Chevy 2500 Crew Cab Long Box Gas - Page 5 - Vehicles - Contractor Talk
Old 12-04-2018, 02:55 PM   #81
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 2,722
Re: Chevy 2500 Crew Cab Long Box Gas
Originally Posted by WarnerConstInc. View Post
Gas mileage will suck no matter what.
I can't see parts or repair being any different between 2500/3500.
Same truck with a couple more leafs in the spring.
Inner10 is online now
Jaws (12-04-2018)
Old 12-04-2018, 04:58 PM   #82
META's Avatar
Trade: General and Trades
Rewards Points: 2,662
I hear heavier duty axel and brakes as well.
META is online now
Old 12-04-2018, 06:01 PM   #83
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,366
Originally Posted by META View Post
I hear heavier duty axel and breaks as well.
Not between the 2500hd and 3500hd.
Possibly between 2500 and hd model.
Not much difference between the HDs at all.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
META (12-04-2018)
Old 12-04-2018, 06:24 PM   #84
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,234
Yes the 3500 has a reinforced rear end housing as well as helper springs
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
META (12-04-2018)
Old 12-04-2018, 07:14 PM   #85
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 12,706
Saw these the other day. Gms, i think they were gas trucks not sure though
A&E Exteriors is offline
The Following User Says Thank You to A&E Exteriors For This Useful Post:
META (12-04-2018)
Old 12-04-2018, 07:19 PM   #86
META's Avatar
I think I heard something about the single mirror bar and body mount change for 2020 GMC/CHEVY trucks.
META is online now
The Following User Says Thank You to META For This Useful Post:
A&E Exteriors (12-04-2018)
Old 12-04-2018, 07:39 PM   #87
Windycity's Avatar
Trade: Masonry
Yeah Chevy just released pictures of the 2020HD pick up truck and those are similar because of the side mounted bed step
Old 12-04-2018, 08:35 PM   #88
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 1,976
The side step is really ugly, somebody should be getting fired for that.
Big Johnson is offline
Old 12-04-2018, 08:56 PM   #89
I think you should order the one you sent me.
META (12-04-2018)
Old 12-04-2018, 08:57 PM   #90
I like Green things
Ugly yes, practical though.
Warner Mill Works
Facebook
YouTube
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
A&E Exteriors (12-04-2018), Inner10 (12-05-2018)
Old 12-04-2018, 09:02 PM   #91
It is practical but they could have come up with a better design. Maybe that’s just the WT package and the fancier packages have something more aesthetically appealing.
Old 12-04-2018, 10:01 PM   #92
META's Avatar
I am getting really close
https://www.chevrolet.com/trucks/sil...stalCode=49341
Being I am also a recent grad, I qualify for a GM discount comparable to the supplier or military discount. Apparently these discounts are not allowed to be combined.
I'll be getting wheel2wheel step rails although some may not be compatible with wheel splash guards.
I am looking into a bed liner like https://dualliner.com because I know the spray in liner will get beat up around the wheel wells with just a rubber mat floor. However, I still need to check I can attach a https://www.rackitinc.com heavy duty rack to the rails with the plastic liner. I may need to modify the side rail liner.
I'll be getting new rail bed tool boxes and looking for the largest I can find where I'll hang/attach them to the rack uprights. I have some large lower quality aluminum deezee rail boxes now but they required bolts to the truck bed. I'd like to avoid penetrating the bed and rails if possible.
I have a cheap harbor freight box rack that I slightly modified. It's been a decent rack for $200...
Finally, wheel flares. I may put some on to protect the wheel panels.
META is online now
Old 12-04-2018, 10:50 PM   #93
GC/carpenter
Californiadecks's Avatar
Rewards Points: 10,952
I think the only difference between the 2500 and the 2500hd is the hood height.
Mike.
_______________
Californiadecks is online now
Old 12-05-2018, 09:25 PM   #94
META's Avatar
I am looking at this European underbody coating.
DINITROL 4941
https://www.rencosupplyonline.com/Pr...ode=DIN4941LBX
META is online now
Old 12-05-2018, 09:44 PM   #95
Windycity's Avatar
Trade: Masonry
DINITROL 4941
For undercoating?
Old 12-05-2018, 10:59 PM   #96
META's Avatar
For undercoating?
Yeah. Still doing research on products.
META is online now
Old 12-06-2018, 12:43 AM   #97
Windycity's Avatar
Trade: Masonry
You have to be careful with products because Chevy waxes their frames and some products could soften the wax causing failure and exposing bare metal
The product they use is daubert noxrust on the frame
META (12-06-2018)
Old 12-06-2018, 06:33 AM   #98
META's Avatar
Thanks for that info.
https://www.daubertchemical.com/stor...ox-rust-x-121b
NOX-RUST X-121B
"Nox-Rust*X-121B (also known as "Nox-Rust*X-121 Black") dries to a firm wax-like film that will repel water, self-heal, and remain flexible at low temperatures. Can be easily applied using low-pressure airless equipment."
It is my understanding Nox-rust isn't very durable much longer than a year.
Dinitrol 479 appears to be a longer lasting product. However, still not sure about applying Dinitrol over Nox-Rust.
"DINITROL 479 Black 1 L 12-P
DINITROL 479 is a thick corrosion preventative compound with a ”rubbery” consistency which forms a very hard, elastic, wear resistant protective film with extremely good sound damping pro-perties. The product has high thixotropy, contains low aromatic solvent that do not attack paints, plastics and rubber parts of the car. The thick layer of coating has a heavy-duty structure, which looks like orange peel and absorbs very well outside road noise resonance from vibrations of vehicle parts as well as damps sound from stone chip and sand attacks. The product withstands heavy mechanical wear with excellent adhesion properties. DINITROL 479 is an approved alternative for wheel arches covers from plastic or felt. The product has good adhesion to painted and primed surfaces, original PVC and steel and ensures reliable protection from corrosion. DINITROL 479 is designed as sound deadening and corrosion protective product for treatment of underbody *components, like wheel arches, door sill plates of all kinds of vehicles, busses, trucks, trailers etc."
META is online now
Old 12-06-2018, 06:42 AM   #99
NOX-RUST X-121B
The problem I’ve had with cars/trucks rusting out is the bottoms of the painted panels on the sides. I wouldn’t get too worked up over underbody coatings.
For $20/month you can get a mister car wash unlimited package. $30 for the ultimate wash package. Definitely worth the $$$, there are mister car washes all over around here. Keeps the salt off in the winter.
Old 12-06-2018, 06:50 AM   #100
I like Green things
Salt? That stuff the put on the roads in MI is nasty stuff. Like some sort of brine.
Warner Mill Works
Facebook
YouTube
Come on, Share some pictures of your work... Dyer Sandblasting 577 08-22-2015 09:31 PM
2002 Chevy 2500 Utility nakarsten Contractor Swap 2 11-23-2012 10:09 PM
long term planning question guardian Business 1 04-19-2011 12:49 AM
Crew or Sub work out? KES Decks & Fencing 6 10-30-2008 10:32 PM
