Chevy 2500 Crew Cab Long Box Gas - Page 6 - Vehicles - Contractor Talk
Old 12-06-2018, 06:53 AM   #101
META's Avatar
Trade: General and Trades
Rewards Points: 2,960
Re: Chevy 2500 Crew Cab Long Box Gas
Originally Posted by Big Johnson View Post
The problem Iíve had with cars/trucks rusting out is the bottoms of the painted panels on the sides. I wouldnít get too worked up over underbody coatings.
For $20/month you can get a mister car wash unlimited package. $30 for the ultimate wash package. Definitely worth the $$$, there are mister car washes all over around here. Keeps the salt off in the winter.
That is a good practice, but not sure about a truck with rack and side boxes going through the mechanical washing systems.
META is offline
Old 12-06-2018, 07:30 AM   #102
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,276
Originally Posted by WarnerConstInc. View Post
Salt? That stuff the put on the roads in MI is nasty stuff. Like some sort of brine.
They put that stuff down almost every day from mid November to May. We get some lake effect so almost every day thereís at least a dusting. Itís not always enough to plow but it makes the roads slippery so they dump on the salt.
Big Johnson is online now
Old 12-06-2018, 07:38 AM   #103
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,484
That stuff is nasty. Almost impossible to wash off. What ever happened to sand? Sand worked, didn't rot out your truck, was probably cheaper too.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 12-06-2018, 08:02 AM   #104
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,836
Plus you canít have anything in the bed of the truck
Every car wash I go to the attendance looks in the back of the truck to make sure itís completely clear because Iím assuming the blowers will blow everything out
Basically my truck is never eligible to go through a car wash
Windycity is offline
The Following User Says Thank You to Windycity For This Useful Post:
META (12-06-2018)
Old 12-06-2018, 08:05 AM   #105
Windycity's Avatar
Trade: Masonry
Thanks for that info.
https://www.daubertchemical.com/stor...ox-rust-x-121b
NOX-RUST X-121B
"Nox-Rust*X-121B (also known as "Nox-Rust*X-121 Black") dries to a firm wax-like film that will repel water, self-heal, and remain flexible at low temperatures. Can be easily applied using low-pressure airless equipment."
It is my understanding Nox-rust isn't very durable much longer than a year.
Dinitrol 479 appears to be a longer lasting product. However, still not sure about applying Dinitrol over Nox-Rust.
"DINITROL 479 Black 1 L 12-P
DINITROL 479 is a thick corrosion preventative compound with a ĒrubberyĒ consistency which forms a very hard, elastic, wear resistant protective film with extremely good sound damping pro-perties. The product has high thixotropy, contains low aromatic solvent that do not attack paints, plastics and rubber parts of the car. The thick layer of coating has a heavy-duty structure, which looks like orange peel and absorbs very well outside road noise resonance from vibrations of vehicle parts as well as damps sound from stone chip and sand attacks. The product withstands heavy mechanical wear with excellent adhesion properties. DINITROL 479 is an approved alternative for wheel arches covers from plastic or felt. The product has good adhesion to painted and primed surfaces, original PVC and steel and ensures reliable protection from corrosion. DINITROL 479 is designed as sound deadening and corrosion protective product for treatment of underbody *components, like wheel arches, door sill plates of all kinds of vehicles, busses, trucks, trailers etc."
Itís actually a very durable product unfortunately Chevy had some control issues a few years ago with application where it was failing prematurely
I personally like the wax coating however I absolutely despise doing anything underneath the truck because if you barely touch it with your hands or clothes it get it all over
META (12-06-2018)
Old 12-06-2018, 08:16 AM   #106
I always have to clean out whateverís in the bed before I go. I donít like **** sliding around back there anyways so itís usually pretty clean. If you have something heavy they let you through. I had a bunch of lumber scraps once and they cleaned it all out and threw it away for me.
