Do We Talk About Garages In Vehicles? - Vehicles - Contractor Talk
Old 01-30-2019, 04:18 PM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 11,148
Seems appropriate, right?
Guys who have built your own garage/shop...
What did you do right?
What would you change if you did it again?
I've got 40x40 concrete pad with an ok from the town to build basically as big as I want. I'm not sure what I want though.
If I had to guess, I'd assume I want a two-bay with roll up doors and high ceilings(16'?)
I'd also assume I'd be parking a van in one of the bays and using the other as a workshop.
What are the challenges with keeping a space like that heated? Doesn't have to be hot. Just looking for somewhere that my paint and glue won't freeze.
Any online resources that are solid for garages/shops that you want to plug?
I haven't lived in a house with a garage since 1991.
Easy Gibson is online now
Old 01-30-2019, 04:39 PM   #2
Rooster Cogburn's Avatar
Trade: Master carpenter
Rewards Points: 264
Re: Do We Talk About Garages In Vehicles?
Probably depends no how much you want to spend. If you build 40x40 with a 16 foot ceiling, that is alot of space for a guy that doesn't have a garage now.
With that much space, you could build a room in a back corner with a loft over it . Is it too late for plumbing? I have a 3/4 bath and a kitchenette in mine.
Rooster Cogburn is offline
Old 01-30-2019, 04:40 PM   #3
Lettusbee's Avatar
Rewards Points: 648
I have a large shop with a radiant tube heater for the main area.
There are 3 smaller rooms that are well insulated and have baseboard electric heat. One of those rooms is a spray booth that I keep my cold sensitive materials in. Keep the heater set on low and it's plenty warm for storage, turn it up if I'm going to be in there for a while.
Lettusbee is online now
Old 01-30-2019, 04:50 PM   #4
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 211
Just finished my attached garage last year. 26 x 52 with the shop half heated with radiant heat via pex in the slab. It is amazing!!
Easy Gibson
Warren is online now
The Following 2 Users Say Thank You to Warren For This Useful Post:
Morning Wood (01-31-2019), overanalyze (01-31-2019)
Old 01-30-2019, 05:23 PM   #5
Rewards Points: 264
how do you heat the tubing?
Old 01-30-2019, 05:27 PM   #6
Geometrist
Warren's Avatar
Rewards Points: 211
Standard 40 gallon hot water heater.
Easy Gibson
The Following User Says Thank You to Warren For This Useful Post:
Old 01-30-2019, 05:37 PM   #7
Geometrist
Warren's Avatar
Rewards Points: 211
Easy:
Obviously, your best bet for construction of that will be pole barn style. I would set up one portion with a taller door, but probably just a 9 or 10 footer, unless you know you are gonna need bigger. Since you already have the slab, the slab heat is a no go, but I would opt for either a commercial Reznor, or maybe a couple of those Mitsubishi in the wall deals.
Easy Gibson
Old 01-30-2019, 06:47 PM   #8
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,892
16' ceilings may be overkill for most use, but it is great for a loft level, or a vehicle lift. I built a loft in mine and have essentially 100% of my storage up there, so the ground entire floor is free to rearrange for projects as needed.
If I had to build from scratch, I would stick frame instead of pole, just for ease of insulating with normal methods. If I had enough space for main floor square footage, I'd just do a 12' ceiling and no loft.
My previous shop had radiant heat, and yes, it is awesome. In Fairbanks, Alaska on a -40 day, I could open and then close the overhead door and be comfortable in my t-shirt after 1 minute.
Half of all people are below average.
Golden view is online now
Old 01-30-2019, 07:01 PM   #9
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 2,434
Natural gas infrared tube. I know some guys who have them in their hangers and swear by them.
https://sunstarheaters.com/tube-heaters/
https://www.anthonyphc.com/blog/perk...garage-heater/
Big Johnson is online now
Old 01-30-2019, 07:17 PM   #10
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 18,799
Good explanation of them.
http://www.infraredinfo.com/Article_1.html
MarkJames is online now
Old 01-30-2019, 07:41 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 1,612
while you are building it the thought will cross your mind that ....
