVT is offline
Old 06-19-2020, 10:04 AM   #13
hdavis's Avatar
Never tried it, but plow slick may fit the bill:
http://www.plowslick.com
It's supposed to be a once a year applicatiin, so it should stand up to abrasion.
Pricey.....
TheConstruct (06-19-2020)
Old 06-19-2020, 11:13 AM   #14
rrk's Avatar
Rewards Points: 5,358
I have dumped some used motor oil in mine and it works good for everything but dirt small stones concrete etc
I would think that sod would also stick to it
rrk is online now
Old 06-19-2020, 02:13 PM   #15
Pricey.....
That might be the ticket. Itís only $80 for my trailer
hdavis (06-19-2020)
Old 06-19-2020, 03:43 PM   #16
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,796
My little 5x8 dump has a single hydraulic jack instead of a scissor lift and i struggle to get stuff out most of the time
Scissor lifts put the bed at a higher angle which helps But fortunately most of my debris is Brick and masonry debris so usually it slides out without too much issue except for the stupid d rings that are welded to the floor
A little diesel helps lube up the bed
Windycity is online now