Jaws (12-06-2018)
Old 12-06-2018, 04:57 PM   #107
TimNJ's Avatar
Rewards Points: 4,288
Originally Posted by A&E Exteriors View Post
Saw these the other day. Gms, i think they were gas trucks not sure though
What it looks like unwrapped:
https://www.caranddriver.com/news/20...00-photos-info
TimNJ is online now
Old 12-06-2018, 05:00 PM   #108
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,388
Originally Posted by TimNJ View Post
That is fugly
A&E Exteriors is offline
The Following 2 Users Say Thank You to A&E Exteriors For This Useful Post:
Calidecks (12-06-2018), TimNJ (12-06-2018)
Old 12-06-2018, 05:01 PM   #109
I like Green things
New trucks keep getting worse looking every year.
Warner Mill Works
Facebook
YouTube
The Following 3 Users Say Thank You to WarnerConstInc. For This Useful Post:
Calidecks (12-06-2018), Jaws (12-06-2018), Lettusbee (12-06-2018)
Old 12-06-2018, 06:28 PM   #110
That is fugly
Beautiful and they got rid of that hideous bow tie.
Old 12-06-2018, 06:31 PM   #111
The Sheriff
Jaws's Avatar
Rewards Points: 3,978
They let it go through with a cooler.
I try to only haul around a cooler lol
Sent from my SM-N920V using Tapatalk
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
The Following User Says Thank You to Jaws For This Useful Post:
Big Johnson (12-06-2018)
Old 12-10-2018, 09:39 PM   #112
META's Avatar
Https://www.gmpartsdirect.com is where I'll probably get a few accessories to install myself.
META is offline
Old 12-15-2018, 09:13 PM   #113
META's Avatar
This just got ordered.
https://www.chevrolet.com/previous-y...stalCode=49345
META is offline
The Following 3 Users Say Thank You to META For This Useful Post:
A&E Exteriors (12-15-2018), TimNJ (12-16-2018), VinylHanger (12-16-2018)
Old 12-16-2018, 07:54 AM   #114
You going to put plows on it?
Old 12-16-2018, 08:21 AM   #115
META's Avatar
I might for personal and family use. The Alaska package got me some upgrades I wanted. I'll have the dealership take off the decal.
META is offline
Old 12-16-2018, 12:42 PM   #116
VinylHanger's Avatar
Rewards Points: 9,638
Very nice. I thought I would miss the diesel sound when I went gas, but the 6.0 has a nice growl to it.
Does the 2018 have the same engine they have run for the last 10 years or more? I heard they were going to upgrade/redesign it. 2019 maybe? It might make me nervous to have the first year of any engine/tranny.
VinylHanger is offline
Old 12-16-2018, 01:06 PM   #117
META's Avatar
This is a 2019 build, same engine they've had for the last few years. I hear 2020 is "new" engine and the body similar to the 1500.
The brown metalic will go better with my company's colors over the graphite metalic.
META is offline
The Following User Says Thank You to META For This Useful Post:
zbiddle91 (01-13-2019)
Old 01-22-2019, 08:13 PM   #118
META's Avatar
Target production week is Jan 28...then hopefully a short trip to me from Flint, MI.
META is offline
Old 01-22-2019, 08:21 PM   #119
META's Avatar
I just ordered this rack with the rail mounting hardware and headache rack. It's rated for 1,700 lbs.
Rack-it Truck Rack's New HD Square Tube Rack For Pickups #2
META is offline
The Following 2 Users Say Thank You to META For This Useful Post:
Calidecks (01-23-2019), mrcat (01-23-2019)
Old 01-22-2019, 08:48 PM   #120
Windycity's Avatar
Trade: Masonry
Looks like it is forklift loadable from the sides....nice rack!
META (01-22-2019)
Come on, Share some pictures of your work... Dyer Sandblasting 577 08-22-2015 09:31 PM
2002 Chevy 2500 Utility nakarsten Contractor Swap 2 11-23-2012 10:09 PM
long term planning question guardian Business 1 04-19-2011 12:49 AM
Crew or Sub work out? KES Decks & Fencing 6 10-30-2008 10:32 PM
