Dump / Mini Skid Steer Trailer - Vehicles - Contractor Talk
Thread Tools
Old 05-05-2019, 08:29 PM
Stunt Carpenter's Avatar
Rewards Points: 1,728
Hey Guys,
Wanting to get everyoneís opinion on a new dump trailer. I currently have a 12í that works for almost everything I do.
The problem I run into is I also use it to move around my mini skid steer and run into the problem of the trailer being half full and needing to move the machine. Then I have to make an extra trip to the landfill that is a 40min drive each way plus unloading.
I was tossing around the idea of getting a 16í trailer and putting a 12í dump on the back end so I have 4í on the front for the machine. This would also let me make some permanent mounts for auger bits and possibly a rack for my second bucket and auger drive.
My concerns are load balance and tongue weight. Machine is ~1400 lbs plus attachments. Would I need to move to a goose neck.
Thanks
Stunt Carpenter is offline
Old 05-05-2019, 09:29 PM
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 560
Re: Dump / Mini Skid Steer Trailer
I'm guessing you should have a gooseneck, I just looked up the tounge weight rating on a class V hitch, and looks like they're only good for 12-1700 lbs, depending if it's set up for weight distributing or not.
https://www.drawtite-hitches.com/lea...towing-classes
mrcat is online now
Old 05-06-2019, 09:20 AM
Donohue Const's Avatar
Rewards Points: 1,530
definitely get a gooseneck
once you pull one vs bumper mount you will not want to go back
I like the idea of that trailer set up, sounds like it would be really handy for what your trying to do
what are you pulling it with?
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 05-06-2019, 01:30 PM
I would be pulling it with my F250 gasser.
I considered getting a dually flat deck truck instead but we use the truck for family stuff also so it would have been a pain for that.
Old 05-06-2019, 04:39 PM
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,044
Are you looking for Something like this? But with the ability to hold a machine on the front?
Windycity is online now
Old 05-06-2019, 06:21 PM
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,174
Never seen one like that, and I thought I knew everything.
That's pretty neat.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 05-06-2019, 06:43 PM
Windycity's Avatar
Trade: Masonry
That's pretty neat.
I saw that type of dump trailer when I was looking to purchase a dumptrailer for myself, i think its a newer concept and i would assume thatís perfect for landscapers that do lawn maintenance type stuff
The Following User Says Thank You to Windycity For This Useful Post:
Seven-Delta-FortyOne (05-06-2019)
Old 05-06-2019, 06:56 PM
Thatís exactly what I was thinking just a shorter area on the front to keep the overall length down.
Old 05-06-2019, 07:01 PM
Windycity's Avatar
Trade: Masonry
The issue i see with your plan is even with heavy duty ramps side loading a heavy piece of equipment like you plan on using would be hard to keep the opposite side from popping up in the air
Old 05-06-2019, 07:07 PM
Trade: Highwayman
Flip down jack.
Just like on an equipment hauler.
Get Off My Lawn.
Old 05-06-2019, 07:11 PM
Windycity's Avatar
Trade: Masonry
Yea jacks would definitely be needed!!
Fyi the type of trailer I posted above is called a hybrid dump trailer
Old 05-06-2019, 08:36 PM
Hereís a better picture of what Iím after. This ones a pintel hitch so the tough weight must be getting up there.
My machine is a little for compact than the bobcat version so it would fit with more room.
Wondering if a driver side ramp would be better.
Thread Tools
Rate This Thread
Skid steer and mini or dozer and mini? Cat325 Excavation & Site Work 13 01-10-2018 01:06 AM
Toro dingo mini skid steer arbor pro Contractor Swap 0 05-04-2012 11:40 AM
Mini skid steer ash2042 Decks & Fencing 9 09-30-2011 10:51 PM
Biljax Escalate 5x10 Hydraulic Lift Trailer and Toro Dingo mini skid attachments arbor pro Contractor Swap 2 05-17-2011 11:01 AM
2 mini skid steers plus lots of attachments for sale arbor pro Contractor Swap 15 03-03-2011 09:37 AM
