Chevy 2500 Crew Cab Long Box Gas - Page 3 - Vehicles - Contractor Talk
Old 11-19-2018, 10:07 PM   #41
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,086
Re: Chevy 2500 Crew Cab Long Box Gas
Big Johnson is online now
Old 11-20-2018, 05:40 AM   #42
META's Avatar
Trade: General and Trades
Rewards Points: 3,374
Yeah, I'd be getting something like those for the floors.
META is offline
Old 11-20-2018, 06:25 AM   #43
META's Avatar
Regarding tires.
$40 per tire difference between 18" and 20".
META is offline
Old 11-20-2018, 10:11 AM   #44
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,418
Originally Posted by META View Post
Regarding tires.
It's not really the tire as much as it is the fancy rim.
Mike.
_______________
Calidecks is online now
Old 11-20-2018, 10:32 AM   #45
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,572
I just ordered rubber floors for my 97, now to get the motivation to pull the interior.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 11-20-2018, 11:14 AM   #46
The Sheriff
Jaws's Avatar
Rewards Points: 4,936
I have never had twenties, I have never cared to customize my trucks. I run them pretty much stock four-wheel Drive, only upgrades I buy are either a weather guard or Rawson and Koenig tool box, always put a cow catcher on the front because of all of the deer, and now that these trucks are so tall I put rails on my truck is well. I used to put headache racks on but I don't even do that anymore because we have a number of flatbeds and it's easy enough to just hook up to 1 and pick up whatever I need. It does look better with a headache rack in my opinion but I'm not really into the look thing.
My 18 F250 is 61 in off of ground I believe to the top rail of the back of the truck, with a 18s.
I hate carpet, I did not have the option to get rubber floors with the model truck I bought this time, I bought WeatherTech floor mats and they work fine for that. They are constantly muddy, if it's all remodel work it's not as big a deal as new construction but even outside of that with the deer lease in my own place I'm going to get muddy pretty regular
Sent from my SM-N920V using Tapatalk
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 11-20-2018, 11:25 AM   #47
I like Green things
One thing I like about dodge, they offer the perfect options in their tradesman package. The other two need to figure that out.
Warner Mill Works
Facebook
YouTube
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
Jaws (11-20-2018), META (11-20-2018)
Old 11-20-2018, 11:27 AM   #48
The Sheriff
Jaws's Avatar
May have to buy our first new Dodge, we're going to look at a Tradesman diesel.
The 550 we bought is a Tradesman, I agree it is a good package.
It feels like cheating on Ford...
John
Jaws is online now
Old 11-20-2018, 11:48 AM   #49
META's Avatar
Mike.
_______________
This is rubber to rubber comparison...other than /65 to /60.
META is offline
The Following User Says Thank You to META For This Useful Post:
Calidecks (11-20-2018)
Old 11-20-2018, 12:02 PM   #50
I like Green things
I will drive whatever suits my needs, dont really care who made it.
Warner Mill Works
Facebook
YouTube
Deckhead (11-20-2018)
Old 11-20-2018, 12:14 PM   #51
Donohue Const's Avatar
Rewards Points: 1,530
you can delete the carpet in f series up to the lariat trim
and it saves you $50!!!
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is online now
Old 11-20-2018, 12:20 PM   #52
META's Avatar
I am ok with most of the stock. However, steel rims is a poor option in winter salt conditions....hence the attempt to upgrade to aluminum...which forces you into an Alaska plow package with its lettering plastered in the side of your truck, or the pricey 20", or chrome 20" WITH convenience package.
My list is pretty darn stock, accept the larger towing mirrors...
I added some lights for the box and roof, but that isn't that much.
You guys should play around with their build software and get a feel for the process...if you aren't.
I've been driving a 95, 1500 4x4 with 270+ on it.
Long bed crew cab 4x4 WT stock already built gets me a white truck...if they aren't sold out quick. Otherwise, I bump up to the LT....or other.
META is offline
Old 11-20-2018, 12:23 PM   #53
I like Green things
Aluminum rims are worse in the rust belt. They will start to corrode and will constantly leak around the beads.
Warner Mill Works
Facebook
YouTube
Inner10 (11-20-2018)
Old 11-20-2018, 12:35 PM   #54
META's Avatar
I guess I'd need to research case studies on it but I haven't had trouble with my aluminum rims.
META is offline
Old 11-20-2018, 12:41 PM   #55
I like Green things
The Alcoa's on my 97 350 are fine, but have not seen salt.
The GM wheels from mid 2000s on were horrible. Had a set of foose rims that started in a couple years.
228k on my 97, should be good for another 250k.
Warner Mill Works
Facebook
YouTube
META (11-20-2018)
Old 11-20-2018, 12:50 PM   #56
META's Avatar
Speaking of rubber floors....buddy's truck on lunch today.
META is offline
Old 11-20-2018, 01:12 PM   #57
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 562
I've had 3 trucks with aluminium wheels, at least 300,000 miles between them, and 12 Rochester winters, and never have had a problem with corrosion causing leaks....
mrcat is online now
The Following User Says Thank You to mrcat For This Useful Post:
META (11-20-2018)
Old 11-20-2018, 05:22 PM   #58
TimNJ's Avatar
Rewards Points: 4,472
Well I'm going to buck the trends here and say get the diesel.
I had a 2500 LTZ ext cab 4x4 gas and that thing was a gas hog. Best I could do was 13mpg.
The kicker was when I bought it the diesel was an extra $8000-8500.
When I got rid of it, the diesels were fetching $10,000 more than the gassers.
My Ram diesel 3500 dually gets 16mpg without trying.
TimNJ is offline
Old 11-20-2018, 05:27 PM   #59
I like Green things
It was always the beads that leaked.
Warner Mill Works
Facebook
YouTube
META (11-20-2018)
Old 11-20-2018, 06:34 PM   #60
META's Avatar
My state's present average fuel prices.
Gas: $2.44/13mpg= $.188
Diesel: $3.31/16mpg= $.207
Of course diesel engines outlast gas engines with potentially 2.5 as many miles.
I am not a mechanic, but some average miles to engine type from the interwebs..
Gas: 200,000 miles
Diesel: 500,000 miles
Gas is presently $.018 cheaper than diesel.
Hypothetically, if I run gas for 500,000 miles at today's fuel prices I save 500,000X$.018= $9,500. Then we add in the upfront cost of a diesel of about $10,000 to equal around $19,500 to replace a gas engine potentially twice over the hypothetical life of the vehicle in diesel engine terms.
It appears cheaper to run gas, not including the down time of engine replacement.
I am sure there are other factors I haven't included, but I still prefer gas for my needs.
META is offline
Come on, Share some pictures of your work... Dyer Sandblasting 577 08-22-2015 09:31 PM
2002 Chevy 2500 Utility nakarsten Contractor Swap 2 11-23-2012 10:09 PM
long term planning question guardian Business 1 04-19-2011 12:49 AM
Crew or Sub work out? KES Decks & Fencing 6 10-30-2008 10:32 PM