"why does this dam thing have to so big".....
about a year later you will wish it was bigger....
griz is offline
The Following 4 Users Say Thank You to griz For This Useful Post:
Deckhead (02-06-2019), KAP (01-30-2019), mrcat (01-30-2019), SouthonBeach (01-30-2019)
Old 01-30-2019, 07:43 PM   #12
Lettusbee's Avatar
Rewards Points: 648
If I was building new, I would love to go with radiant floors.
Have to be careful whats directly under a radiant tube heater. I had to move mine over so I could park my trailer in there.
Old 01-30-2019, 07:44 PM   #13
Lettusbee's Avatar
Rewards Points: 648
If you go Pole Barn style, watch some RR buildings videos on youtube. He has some efficient methods for insulating.
The Following User Says Thank You to Lettusbee For This Useful Post:
Golden view (01-30-2019)
Old 01-30-2019, 08:46 PM   #14
KAP's Avatar
Trade: Custom
Rewards Points: 31,276
You have to define what you're going to use the space for before designing the rest... that may end up becoming a project done in phases while you define it... a spot for the van is wasted real estate unless you're going to use that area also as a load/unload area for deliveries...
The first shop we moved into decades ago, I literally had a used Craftsman table saw that was from the 60's that I bought (off a customer who was looking to get rid of it) sitting in the front of a 1500sf shop... that was it... tools on the floor... thought we had all the room we would ever need...
But we outgrew it in a year and half... and did two more moves to after that to larger shops... so something to keep in mind...
It sounds like you're limited to 40' x 40' footprint so the higher you go (or plan to go), you can add office, bathroom, etc. at a later date as needed... Wasn't clear if this was at your home or not...
KAP is offline
Old 01-30-2019, 09:14 PM   #15
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 709
I'm intrigued by this. Wife's been after me for a few years now to build a shop/storage place and get my stuff out of the house. A warm floor would be awesome.
How well does it cope with an extended run of, oh, 15-20° weather, and what's your usual temperature setting? Have any numbers on that water heater's duty cycle and/or cost to operate for a season?
Tinstaafl is online now
Old 01-30-2019, 10:20 PM   #16
rrk's Avatar
Rewards Points: 968
Easy’s plan may turn to dust when he figures property tax increase for a heated 2 story 40 x 40 garage mahal
rrk is online now
Easy Gibson (01-31-2019)
Old 01-30-2019, 10:28 PM   #17
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,432
Alot of guys on the garage forum have this....they swear by the comfort of radiant heat.
Once the slab is warm you have alot of heat mass plus there is no blowing air or noisy furnaces
Windycity is online now
The Following 2 Users Say Thank You to Windycity For This Useful Post:
overanalyze (01-31-2019), Tinstaafl (01-30-2019)
Old 01-30-2019, 10:37 PM   #18
We’re you out today setting the railroad tracks on fire?
Old 01-31-2019, 05:34 AM   #19
Geometrist
Warren's Avatar
Rewards Points: 211
This being my first Winter, I can only guess. Decembers bill was about $25 higher, but you would have to factor in avg daily temps, gas prices, etc. I am heating about 700 sq feet. They did 4 runs of tubing with each run being within 12" of each other. As for now, I just control the temp via the water heater, which is a about 2 tics above the lowest setting. I will eventually wire it to a thermostat, but in the meantime it felt like about 65 degrees out there yesterday, when the outside air was zero.
Easy Gibson
The Following 4 Users Say Thank You to Warren For This Useful Post:
Kscarpentry (02-02-2019), overanalyze (01-31-2019), Tinstaafl (01-31-2019), Xtrememtnbiker (01-31-2019)
Old 01-31-2019, 06:34 AM   #20
Mike-B's Avatar
Rewards Points: 850
Interesting idea in tbat radiant heat. How are you circulating the water?
Mike-B is online now
Hi contractor talk ! Wireman64 New Member Introductions 0 04-04-2013 08:27 PM
Contractor Talk Calander 2014.... .. PrestigeR&D General Discussion 73 01-18-2013 10:32 PM
Contractor Talk, Top Referrer Site My Driveway Dr Marketing & Sales 8 01-11-2013 12:58 PM
Router talk....101..... PrestigeR&D Tools & Equipment 94 12-16-2012 10:58 PM
New to Contractor Talk myankevich New Member Introductions 4 04-18-2010 11:05 AM
